North Carolina Woodworker
Go Back   North Carolina Woodworker > Other > Off Topic
Notices
Off Topic Our new off topic forum. This is the place to discuss non-woodworking or non-site related topics. Be advised that the posting rules for this forum are same as all other forums.
» Announcements
Raffle is now closed. Raffle numbers have been Email Please Read . Drawing 12:30 pm Thursday 1/8/09 (GOOD LUCK)!!
1st Qtr
Donation Drive Please Donate! Please Read!
Featured Photos
by bluewing92
26251 photos
9608 comments
by Pop
26251 photos
9608 comments
by bdjessup
26251 photos
9608 comments
by MrAudio815
26251 photos
9608 comments
» Online Users: 40
8 members and 32 guests
ACobra289 , erasmussen , Greybeard , HillsboroughWW , jeff... , jglord , newtonc , Sealeveler
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 04-25-2008, 12:34 AM   #1
jeff...'s Avatar
City: Stovall
State: NC
County: Granville
Threads: 471
Avg Visit Freq/Week
= 6.81 over 180 days
I working on an older style tractor that "had" a old style generator / voltage regulator - now it has a 70's GM Alternator. One problem - once started it won't turn off by the key - I have to choke it to get it to shut off. Guess I got something wired up wrong or need another part??? I was hoping someone could help me figure out what I did wrong. Here's how I got the thing wired. It starts and runs just fine - just won't shut off by the key - it's crazy .
Thanks
__________________
"Do, or do not. There is no 'try'." -- Jedi Master Yoda
Show Printable Version Email this Page   Quote this post in a PM to jeff...
Old 04-25-2008, 01:43 AM   #2
scsmith42's Avatar
City: New Hill
State: NC
County: Chatham
Threads: 34
Avg Visit Freq/Week
= 5.44 over 180 days
Jeff, your problem is that your ballast resister is wired incorrectly. Rather than being fed by the alternator, it should be fed by the "run" side of the ignition switch.
The ballast resistor by-pass circuit is in the correct location.
Regards,
Show Printable Version Email this Page   Quote this post in a PM to scsmith42
Old 04-25-2008, 05:47 AM   #3
Administrator
toolman's Avatar
City: Hookerton
State: NC
County: Greene
Threads: 42
Avg Visit Freq/Week
= 6.96 over 180 days
Man I just love this site!! Scott Your the Man!!
__________________
Chad
Pen turning is fast and fun!
It is highly addictive!
All your free time you once had will become a thing of the past!!
And Down The Dark Side Of Woodworking You! Will!
ooooo!!
Show Printable Version Email this Page   Quote this post in a PM to toolman
Old 04-25-2008, 02:08 PM   #4
jeff...'s Avatar
City: Stovall
State: NC
County: Granville
Threads: 471
Avg Visit Freq/Week
Scott is the man !!!
Scott you mean like this? Looks like I'll need to get another ignition switch... one with a stop, run and start. I can see where the other switch would not break the circuit with juice coming off the alternator to feed the coil - hence the reason it kept running even with the key off...
Thanks
__________________
Old 04-25-2008, 02:23 PM   #5
scsmith42's Avatar
City: New Hill
State: NC
County: Chatham
Threads: 34
Avg Visit Freq/Week
Jeff, I'm not sure about where wire number 1 goes to from the alternator, but I do know that you typically have two circuits to the coil. The "start" circuit either comes off of the starter or "start" post on the switch, and provides a full 12 volts to the coil for a hotter spark during starting.
The "run" circuit is fed from the "on" side of the ignition switch and goes through the resistor. It's function is to provide a slightly lower voltage to the coil while the motor is running so that the points don't burn out.
Rather than adding a new key switch, you could wire a starter button in line in-between the battery and the starter solenoid, and move your resistor and alternator circuit over to the "run" side of the key switch.
SS
Old 04-25-2008, 02:57 PM   #6
jeff...'s Avatar
City: Stovall
State: NC
County: Granville
Threads: 471
Avg Visit Freq/Week
SS
Scott thanks - After reading up a little bit on the Delco SI - seems that #1 is a feild wire and is mainly used to light up an idiot light when amperage is low. I really should disconnect that from the Ballast and run it to the idiot light. I'll draw up a new diagram - I already have a 3 post ford ign switch, with the plymouth ballest resistor and Chevy alternator it should fit right in
I hope this one will work - I'll have some fun playing with wires tomorrow.
What you think Scott?
Thanks again man!!!
