Klingspor's Woodworking Shop (Festool) Ad #2
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
  1. #1
    DQ
    kooshball's Avatar
    Nickname
    Join Date
    Feb 2010
    Location
    Apex, NC
    Posts
    1,315
    Visit Freq
    0.50 visits/week
    Threads
    262
    Classifieds
    Help setting the blade in Stanley Bailey #4 plane!!
    I was given an old Stanley Bailey #4 plane recently (with the ridges in the sole). The trouble is that I can't get the iron to sit in the mouth properly. With the bevel down the iron will sit flush with the front of the mouth which won't allow the shavings to come through the sole. I have tried to move the "ramp" (if that is what it is called) back but the same thing happens. It is almost as if the iron angle is too shallow.
    Any ideas?
    Thanks
  2. #2
    DQ
    Nickname
    Chuck
    Join Date
    Nov 2005
    Location
    Rocky Mount, NC
    Posts
    2,783
    Visit Freq
    0.46 visits/week
    Threads
    120
    Classifieds
    Re: Help setting the blade in Stanley Bailey #4 plane!!
    Quote Originally Posted by kooshball View Post
    Any ideas?
    Thanks
    A Stanley 4 with vintage iron shouldn't have any problem. Do you have pictures?
    Bevel angle should be 25 degrees but up to 30 would work okay.
    The ramp is called a frog. You should be able to line it up directly with the sole angle in the mouth.
    It's possible someone used a thicker blade maybe?
    Chuck
  3. #3
    User eyekode's Avatar
    Nickname
    Salem
    Join Date
    Jan 2009
    Location
    Apex, NC
    Posts
    2,072
    Visit Freq
    0.31 visits/week
    Threads
    184
    Classifieds
    My guess is some mistake with the frog/blade/chipiron assembly. If you take the frog out but assemble the iron on the frog properly it would look like this:
    Check out the whole article: http://blog.woodworking-magazine.com...+Sandwich.aspx
    If it doesn't work out I am running an old-plane-orphanage at my place .
    Salem
  4. #4
    DQ
    kooshball's Avatar
    Nickname
    Join Date
    Feb 2010
    Location
    Apex, NC
    Posts
    1,315
    Visit Freq
    0.50 visits/week
    Threads
    262
    Classifieds
    I will need to get some photos tomorrow but I have aligned the frog with the mouth and I still have the same issue. Also, the iron is pretty thin so I am under the assumption that it is the original.
    Thanks
    Quote Originally Posted by cpowell View Post
    Chuck
  5. #5
    Nickname
    Salem
    Join Date
    Jan 2009
    Location
    Apex, NC
    Posts
    2,072
    Visit Freq
    0.31 visits/week
    Threads
    184
    Classifieds
    David,
    Are you sure the blade is lying flat on the frog (like the picture I posted previously)? Are you sure the bevel is down on the blade?
    Salem
  6. #6
    Forum Leader Corporate Member
    DQ
    Bryan S's Avatar
    Nickname
    Bryan
    Join Date
    Apr 2006
    Location
    Burlington, NC
    Posts
    2,637
    Visit Freq
    5.92 visits/week
    Threads
    151
    Classifieds
    He is your partner, your defender, your friend, your dog. You are his love, his life, his leader. He will be yours, faithful and true to the very last beat of his heart. You owe it to him to be worthy of such devotion
  7. #7
    DQ
    kooshball's Avatar
    Nickname
    Join Date
    Feb 2010
    Location
    Apex, NC
    Posts
    1,315
    Visit Freq
    0.50 visits/week
    Threads
    262
    Classifieds
    Thanks guys. Let me clarify a few things since I made an error in my original post.
    -The plane is actually a no 5 (not no 4).
    -I have set just the iron against the frog with the frog flush with the back of the mouth and it sits flat but there is still no room between the front of the mouth and the iron
    -yes the bevel is down
    the width of the mouth opening seems pretty narrow; what is a "normal" dimension?
    Thanks
  8. #8
    Nickname
    Salem
    Join Date
    Jan 2009
    Location
    Apex, NC
    Posts
    2,072
    Visit Freq
    0.31 visits/week
    Threads
    184
    Classifieds
    The mouth on my 2 #5's is .160. The iron is around .085. We need a picture. Or you could bring it by if you want .
    Salem
  9. #9
    DQ
    kooshball's Avatar
    Nickname
    Join Date
    Feb 2010
    Location
    Apex, NC
    Posts
    1,315
    Visit Freq
    0.50 visits/week
    Threads
    262
    Classifieds
    I am still looking for the camera but the width of my mouth is 0.14 and the Stanley iron is 0.10.
    Quote Originally Posted by eyekode View Post
    Salem
  10. #10
    DQ
    Bryan S's Avatar
    Nickname
    Bryan
    Join Date
    Apr 2006
    Location
    Burlington, NC
    Posts
    2,637
    Visit Freq
    5.92 visits/week
    Threads
    151
    Classifieds
    David based on your last post, with the front of the frog flush with the back of the mouth it sounds like the frog is still too far forward. I am still early in this hand plane learning curve, but I did the same thing setting up my first plane. Like you did, I set the frog even with the back of the mouth and I had to move the frog back a good bit more than I thought it would have to be.
