05-15-2008, 08:32 PM
#1 |
Name: RAS City: Pikeville State: NC County: Wayne Join Date: Dec 2005 Avg Visit Freq/Week = 6.88 over 180 days | I got my vacuum pump finished
Then I run into a problem, does anyone know what the threads are on the outboard side of the headstock spindle, on the HF lathe?
I found out they are monkey threads (LH)
I have metric tap and die, I also have SAE tap and die, but I dont have any LH tap and die  never had any use for any.
If I know what they are then maybe I can buy 1 die some place
__________________
Earl "If you want to learn how to build a house, build a house.
Don't ask anybody, just build a house." "Oland tool, better than a bowl gouge, a lot cheaper to make." Darrell Feltmate around the woods |
05-15-2008, 08:52 PM
#2 |
Name: Dennis City: Ivan's Corner (Monroe) State: NC County: Union Join Date: Jan 2007 Avg Visit Freq/Week = 6.92 over 180 days | You may have a REAL problem finding a LH die. I frequent machine tool supplies catalogs from companies such as WT Tool. They carry a good many taps & dies. The only LH die they list is a 14mm x 1.0. That sounds a bit small for a lathe spindle, even a HF, being slightly under 5/8". Good luck. |
05-15-2008, 09:23 PM
#3 |
Name: RAS City: Pikeville State: NC County: Wayne Join Date: Dec 2005 Avg Visit Freq/Week = 6.88 over 180 days | Originally Posted by Gotcha6 You may have a REAL problem finding a LH die. I frequent machine tool supplies catalogs from companies such as WT Tool. They carry a good many taps & dies. The only LH die they list is a 14mm x 1.0. That sounds a bit small for a lathe spindle, even a HF, being slightly under 5/8". Good luck.
Its the inside threads on the outboard side, close to 7/16 somewhere in that area, and they might be metric
__________________
05-15-2008, 10:28 PM
#4 |
Name: Dennis City: Ivan's Corner (Monroe) State: NC County: Union Join Date: Jan 2007 Avg Visit Freq/Week = 6.92 over 180 days | Here's a listng to their LH TAP page. They have a large inventory of English thread taps. Just no LH dies. http://tool.wttool.com/search?p=Q&ts...=search&w=taps |
05-15-2008, 10:33 PM
#5 |
Name: Dennis City: Ivan's Corner (Monroe) State: NC County: Union Join Date: Jan 2007 Avg Visit Freq/Week = 6.92 over 180 days | |
05-15-2008, 10:58 PM
#6 | | Administrator
Name: Chad City: Hookerton State: NC County: Greene Join Date: Feb 2006 Age: 54 Avg Visit Freq/Week = 6.96 over 180 days | Earl;
Which HF lathe is it?
If it is bigger than a 7/16 it will be a M12, M10 if smaller..  I can turn you one with the threads you need.
I will need to see it, I work in Wilson 301 and 117, I can stop by Sunday after the lumber run, and look at it. I have thread pitch gages to check the pitch..
Up to you..
__________________
Chad Pen turning is fast and fun!
It is highly addictive!
All your free time you once had will become a thing of the past!! And Down The Dark Side Of Woodworking You! Will!
Goooooo!!  |
05-15-2008, 11:06 PM
#7 |
Name: jeff... City: Stovall State: NC County: Granville Join Date: Mar 2006 Avg Visit Freq/Week = 6.81 over 180 days | What in the world is an M10 or M12 - some kind of small firecracker - has to be cause it's less than an M80 .gif)
__________________ "Do, or do not. There is no 'try'." -- Jedi Master Yoda |
05-15-2008, 11:29 PM
#8 | | Administrator
__________________
Goooooo!!  |
05-15-2008, 11:37 PM
#9 |
Name: jeff... City: Stovall State: NC County: Granville Join Date: Mar 2006 Avg Visit Freq/Week = 6.81 over 180 days | Originally Posted by toolman Hey if it's not 3/8" copper tubing I'm lost - ya know .gif)
05-15-2008, 11:40 PM
#10 | | Administrator
__________________
Goooooo!!  |
05-15-2008, 11:42 PM
#11 |
Name: Bruce City: Apex State: NC County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 6.26 over 180 days | Originally Posted by jeff... Hey if it's not 3/8" copper tubing I'm lost - ya know .gif) And in the refrigeration industry what you call 3/8" is called 1/4" instead. |
05-16-2008, 12:01 AM
#12 |
Name: jeff... City: Stovall State: NC County: Granville Join Date: Mar 2006 Avg Visit Freq/Week = 6.81 over 180 days | Originally Posted by junquecol And in the refrigeration industry what you call 3/8" is called 1/4" instead. Does 1/4" work better than 3/8"? You got me thinking...
05-16-2008, 10:58 PM
#13 |
Name: Bruce City: Apex State: NC County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 6.26 over 180 days | [quote=jeff...;1520 You got me thinking...  [/quote]Jeff, how many times do we have to warn you about thinking? Bruce |
05-16-2008, 11:59 PM
#14 |
Name: jeff... City: Stovall State: NC County: Granville Join Date: Mar 2006 Avg Visit Freq/Week = 6.81 over 180 days | Originally Posted by junquecol Jeff, how many times do we have to warn you about thinking? Bruce Sorry should have known better - stick with what works
Posting Rules
Members: 2,315
Threads: 17,273
2nd Top Poster: jeff... (6,592) | | Welcome to our newest member, kenger22 | |
