West Penn Hardwoods (Ad 1)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
  1. #1
    DQ
    kooshball's Avatar
    Nickname
    Join Date
    Feb 2010
    Location
    Apex, NC
    Posts
    1,320
    Visit Freq
    0.77 visits/week
    Threads
    264
    Classifieds
    filling knots and cracks with sawdust and epoxy vs. sawdust and wood glue?
    I have to fill some knots and cracks within knots on my walnut bed but I would like some advise on the best way to do it. Can I go for sawdust with wood glue or am I better off using epoxy?
    Thanks,
  2. #2
    Recovering tool addict Corporate Member
    DQ
    Bas's Avatar
    Nickname
    Bas (44)
    Join Date
    Aug 2007
    Location
    Raleigh, NC
    Posts
    6,957
    Visit Freq
    4.69 visits/week
    Threads
    354
    Classifieds
    Re: filling knots and cracks with sawdust and epoxy vs. sawdust and wood glue?
    I'd use 5 minute epoxy. I mix it with some coffee grounds to get a nice dark filling for the knotholes. Sawdust would work too, but may look unnatural in a knothole. The good thing about epoxy is that it won't creep like PVA glue and it's much harder.
    Bas.
    "I don't need it. I just want it."
    How to add a picture to your post
  3. #3
    DQ
    Tar Heel's Avatar
    Nickname
    Stuart
    Join Date
    Jan 2006
    Location
    Chapel Hill, NC
    Posts
    1,428
    Visit Freq
    0.00 visits/week
    Threads
    178
    Classifieds
    I have used walnut sanding dust (not sawdust) and CA with very good results.
  4. #4
    DQ
    kooshball's Avatar
    Nickname
    Join Date
    Feb 2010
    Location
    Apex, NC
    Posts
    1,320
    Visit Freq
    0.77 visits/week
    Threads
    264
    Classifieds
    Quote Originally Posted by Bas View Post
    Any issues with yellowing of the epoxy?
  5. #5
    DQ
    Bas's Avatar
    Nickname
    Bas (44)
    Join Date
    Aug 2007
    Location
    Raleigh, NC
    Posts
    6,957
    Visit Freq
    4.69 visits/week
    Threads
    354
    Classifieds
    I haven't seen any yellowing, but my woodworking experience with walnut is limited. Certainly nothing within 2 years. BTW, when filling a large knothole with epoxy, check the back and if it goes all the way through, put a piece of masking tape over it. Otherwise, you may attach the board to something permanently...
    Bas.
  6. #6
    Nickname
    Join Date
    Feb 2009
    Location
    Monroe, NC
    Posts
    431
    Visit Freq
    5.73 visits/week
    Threads
    Classifieds
    Coffee Grounds! Why not! Now there's an idea...
    I agree with Tar Heel on the sanding dust vs sawdust; although, on a knot sawdust would probably work okay.
    Usually, on walnut, the knot is darker than the surrounding wood. I have had excellent results mixing in some ebony or wenge sanding dust in with the walnut dust to get a good color match.
    Definitely go with the epoxy. Its harder, and doesn't shrink. You may have to use more than one application of epoxy, as it will sink into the wood and leave a depression on the first try. If so, you probably want to apply the second coat within a few hours (talking 5-min version); otherwise, after the first application fully cures, the second coat will not make a good bond with the first.
    Hope this helps.
    Matt...
  7. #7
    Board of Directors
    Vice President
    Returning Member CarvedTones's Avatar
    Nickname
    Andy (59)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,674
    Visit Freq
    0.04 visits/week
    Threads
    329
    Classifieds
    Epoxy will break down from exposure to light over time if there is no top coat of finish over it, but it doesn't require much to protect it. Just a little lacquer or varnish. Get it very near flat when you fill. A little "fudge factor" that seems like a good idea when you are filling it is a major pain to sand away later (DAMHIKT).
  8. #8
    DQ
    Bas's Avatar
    Nickname
    Bas (44)
    Join Date
    Aug 2007
    Location
    Raleigh, NC
    Posts
    6,957
    Visit Freq
    4.69 visits/week
    Threads
    354
    Classifieds
    Quote Originally Posted by CarvedTones View Post
    Sanding is definitely a pain. A block plane or scraper works quite well on epoxy. Just make sure you let it cure for 24 hours. It hardens within 5, but it will still be a little gummy on the inside.
    Bas.
  9. #9
    Board of Directors
    Vice President
    Nickname
    Andy (59)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,674
    Visit Freq
    0.04 visits/week
    Threads
    329
    Classifieds
    I get myself in trouble talking epoxy sometimes, but here I go again...
    I had troubles with the quick stuff a while back. I tossed what I had and got some newer better packaged (not the syringes) Loc-Tite 5 minute stuff and have had good results with it. For void filling, 5 minutes is about how long it takes for a film to form on the top and it will not run after that if you made a decently thick slurry. In the instructions on the Loc-Tite, they refer to 5 minutes as the "set time" and 24 hours as the cure time. Using it as an adhesive, you have to be really careful about what "set" means. Put some pressure on it anytime in the first couple of hours and you can get some creep. I also have some 2:1 slower laminating epoxy I often use for void filling, but after getting some better 1:1 quick stuff, I have to recant on my earlier opinion (in other threads) about that offering any significant advantage. There are some 5 minute products out there that never get all that hard though, so just make sure it really is a decent epoxy.