  11. #11
    Returning Member
    DQ
    09woodie22's Avatar
    Nickname
    Gabe
    Join Date
    Aug 2010
    Location
    Penhook, VA
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    You have gotten plenty of informed input! Just FYI (and not trying to be an opportunist) if you find out it is the wrong blade I have a spare I'll part with for a song.
    Gabe
  12. #12
    DQ
    bluedawg76's Avatar
    Nickname
    Sam
    Join Date
    Aug 2010
    Location
    Durham, NC
    Posts
    876
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    if you're blade measures 0.1" thick, it's probably a newer blade? which are typically the thicker versions at 0.095". Is it a Stanley blade? I have an older #7 which has a very tight mouth that will not accommodate a thicker blade. You can ever so carefully file the front of the mouth just a hair, but be very cautious and conservative doing this. You can also introduce an angle of appr. 15 degrees to give a little extra help in getting the shavings out of the way. Another thought is to set the cap iron back closer to 1/16" rather than 1/32 or less as typically suggested for a smoother plane and that will improve your clearance with such a tight mouth.
    Sam
  13. #13
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,074
    Visit Freq
    6.65 visits/week
    Threads
    76
    Classifieds
    Let's make sure you have it set up correctly:
    First you have the plane body. That is the casting to which the handle (called a "tote") is screwed to.
    Then you have the "frog", which you call the "ramp". This can be set back to where the bevel is behind the opening ("mouth") because the bevel on the blade (properly called "iron") will allow more clearance. Loosen the two screws in the frog that attach the frog to the body. Set the iron (blade) on it with the bevel side down and adjuster disk in the slot on the blade, and move it back until you have about 1/32 or more mouth clearance between the top of the blade and the front of the mouth with the blade shoved through the mouth. Remove blade and tighten frog screws.
    Install the chip breaker. Screw is on the bottom (beveled side) and chip breaker is on top (flat side). Set front edge of chip breaker about 1/32" back from the cutting edge of the iron.
    Put chip breaker/iron assembly on the frog with the chip breaker screw head in the recess on the frog. Make sure the tang on the depth adjustment screw is going into the slot on the chip breaker, and the lateral adjuster disk is inside the wide slot on the iron.
    On top of this is the "cap iron", which holds it all secure and tight when in use. Lift the spring lever up and slide it full forward onto the chip breaker. Tighten screw until it just barely touches the cap iron, and then push the lever down.
    My guess is that you have the frog too far forward, the blade sitting on top of the lateral adjustment disk, or the chip breaker sitting on top of the depth adjuster tang. I have used thicker irons (blades) than the original and have still had plenty of clearance but all have had a 25 degree primary bevel.
    With a primary bevel of 25 degrees a much thicker iron can be used in any adjustable frog Stanley plane because the thickness of the blade going in front of the back edge of the mouth is no different than a stock iron. If you have a radical primary bevel (like 35+ degrees), you may be pushing the blade too far forward, which also may be your problem. Stanley/Bailey panes are designed for a 25 degree primary angle.
    Hope this helps
    Practicing at practical woodworking
  14. #14
    DQ
    kooshball's Avatar
    Nickname
    Join Date
    Feb 2010
    Location
    Apex, NC
    Posts
    1,315
    Visit Freq
    0.50 visits/week
    Threads
    262
    Classifieds
    Still no camera, sorry but I have a few updates.
    First, thanks for all the replies!
    I am not sure if the iron is stock but it does say Stanley sw inside a heart. The primary bevel is 25deg with a not so micro bevel of 30 deg taking up 3/32". The other Stanley iron that I have on a no6 is only .06" vs .1" for the no 5 iron.
    I have taken everything apart so that I can place the iron flush on the frog and watch/feel what happens as I slide the iron into the mouth. With the frog back, the iron slides into to mouth but in order to get to the correct depth the iron rides up into the back of the mouth and closes off the clearance in the front on the iron.
    From what I can see, three things that would would be a thinner iron, a steeper frog or perhaps a 20 deg primary bevel. Since the last two seem strange, perhaps a thinner iron is the way to go.
  15. #15
    DQ
    bluedawg76's Avatar
    Nickname
    Sam
    Join Date
    Aug 2010
    Location
    Durham, NC
    Posts
    876
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    well if it's a sw blade, it's not likely to be new. i thought production stopped on these in the 30's. also, i didn't realize they were that thick! perhaps the blade iron doesn't pair with the plane and is just a mistmatch? can you date the plane? there was a post a week or so ago with a nice link to a stanley plane dating site. what about the seating of the frog? are you sure it's seated at a 45 degree angle?
Similar Threads
  1. stanly bailey plane
    By yanmarman2007 in forum Hand Tools and their Use
    Last Post: 01-20-2011, 09:55 AM
  2. Where can I find a Stanley Bailey #5 replacement handle?
    By kooshball in forum Hand Tools and their Use
    Last Post: 11-14-2010, 09:20 PM
  3. CL - Stanley Bailey #3 hand plane - $30 (N. Raleigh/Wake Forest)
    By sushinutnc in forum Found for Sale/Hot Deals
    Last Post: 05-20-2010, 01:02 AM
  4. Stanley Bailey Clamps at Big Lots: Bessey K Clone
    By Mark Gottesman in forum Found for Sale/Hot Deals
    Last Post: 11-13-2008, 03:10 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
