Klingspor's Woodworking Shop (Locations) Ad #1
Results 1 to 10 of 10
  1. #1
    Nickname
    Join Date
    Oct 2009
    Location
    Angier, NC
    Posts
    Visit Freq
    4.96 visits/week
    Threads
    Classifieds
    Gloss over Danish Oil
    I am finishing a walnut bench that I have applied two coats of Watco Danish Oil (Dark walnut) to. It does not have much of a shine (Actually hardly any) Can I apply polycrylic over the danish oil without any issues? If not polycrylic what would you recommend. And how long should I wait after applying the Watco danish oil before applying the topcoat.
  2. #2
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    11,689
    Visit Freq
    7.00 visits/week
    Threads
    678
    Classifieds
    Re: Gloss over Danish Oil
    Watco oil is a blend of varnish and linseed oil. If you want gloss you can continue to build up the Watco oil finish, I find that four coats starts to have some sheen. You could buff with paste wax. Or you can use a gloss spar varnish. Polyurathane would also work, but if you had to repair it later the featheredge where you sand out the repair would show. With oil or spar varnish repairs blend in much better.
    It all depends on the final look you are after and what you are comfortable doing.
    Oil usually takes at least a week to dry well enough to top coat.
    Please post some pictures of your project!
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  3. #3
    DQ
    bluedawg76's Avatar
    Nickname
    Sam
    Join Date
    Aug 2010
    Location
    Durham, NC
    Posts
    876
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    In general, oil/varnish finishes aren't really meant to have a high sheen, but instead have that "in the wood" finish and feel. 2 coats are all that is necessary (as per manufacturers' recommendations). Any buildup in the sheen is not the oil, but just more varnish coating. It's much quicker and economical to either buff with wax or switch over to a varnish.
    Let it dry for at least 3 days, but closer to a week is probably better. It should just barely smell like linseed oil if at all once it's dry. Next, it depends on the look your after (here I'd highly recommend a test piece for comparison that has the same 2 coats of Danish oil). Like Mike said I'd try:
    1) Buff with paste wax which will be a soft finish with a nice luster.
    2) Although polycrylic should be fine, I'd tend to stay on the oil side and use a wiping varnish like thinned polyurethane (50/50 gloss polyurethane/ mineral spirits). You could always try a test piece and see how the polycrylic performs as well. Lots of premixed versions of wiping varnish out there as well. See the Howard Acheson's post for application:
    http://www.ncwoodworker.net/forums/s...ight=wipe+poly
    To repair: Wax can be removed with mineral spirits and then reapplied. A varnish needs to be stripped (chemical or sanding) but is much more protective.
    Note that Danish oil is usually mostly mineral spirits (~50%) with some raw linseed oil and a little varnish. Raw linseed oil takes much longer to cure than boiled linseed oil (3d vs. 1d in optimum conditions). A homebrew recipe for oil/varnish is 1/3,1/3,1/3 boiled linseed oil (BLO): mineral spirits: varnish (polyurethane or other). apply like danish oil except it dries a bit faster. then buff with wax or topcoat with varnish. Alternatively, if you want the oil look and varnish sheen/feel/protection, you can simply coat with blo, let dry, then topcoat with varnish. Oh the possibilities...
    HTH,
    Sam
    Last edited by bluedawg76; 12-20-2011 at 10:30 AM. Reason: remove random emoticon again?
    You can't milk a cow with your hands in your pants.
  4. The following user says Thank You to bluedawg76 for this useful post:
  5. #4
    DQ
    Nickname
    Howard
    Join Date
    Apr 2006
    Location
    Bolivia, NC
    Posts
    772
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    As already said, oil/varnish finishes like Watco do not result in a high gloss. They are in-the-wood finishes the leave a sort of soft sheen.
    You can overcoat Watco with a waterborne acrylic like Polycrylic but you must allow the Watco to fully dry. This means to give it at least 7-10 days. It may seem dry earlier but because of the deep absorption of the oils, the oxygen necessary for continued curing must not be impeded by a relatively air impervious finish like waterborne acrylic.
