Results 1 to 11 of 11
11-16-2011, 05:29 PM #1User (Inactive)
- Nickname
- Nate
- Join Date
- Jan 2011
- Location
- Durham, NC
- Posts
- 26
- Visit Freq:
- 0.35 visits/week
- Threads
- 9
- Classifieds
- 0
Dual Purpose Post - WIP and Dust Collector vs Cyclone Attachment
So, I have two goals with this post.
1. I've been working on a walnut toy box. This is my first project using rough lumber. Pictures below:
Rough cut from Saw4you:
Squared Stock
Dry Fit of the front face - first raised panel project
2. During this project, I managed to create a giant mess of dust and wood chips. I have a 16 gallon shop vac, but it really didn't help. So the questions to the guru's is would a cyclone attachment be sufficient or should invest in a DC unit? If DC unit, then what should I look for? $100 or $1,000 unit?
Thanks for looking.
11-16-2011, 05:37 PM #2Corporate Member
DQ
- Nickname
- Jeremy (32)
- Join Date
- Dec 2010
- Location
- Greensboro, NC
- Posts
- 495
- Visit Freq:
- 6.92 visits/week
- Threads
- 38
- Classifieds
- 0
Re: Dual Purpose Post - WIP and Dust Collector vs Cyclone Attachment
Dust Collector! Harbor Freight (I know a lot of their stuff is garbage) sells a 1.5HP Dust Collector (with good reviews) for $249. If you check their ads, you can use a coupon and get it for $139. I have had mine for over a year and a half and it is still working great. I know somebody will probably say that Harbor Freight sucks and that you are wasting your money. I would challenge them to find a better dust collector solution for $139! :-)
Just my 2 cents.
11-16-2011, 05:52 PM #3Administrator Corporate Member
DQ
- Nickname
- Mark (58)
- Join Date
- Dec 2009
- Location
- Willow Spring, NC
- Posts
- 2,731
- Visit Freq:
- 7.00 visits/week
- Threads
- 182
- Classifieds
- 6
For $139.00 the HF DC works very well. If you go that route, consider adding a Thein type pre-separator or something like the Vortex system from Rockler. If you don't, you will be emptying the bags quite often and losing suction as you use the collector.
You should also replace the filter bags that are on the HF DC with either 1.0 or .5 micron bags or better still a Wynn filter.
If you can afford to do so, a full blown cyclone system is the way to go. Check out Penn-State Industries, Oneida, Clear-Vue, Grizzly, JDS, etc.“I know you believe you understand what you think I said, but I am not sure you realize that what you heard is not what I meant.” - Richard M. Nixon
11-16-2011, 06:15 PM #4Staff Advisor
DQ
- Nickname
- Joe (70)
- Join Date
- Sep 2005
- Location
- Holly Springs, NC
- Posts
- 4,479
- Visit Freq:
- 6.92 visits/week
- Threads
- 597
- Classifieds
- 0
The box looks good
Personally, I'm happy with my Fein vac and a 40gal paper barrel and Thein baffle. But if I had the room, I'd have a cyclone.Always be yourself because the people that matter don't mind, and the ones who mind, don't matter.
11-16-2011, 08:24 PM #5Forum Leader Corporate Member
DQ
- Nickname
- tat
- Join Date
- Jul 2008
- Location
- Charlotte, NC
- Posts
- 889
- Visit Freq:
- 6.65 visits/week
- Threads
- 72
- Classifieds
- 0
Wynn Filter Wynn Filter and yea WynnFilter....
http://www.wynnenv.com/cartridge_filters.htm
so yea I have the HF dustcollector with the Wynn Filter cause at the time it was the best deal and I am happy with the job it does but
I just bought this today cause a dust collector is not enough in the long run
http://jdstools.com/jdsairtechhp.aspx
11-16-2011, 08:53 PM #6Corporate Member
DQ
- Nickname
- paul (55)
- Join Date
- Dec 2010
- Location
- Clinton, NC
- Posts
- 183
- Visit Freq:
- 2.31 visits/week
- Threads
- 13
- Classifieds
- 0
I have an Oasis 5 HP single stage sytem with 4" PVC going to each of my large machines. It came to my door for a total cost of $470. I then spent about $200 on PVC pipe and fittings. At each tool, the suction will pull the fuzz off of a tennis ball. The DC is located next to a 1/2 HP housed exhaust fan installed onto a 24" X 24" window. It easily handles ambient dust that escapes the canvass bags. This is the way to go, in my view, but many are sure to disagree. The bottom line is that my tools are nearly dust free and I've save a heap of money. I will take photos and do a full report when I get the time.
The following user says Thank You to pviser for this useful post:
11-17-2011, 07:30 AM #7Corporate Member
DQ
- Nickname
- Lloyd
- Join Date
- Apr 2010
- Location
- Raleigh, NC
- Posts
- 55
- Visit Freq:
- 5.58 visits/week
- Threads
- 10
- Classifieds
- 0
I recently got the HF dust collector, and have a trash can type separator. Once I got a jointer and planer this year, it was absolutely necessary. I love the set up, and the whole thing cost less than $200. Next upgrade will be the better filter bag - per Mark's suggestion.
Lloyd
11-17-2011, 08:50 AM #8User (Inactive)
- Nickname
- Nate
- Join Date
- Jan 2011
- Location
- Durham, NC
- Posts
- 26
- Visit Freq:
- 0.35 visits/week
- Threads
- 9
- Classifieds
- 0
So, I did a bit of research last night. I think I'll start with the Thien Seperator. Once I get that working with the shop vac, I'll go get a DC.
11-17-2011, 12:51 PM #9Corporate Member
DQ
- Nickname
- David
- Join Date
- Feb 2010
- Location
- Apex, NC
- Posts
- 760
- Visit Freq:
- 6.73 visits/week
- Threads
- 177
- Classifieds
- 1
I mounted my Thien baffle inside the bag ring on my HF DC with excellent results. I also have the Wynn filter and and ambient JDS air cleaner and although I want a 5HP cyclone, the results I get are acceptable, if I setup an over-blade DC fitting I would be all set...
11-17-2011, 03:39 PM #10Forum Leader Corporate Member
DQ
- Nickname
- tat
- Join Date
- Jul 2008
- Location
- Charlotte, NC
- Posts
- 889
- Visit Freq:
- 6.65 visits/week
- Threads
- 72
- Classifieds
- 0
11-18-2011, 07:25 AM #11Corporate Member
DQ
- Nickname
- David
- Join Date
- Feb 2010
- Location
- Apex, NC
- Posts
- 760
- Visit Freq:
- 6.73 visits/week
- Threads
- 177
- Classifieds
- 1
"There is always free cheese in a mousetrap" - H. R. Gross [1899-1987], Member of Congress [1948-1974] [R] Iowa
Similar Threads
Grizzly Industrial Dust Collector Dual Bag 3HP G1030 - $300 (North Raleigh)
By Splint Eastwood in forum Found for Sale/Hot DealsReplies: 0Last Post: 01-24-2010, 03:25 PM -
Dust Collector: Cyclone vs. Portable?
By mburke911 in forum Power Tools and Their UseReplies: 12Last Post: 01-24-2009, 10:31 AM -
Raleigh CL Delta dual bag dust collector $200
By woodworker2000 in forum Found for Sale/Hot DealsReplies: 4Last Post: 05-22-2008, 12:31 AM -
Clearvue Cyclone Dust Collector?
By Tarhead in forum Power Tools and Their UseReplies: 7Last Post: 08-21-2006, 05:59 PM
