West Penn Hardwoods (Ad 2)
Results 1 to 13 of 13
  1. #1
    Nickname
    Join Date
    Feb 2009
    Location
    Monroe, NC
    Posts
    433
    Visit Freq
    5.42 visits/week
    Threads
    Classifieds
    Need a wood glue with long setting time
    I will be making some walnut chairs, and need a wood glue (not epoxy) with a long-set time. Just wanted to get some opinions.
  2. #2
    Board of Directors
    Vice President
    Returning Member CarvedTones's Avatar
    Nickname
    Andy (59)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,674
    Visit Freq
    0.04 visits/week
    Threads
    329
    Classifieds
    Re: Need a wood glue with long setting time
    You need to quantify what you mean. I think plain old TightBond I has a long set time.
  3. #3
    User WoodWrangler's Avatar
    Nickname
    Jeremy (40)
    Join Date
    Mar 2006
    Location
    Bradenton, Fl
    Posts
    5,275
    Visit Freq
    0.23 visits/week
    Threads
    572
    Classifieds
    Plastic Resin glue has a long set time, but is very hard/brittle and does not work good in all applications. Titebond also has a slow setting glue (white in color) that is decent.
  4. #4
    Recovering tool addict Corporate Member
    DQ
    Bas's Avatar
    Nickname
    Bas (45)
    Join Date
    Aug 2007
    Location
    Raleigh, NC
    Posts
    6,959
    Visit Freq
    4.62 visits/week
    Threads
    354
    Classifieds
    When I need a glue with a long open time, I use Weldwood (made by DAP). This is a type of plastic resin glue, Ace Hardware sells it. It is water resistant and a good choice for Walnut because it's brown. Unlike yellow (PVA) glue, it has very little movement, so you're not likely to get any kind of "creep". Whether that's good or bad depends on the application. For a table top, it's probably good, but for chair joints some flexibility may actually be desirable. I'm not sure I would classify it as "brittle", but it is definitely harder.
    Bas.
    "I don't need it. I just want it."
    How to add a picture to your post
  5. #5
    DQ
    nelsone's Avatar
    Nickname
    Ed
    Join Date
    Apr 2006
    Location
    Mint Hill, NC
    Posts
    3,452
    Visit Freq
    1.42 visits/week
    Threads
    153
    Classifieds
    Hide glue is traditional for chairs because it is reversable making chair repairs easier. I have a bottle of Titebonds Liquid hide glue, but haven't used it enough to give an opinion on it. The one time I did use it, I had to warm it up to make it usable. I think it has a pretty long open time.
    Never take life seriously. Nobody gets out alive anyway !
  6. #6
    Nickname
    chester
    Join Date
    Dec 2009
    Location
    Asheboro, NC
    Posts
    19
    Visit Freq
    0.46 visits/week
    Threads
    Classifieds
    I thinkl Andy is right----good old titebond I has worked well for me.I'm just wondering why you need a long open time? I have glued up a lot of chairs and normally you can work out a system to do one section at a time (unless it is a Windsor type (those are dogs)).If you can imagine a chippendale style: I glue the back 2 legs with the back rail and stretcher and clamp them across. Then add the shoe, splat, and crest rail and clamp down from the top of the crest rail (use a clamping jig on the rail) to the bottom of the legs.Let this set up and clamp the 2 front legs and rail together.Let the 2 front legs set up and all that's left is the side rails and stretchers, which are easy.I don't mean to question your technique but thought I would share mine.Good Luck.
  7. #7
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,115
    Visit Freq
    6.50 visits/week
    Threads
    77
    Classifieds
    Another option I have used with intricate glue ups is polyurethane glue (i,e gorilla glue, etc). Altho I am not a big fan of it most times, the advantage is that you can spread the glue on one of the mating surfaces where it will remain soft for quite a while, and then just spritz the other with a water spray bottle right before you join them to activate the glue.
    The glue expansion factor may make it unsuitable for chairs, as is the strength loss over time, but it is another option.
    Practicing at practical woodworking
  8. #8
    DQ
    Nickname
    Howard
    Join Date
    Apr 2006
    Location
    Bolivia, NC
    Posts
    772
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Matt Furjanic View Post
    Why do you rule out epoxy. IMO, it is the best and safest choice for chairs. It's all we used for any chairs we made in the shop I was involved with. We built over a thousand chairs in ten years and did lots of testing of adhesives. Epoxy was best for the types of stresses that chairs are subjected to.
  9. #9
    DQ
    Skymaster's Avatar
    Nickname
    Jack (77)
    Join Date
    Aug 2009
    Location
    Zebulon, NC
    Posts
    1,734
    Visit Freq
    6.54 visits/week
    Threads
    Classifieds
    Titebond makes a slow set glue also, I just cant drag its name outta my tired brain tonight. You can google it
  10. #10
    Returning Member 4yanks's Avatar
    Nickname
    Willie
    Join Date
    Mar 2006
    Location
    Southern Pines, NC
    Posts
    481
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    I use liquid hide glue for complicated glue-ups that require a longer open time.
  11. #11
    Papa Red Senior User
    DQ
    red's Avatar
    Nickname
    Red
    Join Date
    Nov 2009
    Location
    Denver, NC
    Posts
    2,295
    Visit Freq
    4.92 visits/week
    Threads
    Classifieds
    Quote Originally Posted by 4yanks View Post
    Same here and it works great.
    Red
    Red
  12. #12
    Board of Directors
    Vice President
    Nickname
    Andy (59)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,674
    Visit Freq
    0.04 visits/week
    Threads
    329
    Classifieds
    Here is a good page on various options:
    http://www.woodworkingtips.com/etips/etip61.html
    I found that looking for the "how to slow hide glue" tips that I know I have seen somewhere, but reading the above page, the one that jumps out as simplest, easiest and (one of my favorite attributes) cheapest is this:
    You can thin Titebond yellow glue with about 5% water (one part water to twenty parts glue). One of the researchers at Franklin Industries (manufacturer of Titebond) told us that this will slow the set time about 50%. And he said that it won't have any significant effect on the strength of the glue joint as long as you don't mix in more than 5% water.
    I have not used the liquid hide glue, but have used the old "mix and use" for years. I know an instrument maker who does his assembly in a small room he heats up like a sauna and he leaves the wood in there for a couple of hours before he goes in and glues it up. Its open time is dictated by temperature.
  13. #13
    DQ
    Skymaster's Avatar
    Nickname
    Jack (77)
    Join Date
    Aug 2009
    Location
    Zebulon, NC
    Posts
    1,734
    Visit Freq
    6.54 visits/week
    Threads
    Classifieds
    Per my previous comment: the name is Titebond Extend
Similar Threads
  1. Long time lurker, first time poster
    By optimist in forum Who We Are
    Last Post: 01-17-2010, 04:01 PM
  2. Long time Lurker....
    By kirkpj01 in forum Who We Are
    Last Post: 01-27-2009, 10:50 PM
  3. Been away a long, long time ......
    By JimThomasson in forum User Announcements
    Last Post: 11-25-2007, 11:34 PM
  4. long time woodworker - new time member
    By Art Stratemeyer in forum Who We Are
    Last Post: 06-19-2007, 02:00 PM
  5. Long time no post
    By Travis in forum General Woodworking
    Last Post: 03-28-2007, 10:49 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
