The Woodworking Source (Banner Ad 2)
Results 1 to 10 of 10
  1. #1
    User (Inactive) KenH's Avatar
    Nickname
    Ken (53)
    Join Date
    Jan 2009
    Location
    Waynesville, NC
    Posts
    Visit Freq:
    0.00 visits/week
    Threads
    Classifieds
    Segmented Bowl Project
    Someone asked for a tutorial on how I made one of my segmented bowl, so listed below are a lot of pictures and a few words on most of the steps in the process for this bowl (4” tall x 12.5” across).
    This picture is of my compound miter segment cutting sled. This sled is for a 12 segment bowl with a basic wall angle of 50°. The two key angles of this sled is the angle of the platform (9.57°) and the fence angle of 78.56°.
    Using the sled I cut the 12 main segments of cherry. For this bowl I selected walnut as the contrasting wood. These 12 strips are about 3/8 inch thick and a little wider that the ¾ inch thickness of the cherry segments.
    The first step in assembling the segments is to glue a walnut strip to each of the cherry segments. I do not clamp these, just apply some pressure and let the glue do the rest.
    After gluing up all of these pairs and letting them dry I begin assembling the segments of the bowl. The first step is to tape them all together.
    Once all of the segments are taped, I flip the group over to make sure everything lines up.
    Then I go back and apply glue in between each of the segments.
    Next I adjust the segments into the bowl shape. I attach a small C-clamp to the first and last segment so I can pull these two segments into place. Getting everything lined up at this point can be a little madding. Even with the tape the segments can move out of place, so at this point it is critical to make sure all the segments are in the right place or the whole thing could come apart while turning it latter.
    Once the glue has dried I flatten the bottom of the bowl using the plainer. Because this bowl is over 12 inches wide I use a sled to avoid the plainer guides.
    Next I prepare the bottom section by gluing it to the faceplate.
    After this dries I turn the bottom plate and then glue this to the bottom of the bowl. After that dries I flatten the top edge of the bowl on the lathe.
    I then cut and glue-up the top 12 segment walnut ring,
    Next I glue the bowl to the segment ring.
    Then it’s back to the lathe for a little turning, sanding and finishing.
    Resulting in the finished bowl.
    Thanks for reading.
  2. #2
    DQ
    rcflyer23's Avatar
    Nickname
    Kevin (37)
    Join Date
    Sep 2008
    Location
    Davidson, NC
    Posts
    1,578
    Visit Freq:
    3.12 visits/week
    Threads
    111
    Classifieds
    Re: Segmented Bowl Project
    Great how to... Thank you. One of these days I will attempt something like that... Very beautiful bowl by the way.
  3. #3
    Staff Advisor
    DQ
    Trent Mason's Avatar
    Nickname
    Trent Mason (33)
    Join Date
    Feb 2008
    Location
    Raleigh, NC
    Posts
    5,816
    Visit Freq:
    2.00 visits/week
    Threads
    205
    Classifieds
    Ken,
    Thanks so much for taking the time to document all of that and post it here. That is beautiful work and now it seems within the realm of my understanding.
    Trent
    Woodworking will teach you both patience and how to overcome adversity. The more patient you are, the less adversity you will have to overcome.
  4. #4
    DQ
    Tar Heel's Avatar
    Nickname
    Stuart
    Join Date
    Jan 2006
    Location
    Chapel Hill, NC
    Posts
    1,428
    Visit Freq:
    0.27 visits/week
    Threads
    178
    Classifieds
    Very interesting Ken. Thanks for posting that. It would appear that there are some critical cuts in the process and those angles have to be exact in order to get a successful end product. Good job.
  5. #5
    DQ
    RandyJ's Avatar
    Nickname
    Randy
    Join Date
    Jan 2006
    Location
    Macon, NC
    Posts
    2,411
    Visit Freq:
    5.92 visits/week
    Threads
    Classifieds
    Ken, THANK YOU so much for posting this thread. I have been curious about the whole segmented turning aspect and never had anyone explain it. It makes so much more sense now!
    That is a beautiful bowl.
    Thanks again for taking the time to post it.
    Randy
  6. #6
    DQ
    woodArtz's Avatar
    Nickname
    Bob
    Join Date
    May 2007
    Location
    Hillsborough, NC
    Posts
    2,778
    Visit Freq:
    2.23 visits/week
    Threads
    104
    Classifieds
    That's a great project Ken! Thanks for sharing.
    To everything... turn, turn, turn!
  7. #7
    Guest
    Very neat work, Ken -- glad you showed that one at last month's WNC Woodworkers Association meeting on jigs -- but as a non-turner, I must ask a question that I'm very surprised the turners in the crowd have not asked... "How do you calculate the angles for the segments"?
  8. #8
    User Dutchman's Avatar
    Nickname
    Buddy
    Join Date
    Dec 2005
    Location
    Jamestown, NC
    Posts
    337
    Visit Freq:
    0.77 visits/week
    Threads
    Classifieds
    Good looking bowl Ken.
    Those pictures tell the tale about how much work goes into a segmented bowl. Not quite the same as just chucking up a big ol hunk of wood.
  9. #9
    DQ
    ErnieM's Avatar
    Nickname
    Ernie (68)
    Join Date
    Jun 2008
    Location
    Chocowinity, NC
    Posts
    1,068
    Visit Freq:
    6.85 visits/week
    Threads
    142
    Classifieds
    Ken,
    This is fascinating and the end result is quite beautiful. Thanks for taking the time to document this build for us.
    One question: How did you build the sled with angles precise to the hundredth of an inch? And how did you calculate these angles in the first place (I guess that's two questions)?
    Ernie
    www.ernestmillerharpsichords.com
    "A lot of people are afraid of heights. Not me, I'm afraid of widths."
    -Steven Wright.
  10. #10
    Senior User gritz's Avatar
    Nickname
    Robert
    Join Date
    Jan 2009
    Location
    Holly Springs, GA
    Posts
    169
    Visit Freq:
    4.85 visits/week
    Threads
    Classifieds
    Thank's for the insight. I will give this a try.
Similar Threads
  1. segmented "bowl"
    By Sully in forum General Woodworking
    Last Post: 12-31-2008, 09:25 PM
  2. Elevated Dog Bowl Project
    By BiggE98 in forum General Woodworking
    Last Post: 11-30-2008, 11:35 AM
  3. First Segmented Pen
    By ChrisMathes in forum Woodturning
    Last Post: 08-30-2006, 11:08 AM
  4. Segmented bowl
    By cskipper in forum Woodturning
    Last Post: 07-26-2006, 08:32 PM
  5. First segmented bowl
    By NZAPP1 in forum Woodturning
    Last Post: 06-22-2006, 09:15 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
