North Carolina Woodworker
Go Back   North Carolina Woodworker > Other > Other WW or Site related Topics
Notices
Other WW or Site related Topics This is where you should post topics that are woodworking or site related, but there doesn't seem to be a forum that is correct.
» Announcements
Raffle is now closed. Raffle numbers have been Email Please Read . Drawing 12:30 pm Thursday 1/8/09 (GOOD LUCK)!!
1st Qtr
Donation Drive Please Donate! Please Read!
Featured Photos
by Shamrock
26251 photos
9608 comments
by DeCe
26251 photos
9608 comments
by Truefire
135 photos
7 comments
by farmerbw
26251 photos
9608 comments
» Online Users: 25
1 members and 24 guests
MIKE NOAH
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 04-28-2008, 05:19 PM   #1
meika123's Avatar
City: Advance
State: NC
County: Davie
Threads: 48
Avg Visit Freq/Week
= 0.23 over 180 days
Got a question which may or may not be STUPID, but I'm gonna ask it anyway. On the Clear Vue installation instructions, it says "When hooking the impeller to the motor, to tighten the nuts to 5 foot lbs. each." How do I go about doing this with a female hexagonal nut?
Or am I trying to get too technical?
__________________
Dave in NC
"A man's gotta know his limitations"!
Show Printable Version Email this Page   Quote this post in a PM to meika123
Old 04-28-2008, 05:49 PM   #2
ptt49er's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 46
Avg Visit Freq/Week
= 6.84 over 180 days
Get a torque wrench
I wouldn't think it would make a difference if it's a nut or a bolt.
Best of luck!
__________________
~Phillip
"Okay Hunny, so my hobby is collecting other hobbies. Atleast I'm well rounded!"
Show Printable Version Email this Page   Quote this post in a PM to ptt49er
Old 04-28-2008, 06:33 PM   #3
City: Pfafftown
State: NC
County: Forsyth
Threads: 2
Avg Visit Freq/Week
Dave,
I have a torque wrench and a few hex bit sockets. I can't remember the size req'd. let me know if I can help.
Show Printable Version Email this Page   Quote this post in a PM to MIKE NOAH
Old 04-28-2008, 06:42 PM   #4
ptt49er's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 46
Avg Visit Freq/Week
Originally Posted by MIKE NOAH View Post
Dave,
Yeah, the bits would help too...I totally had a mind fart when you said female...
I've gotten a few bits from the auto parts store for stuff like that.
Best of luck!
__________________
~Phillip
Old 04-28-2008, 06:50 PM   #5
meika123's Avatar
City: Advance
State: NC
County: Davie
Threads: 48
Avg Visit Freq/Week
"NUT". I meant "BOLT". "BOLT". Told ya it was stupid!!!
__________________
Dave in NC
Old 04-28-2008, 06:53 PM   #6
Jim Murphy's Avatar
Name: Fern HollowMan
City: Franklinton
State: NC
County: Granville
Threads: 80
Avg Visit Freq/Week
= 5.25 over 180 days
Amazingly enough, I used 7.5 pounds of free weights placed on the impeller blades while the shaft was horizontal. The distance from the screws to the end of the blades is (IIRC) about 8". That means you need 7.5 pounds operating on the 8" to achieve 5 ft/lbs of torque. I held the driver secure and started out using the 5# weights, allowing the weight to pull down the blade as I held the driver tight. Worked around the shaft, then added a 2.5# weight and did it all over again. My impeller hasn't hit the ground (yet). Think about it, it makes sense.
__________________
...I have finally reached the age where my wants and needs have regressed to my early childhood:
---I want everything and need nothing.
Show Printable Version Email this Page   Quote this post in a PM to Jim Murphy
Old 04-28-2008, 07:44 PM   #7
Vice-President
Libraries Administrator
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 119
Avg Visit Freq/Week
Just so you get the nomenclature correct, they are socket head cap screws, and they should be torqued down with a 5/32" hex bit socket (e.g., see this set from Sears; I bought my set at the Blue Borg). I used a 1/2" drive torque wrench that I've had for more than 40 years with a 1/2" to 3/8" drive adapter on it. First, make certain the shaft key is in place and that the impeller clears the blower housing by at least 1/4". What is critically important is to insert the cap screws into the clearance holes in the outer split bushing collar (they are unthreaded) and screw them into the threaded holes in the main bushing itself. Tighten each a little at a time until they are snug and then torque them to the required 5 ft-lbs. This pulls the tapered split outer collar into the main bushing and tightens it around the motor shaft. The other set of threaded holes are used when you want to remove the impeller from the motor shaft -- move the cap screws to those holes and they push the bushing halves apart. Hope this helps.
__________________
Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
Show Printable Version Email this Page   Quote this post in a PM to McRabbet
Old 04-28-2008, 10:15 PM   #8
meika123's Avatar
City: Advance
State: NC
County: Davie
Threads: 48
Avg Visit Freq/Week
I have been that far already. Everything else is hooked up, tightened up, and otherwise assembled.
All I lack is: from an oversight on my part, I failed to cut a rabbet around the edge of the MDF where it fits into the blower housing. I have to figure a way to do this, then I will be ready to mount the impeller into it, and fire the "Sucker" up. Boy, am I apprehensive, and full of anticipation at the same time. WHEW!!!!
__________________
Dave in NC
Old 04-29-2008, 06:02 PM   #9
meika123's Avatar
City: Advance
State: NC
County: Davie
Threads: 48
Avg Visit Freq/Week
All I lack is: from an oversight on my part, I failed to cut a rabbet around the edge of the MDF where it fits into the blower housing. I have to figure a way to do this.
Well, I figured out a way to do this today, and it worked rather well. Got it fitted, and made the hold-down clips for the impeller and motor mount. Installed the impeller to the motor shaft and squared everything up.
Now, I've gotta transport the thing home to its permanent location and start hooking it up.
Been a job, but a lot of satisfaction.
__________________
Dave in NC
Closed Thread
question
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,315
Threads: 17,273
2nd Top Poster: jeff... (6,592)
Welcome to our newest member, kenger22
» Today's Birthdays
fivestring (50)
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