__________________
Old 04-25-2008, 05:45 PM   #7
Joe Scharle's Avatar
City: Holly Springs
State: NC
County: Wake
Threads: 125
Avg Visit Freq/Week
= 7.04 over 180 days
Not Scott, but as per your first dwg I can't see how the starter drops out. Last dwg looks good. I only mention this in case your first dwg is incorrect as to how it's actually wired.
Show Printable Version Email this Page   Quote this post in a PM to Joe Scharle
Old 04-25-2008, 09:31 PM   #8
City: Greensboro
State: NC
County: Guilford
Threads: 57
Avg Visit Freq/Week
= 2.99 over 180 days
Jeff,
I have a '57 Ford 641 Workhorse tractor that my Dad and I have been refurbishing for the past couple of years. There is a web site called www.Yesterdaystractors.com where I go to get help on anything tractor. I hope this helps in the future.
Show Printable Version Email this Page   Quote this post in a PM to b4man
Old 04-25-2008, 10:37 PM   #9
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Threads: 208
Avg Visit Freq/Week
= 6.73 over 180 days
Jeff- we can put one of my circuit boards in the truck, then fuel it with some high grade rocket fuel, and you'll be good to go!
Show Printable Version Email this Page   Quote this post in a PM to Alan in Little Washington
Old 04-26-2008, 12:49 AM   #10
jeff...'s Avatar
City: Stovall
State: NC
County: Granville
Threads: 471
Avg Visit Freq/Week
Well here is what worked... Ran everything with 10Ga wire except the Battery and starter cables which are 2Ga. I drew it like I ran it instead of a lined diagan for easy reading... In the previous diagram, the light stayed on even with the key off I guess for nothing more than to drain the battery... Anyways thanks everyone for your help, I really appreciate it. If your after an old generator conversion to GM Alternator, with key switch, coil and points ignition this one works. It uses the latest technology, early 70's 63 Amp GM 10SI Alternator, 69 Chrysler Ballast Resistor I think 15 ohms and a early 70's Ford 4 post starter Solenoid - I'm so with the times aren't I? (NOT)
__________________
Old 04-26-2008, 09:54 PM   #11
jeff...'s Avatar
City: Stovall
State: NC
County: Granville
Threads: 471
Avg Visit Freq/Week
Couple of things I wanted to point out - just in case anyone wants to use this diagram for conversion.
* I can tell when the battery is not fully charged - the light comes on while the engine is running and the Amp Meter shows only about +2 amps - Once the battery is charged by excess coil voltage, the light goes off and the amp meter shows anywhere from + 10 ~ +50 depending on the motor speed. I thought I may have picked up a bad alternator, so I took it back to where I bought it and it tested fine. I'm still kind of puzzled by this behavior, it's odd... but honestly I think this is because I have a bad battery - I'll have it tested and replace it if it's bad - Think of light that comes from the alternator field (1) wire as the "battery idiot light" that's in your car or truck... It's telling me that my battery is bad
* If the amp meter reads + while starting the motor switch the wires around on the Amp meter - it's wired backwards... No biggie, the amp meter should read -- when cranking the motor.
* What's really cool about this is the two wires that run to the ballast one from the solenoid and one from I (ignition) - you can pull the I wire form the ballast, crank it and it will try to start but once you let the key spring back it dies because the alternator is not supplying voltage to the coil. Unhook the solenoid wire and it cranks all day long but won't start. - pretty cool way to trouble shoot anyways... Scott explained how the wires work before and after the ballast - Thanks Scott... It was easy for me to figure out that everything was working by your explanation...
* Ground the alternator to the negative side of the battery. There's a big lug that's not marked on the backside of the alternator - I used the lug and 10ga wire home run to the negative side of the battery - worked like a champ.
Anyways I learned plenty doing this conversion - I'm going to throw in a volt meter after I pick one up from Nappa. This was a very enjoyable and dirty way to spend the day.
Thanks
__________________
Closed Thread
diagram , wiring
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Wiring Inspection TBone Off Topic 16 04-16-2008 10:36 PM
Workshop Wiring rick7938 Workshops 10 07-29-2007 10:26 PM
Wiring: 3/4 EMT capacity snojcb Power Tools and Their Use 8 12-01-2006 09:49 AM
Shop Wiring Advice mtrager General Woodworking 11 10-15-2006 08:51 PM
Wiring a 3 way switch chris99z71 Old Off Topic Forums 5 08-23-2006 12:55 PM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,315
Threads: 17,273
2nd Top Poster: jeff... (6,591)
Welcome to our newest member, kenger22
» Today's Birthdays
fivestring (50)
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
