West Penn Hardwoods (Ad 1)
Results 1 to 7 of 7
  1. #1
    Returning Member
    Nickname
    Join Date
    Nov 2008
    Location
    Kodak, TN
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    DeWalt 20" Scroll Saw-Type 1, Type2
    I recently purchased a 20" DeWalt scroll saw with a "Type 1" motor on it
    I see the newer ones have a "Type 2" motor.
    Can someone tell me the difference and the pros and cons?
    Thanks.
  2. #2
    Administrator Corporate Member
    DQ
    ScottM's Avatar
    Nickname
    Join Date
    Jul 2007
    Location
    Littleton, NC
    Posts
    10,749
    Visit Freq
    6.54 visits/week
    Threads
    939
    Classifieds
    Re: DeWalt 20" Scroll Saw-Type 1, Type2
    The type 1 are better machines. Made in Canada. The type 2 are made in the far east. Some the the type 2 issues included poor casting of the table, assembly issues and bad motors.
    Maker of fine saw dust
    "Ability is what you are capable of doing. Motivation determines what you do. Attitude determines how well you do it."
    - Lou Holtz-
  3. #3
    Returning Member
    Nickname
    Join Date
    Nov 2008
    Location
    Kodak, TN
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Quote Originally Posted by ScottM View Post
    Thanks.
    I guess old is better in this case. I wish I could say the same for myself.
  4. #4
    DQ
    PChristy's Avatar
    Nickname
    Phillip
    Join Date
    Jun 2008
    Location
    Lexington, NC
    Posts
    5,466
    Visit Freq
    5.42 visits/week
    Threads
    505
    Classifieds
    What Scott said I have the Type 1 and really like it alot - I have had to realign the blade left to right after that it is cutting like a charm
    What happen to the days when we where satisfied with what we had and really didn't care if we had what we didn't -
  5. #5
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    2,815
    Visit Freq
    6.69 visits/week
    Threads
    173
    Classifieds
    I have the DW788, but never checked to see which type it is. However, they,ll have to pry my saw from my cold, dead hands!!! You may find the need to do a little tune up on it. Treat the table top with a product like Top Saver, which will reduce friction on the work piece; make sure the thumb screws on the blade holders are CLEAN and the end that pinches the blade should be squared, not round. If the saw has a knocking sound, that is remedied by taking the top screw out of the tension lever, removing it, then remove screws from the sides of the black housing. Be sure to go slowly and not lose the small bushing when you remove the cap. There is a rod with an L shape end that goes to the rear, with the front of the short L sticking up into the housing. After removing the metal housing piece, turn the L end of the rod one turn clockwise, and reassemble. You will notice when you tension the blade again, the tension lever won't travel as far to the right to achieve the required tension amount, and the knocking will mostly be gone. Good luck! Enjoy a great saw!
  6. #6
    Returning Member sawduster's Avatar
    Nickname
    Robert
    Join Date
    Oct 2007
    Location
    Youngsville, NC
    Posts
    2,624
    Visit Freq
    0.00 visits/week
    Threads
    290
    Classifieds
    Type one over type two fer shure for exactly the reasons Scott gave I have one of each and the type one is just more solidly built.
    To piggyback on what sawman said , take the blade holder thumbscrews out and drag the ends across a piece of sandpaper a couple of times . This helps flattens them a bit but most importantly removes the oils that build up from the blades and all but eliminate any blade slippage
    If you don't have any Top Saver or similar, Johnson's paste wax will do also . Do not use car wax w/silicone ! Wood and silcone are not friends
    Check out Rick's site at http://www.scrollsaws.com/ for some more good info on the saw and lots of other resources
    ...~Robert~
    It ain't scrap till I say it's scrap !
  7. #7
    Returning Member
    Nickname
    Join Date
    Nov 2008
    Location
    Kodak, TN
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Thanks for the info and the tuneup tips. The saw wasn't used very much but I give 'er the tuneup.
    Sawman101: That's an awesome clock you had in another post. I really admire your patience! And what about all that sanding??!!!
Similar Threads
  1. Dewalt 788 Scroll Saw - $250 (Apex)
    By Splint Eastwood in forum Found for Sale/Hot Deals
    Last Post: 04-12-2010, 01:15 PM
  2. Dewalt DW788 Scroll Saw - $250 CLT CL
    By Charlottend in forum Found for Sale/Hot Deals
    Last Post: 03-09-2010, 03:41 PM
  3. CL Raleigh: DeWalt DW788 20" Scroll Saw with Stand 250.00
    By mburke911 in forum Found for Sale/Hot Deals
    Last Post: 03-03-2008, 12:49 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
