Klingspor's Woodworking Shop (Banner Ad 1)
Results 1 to 3 of 3
  1. #1
    Board of Directors
    Events Director
    DQ
    Gotcha6's Avatar
    Nickname
    Join Date
    Jan 2007
    Location
    Ivan's Corner (Monroe), NC
    Posts
    4,546
    Visit Freq:
    6.96 visits/week
    Threads
    311
    Classifieds
    Lathe boring jig updated
    LOML wanted some wooden curtain rods for our front windows. Problem is, they only came 8' long & the window was 9' + to outside of casing. So I needed to splice 2 rods together to make the length. I'm using a splined rod, so it has to align fairly straight. Here's how I built a jig to line bore the rods for a dowel glue up:
    First, I took 4 pieces of PW 10" x 10" and cut a 'v' notch in the center that coincided with the height of the bed tube on my Craftsman lathe. I then cut a dado in each piece to spline them together & drilled leveling screw holes in the 4 base points.
    After that I squared the bases with the lathe bed & spotted register points on the bases. The upper supports were then registered to the base by placing the drill bit back into the thru hole drilled at the spindle center & sliding the v up to it. A notch was then made in the bottom of the upper support to clear the bed tube & the base v was lowered for larger stock.
    A slot and corresponding hole were drilled in each set using a 3/8" router bit in the drill press for height adjustment. Then a stretcher was added & here it is:
    To set up, I chucked the piece to be turned in and adjusted the headstock end to seat the piece in the 'v'. I then used 2 try square heads on one ruler to establish this height off the bed. Moving the tailstock end to the same height produced a seat for the piece that was in line with the centerline of the headstock axis. And we're ready to drill!
    I thank you for looking & hope you find this useful.
    Last edited by Gotcha6; 11-22-2009 at 08:39 PM. Reason: added info to complete post
    WHAT BOX?
  2. #2
    Board of Directors
    Events Director
    DQ
    Gotcha6's Avatar
    Nickname
    Join Date
    Jan 2007
    Location
    Posts
    4,546
    Visit Freq:
    6.96 visits/week
    Threads
    311
    Classifieds
    Re: Lathe boring jig updated
    bump
    Done
    WHAT BOX?
  3. #3
    DQ
    sawduster's Avatar
    Nickname
    Robert
    Join Date
    Oct 2007
    Location
    Youngsville, NC
    Posts
    2,552
    Visit Freq:
    2.69 visits/week
    Threads
    279
    Classifieds
    It is amazing what falls out of peoples' brains on this site
    I had to read it 3 times just to understand it ....and forget me thinking of something like that on my own
    Good work !
    ...~Robert~
    It ain't scrap till I say it's scrap !
Similar Threads
  1. Homemade Boring Bars
    By NCTurner in forum Woodturning
    Last Post: 09-27-2009, 09:28 PM
  2. I know, boring, but it's Xmas!
    By DavidF in forum Woodturning
    Last Post: 12-11-2008, 08:33 AM
  3. Draw-boring technique
    By Monty in forum General Woodworking
    Last Post: 03-16-2006, 10:52 PM
  4. Boring system in action
    By Handturnedbowls in forum User Announcements
    Last Post: 02-07-2006, 03:26 AM
  5. New download - Boring system drawings
    Last Post: 02-05-2006, 06:29 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
