Rob's instructions for adding links.
"I'll be happy to add it, but you can do it easily yourself -- click on Links Library and you will get a listing of the Library Categories. (I usually get the website address stored in the clipboard first so I can just paste it in when I need to enter it). This one should fit into the Woodworking References category. Click on that category, or if you are uncertain what category to use, click on To be Categorized Later and it will be deposited in the appropriate gallery when the link is moderated. Verify in the list that you are not duplicating an existing link and click on Submit a Link in the header. Fill in the appropriate info (this is where you paste the web address from the clipboard) and submit it. All new links are moderated, so as soon as I login the next time, I will review and approve it. I usually try to check the Libraries twice a day for new additions. So, here's you chance; go for it as it is a good link!"
I found these instructions to be easy to follow and encourage others to try it