  10. #10
    DQ
    Bill Clemmons's Avatar
    Nickname
    Bill (69)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    5,964
    Visit Freq
    7.00 visits/week
    Threads
    254
    Classifieds
    I just did exactly what you're talking about on some turned walnut legs for a table. I gathered some fine sanding dust from the piece and mixed it w/ epoxy. I use the 60 min. variety, but the 5 min. works just as well. I just prefer the longer working time. One of the keys I've found when filling voids w/ epoxy is to stir it VERY slowly. Otherwise you will create bubbles which will gradually rise to the top and be visible when it is cured.
    Another way to color epoxy is with black tint. If you want to highlight or put emphasis on a spot, like a knot, add black artist tint. But again, stir slowly, as if you were moving in slow motion.
    Also, as some others have pointed, definitely plan on two applications. The first one will settle into the void and leave a depression. I use a scraper to remove the excess around the spot, and try to do it just before the epoxy hardens completely, but cured enough that it won't pull out of the void. Its a little easier.
    HTH, Bill Clemmons
    I'll gladly tell you how I do something. Just please don't confuse that with the right way to do it, and almost certainly not the only way.
  11. #11
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,101
    Visit Freq
    6.50 visits/week
    Threads
    77
    Classifieds
    I use the 5 min loctite epoxy and walnut sawdust. I have found it is easiest to tape close to the defect (blue masking tape or cellophane packing tape both work well) and fill level to the tape surface. After about 15 - 20 minutes, remove the tape, and it will be soft enough to pare with a sharp chisel flat with the surface. This will greatly reduce the sanding/scraping, which are a pain.
    Pics of how I do it are here: http://www.ncwoodworker.net/pp/showgallery.php?cat=1349. They will give you an idea of what it will look like.
    Practicing at practical woodworking
  12. #12
    DQ
    Bas's Avatar
    Nickname
    Bas (44)
    Join Date
    Aug 2007
    Location
    Raleigh, NC
    Posts
    6,957
    Visit Freq
    4.69 visits/week
    Threads
    354
    Classifieds
    Quote Originally Posted by Matt Furjanic View Post
    Cocoa powder makes for a terrific medium brown. Not kidding. I haven't gotten into using Paprika yet, or Curry, but I'm sure one day I'll need a special color....
    Bas.
  13. #13
    DQ
    kooshball's Avatar
    Nickname
    Join Date
    Feb 2010
    Location
    Apex, NC
    Posts
    1,320
    Visit Freq
    0.77 visits/week
    Threads
    264
    Classifieds
    Who has the oldest knot filled with coffee? I am curious as to how this will age (fading, reacting to epoxy, etc) although if you have a good UV resisant top-coat it should all be ok with the fading.
  14. #14
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    6,654
    Visit Freq
    6.96 visits/week
    Threads
    586
    Classifieds
    My main complaint with some of the epoxies from the big box stores is that it's hard to measure them out for the exact 1:1 mixture (eyeball it?). The smaller tubes with the self mixing nozzle/head work well, but you only get two (2) nozzles which can't be cleaned (supposedly acetone or ethanol will work if used right away). For small projects like filling knots you'll have a bunch of leftover epoxy resin and hardener in the dual syringe tubes, but no nozzles to dispense and mix it . Cost effective?
    The chemical reaction which creates epoxy only happens when the resin and hardener are mixed so the commonly held theory that either component "gets old" sitting on the shelf is hogwash. Store it as recommended by the manufacturer and it should last for years.
    West System epoxy is a little pricier, but you've got a lot of options from resins, hardeners, open time, cure time, fillers, etc. For starters the #105 resin (1 qt) and #205 hardener (1 pt) is an economical choice that'll give you a lot of epoxy for your buck. The metering pumps ($13 for the set) are designed to dispense the precise amounts of resin/hardener each time you use them. No need to clean them either, but they can be cleaned and stored away if you wish. Check out the West website for loads of useful information on product selection and applications.
    http://www.westsystem.com/ss/
  15. #15
    Forum Leader User
    DQ
    Glennbear's Avatar
    Nickname
    Glenn (69)
    Join Date
    Jan 2008
    Location
    Baskerville, VA
    Posts
    4,502
    Visit Freq
    0.50 visits/week
    Threads
    279
    Classifieds
    Quote Originally Posted by Jeff View Post
    Thanks for posting this Jeff, my first major woodworking project was a tack box for my daughter to take to equine college. The plans recommended West system for joinery and it worked out well.
    :new_uklia " I get knocked down but I get up again" - Chumbawamba
Similar Threads
  1. What do you do with your sawdust/wood shavings?
    By Mr. Lahey in forum General Woodworking
    Last Post: 03-01-2010, 12:27 PM
  2. What do you do with your sawdust?
    By rywilson in forum General Woodworking
    Last Post: 08-27-2008, 06:45 PM
  3. RAS sawdust
    By Glennbear in forum Power Tools and Their Use
    Last Post: 08-15-2008, 05:04 PM
  4. Sawdust useage
    By jeff... in forum Wood
    Last Post: 12-05-2006, 12:27 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
