Klingspor's Woodworking Shop (Locations) Ad #1
Results 1 to 8 of 8
  1. #1
    Returning Member
    Nickname
    Greg
    Join Date
    Mar 2008
    Location
    Newport, NC
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Calibrating table saws?
    I have a 12" Dewalt Chop Saw and 12 Craftsman Table Saw(old). Both saws will cut perfectly straight. Any attempt to change to a 45*, they will no longer cut straight. Any suggestions????
  2. #2
    Returning Member mshel's Avatar
    Nickname
    Michael Shelley (69)
    Join Date
    Jul 2005
    Location
    Wilson, NC
    Posts
    1,324
    Visit Freq
    0.23 visits/week
    Threads
    192
    Classifieds
    Re: Calibrating table saws?
    I am going to make an *** out of myself and assume that you mean "not straight" vertically. If this is the problem, I would venture a guess that your home stop (90 deg) one is out of adjustment. Don't know where it is located on your saw but mine (PM66) is near the front gear assy. on both sides of the rack.
    On the chop saw, it too has a stop for relocating the blade to 90 deg. Use a combo square to get the blade back to 90 deg. and then adjust the stop accordingly.
    Hope this helps.
    "Unless you try to do something beyond what you have already mastered, you will never grow." - Ralph Waldo Emerson
    http://carolina-heirlooms.ncwoodworker.net/
  3. #3
    Returning Member dpanda's Avatar
    Nickname
    Dan
    Join Date
    Nov 2008
    Location
    Holly Springs, NC
    Posts
    45
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    I'm not sure what you mean by not straight. Do you mean not straight when you are tilting the blade 45deg, or not straight making a 45 deg miter?
    My assumption is that your not getting a good 45 degree miter? This will happen to me on my Craftsmen table saw if I am using only a miter gauge set to 45 degrees. This happens because the wood is being dragged on the table. Because of the drag, the wood is slightly moving from its original location. This results in cut that is a not straight.
    A 45 degree table saw sled (jig), or a clamping miter gauge, will solve the problem.
    On a miter saw you can get a bad 45 degree miter because the wood will move slightly when making the cut. Hold the wood tightly or clamp if necessary.
    If you're cutting white baseboard trim, caulk will fix the bad cut
    Dan
  4. #4
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,147
    Visit Freq
    7.00 visits/week
    Threads
    713
    Classifieds
    Could you please explain the problem in more detail? Maybe add a picture or two of the "NOT straight" cut?
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  5. #5
    DQ
    walnutjerry's Avatar
    Nickname
    Jerry
    Join Date
    Feb 2006
    Location
    Salisbury, NC
    Posts
    1,596
    Visit Freq
    6.62 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Greg View Post
    I have an older 12" craftsman TS that will not go back to perfect 90 degrees if the blade has been tilted. It took a while to figure out why but the reason is build up of sawdust on the rack and pinion that moves the blade. If you clean it off it will return to the 90 degrees.
    Jerry
    We make a living by what we get...............We make a life by what we give
  6. #6
    DQ
    Gotcha6's Avatar
    Nickname
    Join Date
    Jan 2007
    Location
    Ivan's Corner (Monroe), NC
    Posts
    5,624
    Visit Freq
    6.42 visits/week
    Threads
    348
    Classifieds
    I have an older 12" craftsman tablesaw that will not go back to perfect 90 degrees if the blade has been tilted. It took a while to figure out why but the reason is build up of sawdust on the rack and pinion that moves the blade. If you clean it off it will return to the 90 degrees.
    You may just be better off not trusting the miter stop on your TS if you have to clean it off every time. If you only do 90 & 45 degree cuts most of the time you may want to think about keeping a speed square or drafting square close by to set the blade with. That's what I do.
    WHAT BOX?
  7. #7
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,147
    Visit Freq
    7.00 visits/week
    Threads
    713
    Classifieds
    I check mine with a square every time too. It only takes one big mess up to make you form habits like that.
    WWFD
  8. #8
    DQ
    Nickname
    Jerry
    Join Date
    Feb 2006
    Location
    Salisbury, NC
    Posts
    1,596
    Visit Freq
    6.62 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Gotcha6 View Post
    Thus the reason I updated my table saw and kept the old one for the daddo blades-----set it 90 to the table and leave it.
    Jerry
Similar Threads
  1. Powermatic table saws
    By Sanders Fine Woodworking in forum Power Tools and Their Use
    Last Post: 08-31-2008, 01:27 PM
  2. Hybrid (????) Table Saws
    By Howard Acheson in forum Power Tools and Their Use
    Last Post: 01-19-2008, 10:22 PM
  3. Slidng table table saws
    By vinson in forum Power Tools and Their Use
    Last Post: 07-24-2007, 05:32 PM
  4. cleaning table saws
    By lwhughes149 in forum General Woodworking
    Last Post: 03-19-2006, 11:12 PM
  5. Hybrid table saws
    By Big Daddy in forum Reviews
    Last Post: 12-12-2005, 05:48 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