  6. #5
    Master Scrap Maker Corporate Member
    DQ
    merrill77's Avatar
    Nickname
    Join Date
    Oct 2008
    Location
    Raleigh, NC
    Posts
    2,624
    Visit Freq
    0.15 visits/week
    Threads
    281
    Classifieds
    Quote Originally Posted by ck1999 View Post
    Have you finished the finish? (credit Bob Flexner)
    I was able to get a medium-high gloss on maple by building a few layers of oil/varnish, letting it cure for a week or so, and then wet-sanding (again with the oil/varnish) up through 600 grit. Go higher for a higher gloss.
    Turning beautiful wood into scraps...one board at a time.
  7. #6
    DQ
    bluedawg76's Avatar
    Nickname
    Sam
    Join Date
    Aug 2010
    Location
    Durham, NC
    Posts
    876
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Quote Originally Posted by merrill77 View Post
    good point!
    would you consider this burnishing the wood rather than the finish? with the end result being the same
  8. #7
    DQ
    Nickname
    Howard
    Join Date
    Apr 2006
    Location
    Bolivia, NC
    Posts
    772
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    If you check in your copy of Flexner, you will find that he discourages trying to "build" and oil/varnish finish. Oil/varnish finishes contain so much oil that they are not absorbed very must after the initial application. The high oil content also means the too many coats leaves a gummy, soft finish.
    Oil/varnish mixture finishes are intended to be an in-the-wood finish. The varnish component effectively seals the pores and the surface preventing subsequent application from being absorbed.
  9. #8
    DQ
    merrill77's Avatar
    Nickname
    Join Date
    Oct 2008
    Location
    Raleigh, NC
    Posts
    2,624
    Visit Freq
    0.15 visits/week
    Threads
    281
    Classifieds
    Quote Originally Posted by bluedawg76 View Post
    good point!
    IMO, no. An oil/varnish finish still builds a surface coat, albeit very slowly compared to straight varnish. So it is about leveling and polishing the finish to a higher sheen. I'm certainly no expert in finishing, though.
    Quote Originally Posted by Howard Acheson View Post
    It certainly doesn't build enough of a surface coat to fill the pores on oak, for example (I've tried that). But on a well prepped surface without substantial pores to fill, it seems to build just enough. In my case, the surface was maple and was prepped with a scraper, not sandpaper. I sealed with a coat of 2-3lb shellac, applied a few coats of the oil/varnish, then wet sanded a week or so later. I got a reasonable sheen on it - not a high gloss, but enough to see a reflection in the surface.
  10. #9
    Nickname
    Join Date
    Oct 2009
    Location
    Angier, NC
    Posts
    Visit Freq
    4.96 visits/week
    Threads
    Classifieds
    I ended up getting some spray can lacquer. I applied about 4 coats to the entire bench and about 7 to the top. I may try and apply more later. I sanded after a few coats (400 grit). The lacquer did add gloss and made it look better.
    Thanks for the help.
  11. #10
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    6,379
    Visit Freq
    6.92 visits/week
    Threads
    574
    Classifieds
    Nicely done. It looks good.
Similar Threads
  1. Low gloss poly top-coat??
    By kooshball in forum Finishing
    Last Post: 04-24-2011, 06:47 PM
  2. High-gloss Tung oil vs Low-gloss & Poly
    By BrianBDH in forum Finishing
    Last Post: 02-14-2010, 03:46 PM
  3. Satin Simi-Gloss or Gloss Which sheen is best.
    By Bryan S in forum Finishing
    Last Post: 03-15-2008, 11:49 AM
  4. Knock Down Gloss
    By smessick in forum Finishing
    Last Post: 05-24-2007, 08:25 AM
  5. Black gloss finish on headboard
    By John Reeves in forum General Woodworking
    Last Post: 05-04-2007, 08:20 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
