North Carolina Woodworker
Go Back   North Carolina Woodworker > Other > Off Topic
Notices
Off Topic Our new off topic forum. This is the place to discuss non-woodworking or non-site related topics. Be advised that the posting rules for this forum are same as all other forums.
» Announcements
Raffle is now closed. Raffle numbers have been Email Please Read . Drawing 12:30 pm Thursday 1/8/09 (GOOD LUCK)!!
1st Qtr
Donation Drive Please Donate! Please Read!
Featured Photos
by jstraw
26251 photos
9608 comments
by owen299
26251 photos
9608 comments
by JRD
26251 photos
9608 comments
by AndyBarnhart
26251 photos
9608 comments
» Online Users: 39
7 members and 32 guests
Alan in Little Washington , bitbight , Greybeard , kanguy8 , NCTurner , rcflyer23 , Tar Heel
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 03-28-2008, 11:14 PM   #1
jeff...'s Avatar
City: Stovall
State: NC
County: Granville
Threads: 471
Avg Visit Freq/Week
= 6.81 over 180 days
Need to secure some 12ga copper wire to closely spaced 1/8 thick stainless steel plates. I need a good small sized mechanical fastener and I don't want some big lug sticking off the stainless, any ideas?
BTW Alan, I'm working on some rocket fuel for the green rocket...
Thanks
Show Printable Version Email this Page   Quote this post in a PM to jeff...
Old 03-28-2008, 11:23 PM   #2
BumoutBob's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 16
Avg Visit Freq/Week
= 0.54 over 180 days
Jeff, need more information to be able to help. How about pictures?
Show Printable Version Email this Page   Quote this post in a PM to BumoutBob
Old 03-28-2008, 11:31 PM   #3
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Threads: 208
Avg Visit Freq/Week
= 6.73 over 180 days
Whatch makin? An electrohypertransdialectric detection grid?
Show Printable Version Email this Page   Quote this post in a PM to Alan in Little Washington
Old 03-28-2008, 11:44 PM   #4
BumoutBob's Avatar
State: NC
County: Henderson
Threads: 16
Avg Visit Freq/Week
Drill hole the same size of wire, silver solder in place. 95/5 Soft silver solder works, with the right flux----needs to have some hydrocloric acid in it. ie flux for SS. Use a propane torch, Map gas to hot. if the wire is insulated you may burn it. Be better if you could slide it away from solder joint until it cools. Heat sinking the wire near the solder joint might save the insulation. This will also make it harder to heat the solder joint.
Old 03-29-2008, 12:11 AM   #5
jeff...'s Avatar
City: Stovall
State: NC
County: Granville
Threads: 471
Avg Visit Freq/Week
Bob I did almost exactly that - but used a torch to heat up the SS it worked for a while but eventually what I'm doing, eat up the silver solder. I need a good small mechanical fastener preferably SS.
Here's a few pics of the plates - they spaced with 1/16" nylon and also held together with nylon washers, nuts and bolts. Positive charge on one plate, negative on the other with two neutrals in between. Plate spacing is important hence why I need a small fastener.
Alan no not that but lets just say I might just come up with something to fuel the green rocket.
Thanks
Old 03-29-2008, 12:23 AM   #6
BumoutBob's Avatar
State: NC
County: Henderson
Threads: 16
Avg Visit Freq/Week
Jeff, that connection looks like it heated up and is not making a good contact. There are crimp on connectors(lugs) out there made by AMP or Thomas & Betts These are the ones that you find in the auto stores. The ones for #12 wire are color coded yellow. They come open ended( spade) and ring tongue (closed holes). It appears that you might be able to attach a lug with an #8 or #10 screw there.
If you don't know the lugs I'm talking about, go the Advance Automotive and look around.
Old 03-29-2008, 12:51 AM   #7
jeff...'s Avatar
City: Stovall
State: NC
County: Granville
Threads: 471
Avg Visit Freq/Week
Bob thanks, I'll swing by Nappa or Advanced and see if I can find it. Your right the wire did heat up and after a while lost it's connection and it's ability to conduct current because the silver solder failed.
Thanks
Old 03-29-2008, 09:39 AM   #8
Mike Davis's Avatar
City: Westfield
State: NC
County: Stokes
Threads: 80
Avg Visit Freq/Week
= 6.88 over 180 days
Looks to me like a sloppy silver solder joint.
Show Printable Version Email this Page   Quote this post in a PM to Mike Davis
Old 03-29-2008, 03:47 PM   #9
City: Washington
State: NC
County: Beaufort
Threads: 208
Avg Visit Freq/Week
The weather is getting nice- time to get the cat and the "Storpedo" out and ready to go.
Crimp type (can also be soldered) ring tongue terminals available at auto parts stores and Radio Crap might be the way to go. Remove the insulator if equipped and use stainless steel pop rivets to attach them to the plates. Partially grind off and flatten the nub side of the rivet if you need the clearance.
Closed Thread
electrical
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Electrical question lwhughes149 General Woodworking 3 01-03-2007 02:52 PM
Electrical question lwhughes149 General Woodworking 7 11-12-2006 05:55 PM
Another Electrical Question mtrager General Woodworking 5 10-18-2006 05:31 PM
Electrical Help DaveT Old Off Topic Forums 8 08-28-2006 01:19 PM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,315
Threads: 17,273
2nd Top Poster: jeff... (6,591)
Welcome to our newest member, kenger22
» Today's Birthdays
fivestring (50)
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
