North Carolina Woodworker
Changes to DQ as of 12/1/2008 Very important that you read
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Workshops
Notices
Workshops Tell us about your workshop, or get help with workshop planning and setup
» Announcements
Everyone Log on at 9:00PM Thursday December 4th to set a members online record.
Featured Photos
by rbdoby
508 photos
12 comments
by Vanilla Gorilla
24836 photos
9957 comments
by SteveColes
30 photos
2 comments
by striker
24836 photos
9957 comments
Closed Thread
Old 07-20-2007, 08:31 PM   #1
LeftyTom's Avatar
City: Yadkinville
State: NC
County: Yadkin
Threads: 146
Avg Visit Freq/Week
= 6.53 over 30 days
Question
What is a good thickness for a benchtop I want to drill for holdfast's?
I have one table made out of 2x6's which could be used. Plenty room beneath the top for the 8" holdfast's. But it is 2'x2', so it is only useful for working with small pieces.
My other tables are 2'x4' or 5', but are recycled pallets. Most have a later of 1"x6" over the pallet (yes, not the smoothest of table tops, but I didn't have woodguy disease when I cobbed them together).
Or should I plan on building a bigger, better, super-dyna-whopping table?
__________________
The Tao of Tom: Be good to your pet(s). Invest in good Karma.
Show Printable Version Email this Page   Quote this post in a PM to LeftyTom
Old 07-20-2007, 08:57 PM   #2
LeftyTom's Avatar
City: Yadkinville
State: NC
County: Yadkin
Threads: 146
Avg Visit Freq/Week
= 6.53 over 30 days
I wouldn't mind building a super-dyna-whopping workbench, if only I could get the materials for free
Heaven help me, because if I build a suitable workbench, I'm jonesing to make a shoulder vise. If only my ability would rise to the level of my desire.
__________________
Old 07-20-2007, 09:06 PM   #3
jmauldin's Avatar
City: Mount Airy
State: NC
County: Surry
Threads: 26
Avg Visit Freq/Week
= 4.67 over 30 days
My workbench top is 31/2" luguna with a tail vise. I have holes for dogs down both sides, plus I have drilled 3/4" holes down the center so I can use the iron bench dogs. I have never had any problem with swag and it stays perfectly flat. I have the bench legs anchored in concrete. That way it doesn't move. I also have a 4'x6' workbench that I rescued from an old factory. It has a 4" hard maple top and massive cast iron legs. However, it is not as flat at the other, however. I just haven't taken the time to level it.
Jim in Mayberry
Show Printable Version Email this Page   Quote this post in a PM to jmauldin
Old 07-20-2007, 09:53 PM   #4
City: Wilmington
State: NC
County: New Hanover
Threads: 15
Avg Visit Freq/Week
= 3.97 over 30 days
Tom,
I believe I made my workbench top roughly 2 3/4 thick. IMO, having a good level surface is job one. I think building a good workbench would be an enjoyable task, one you can take pride in and inspire you to do high quality work on in the future. It doesn't have to be the largest work bench, just sized to the work you intend on doing.
Good Luck with your bench,
Stephen
__________________
STRIKER
Show Printable Version Email this Page   Quote this post in a PM to striker
Old 07-21-2007, 09:21 AM   #5
pcooper's Avatar
City: Maiden
State: NC
County: Catawba
Threads: 12
Avg Visit Freq/Week
= 6.53 over 30 days
The bench I made has a thicker top where the bench dogs go, and some thinner where the back of the bench is (a place where only weight of material is). The bench dog area is 3 1/2" thick, the rear is only 2" thick. The bigger the bench, the more weight, the less likely you'll be chasing it across the floor when you need to do things like hand planing. If you don't have room for a big whopping bench, build as much as you can as thick as you can, then grow into another one later. I collected stuff for years before being able to build the bench I have now. I used the bench style that Norm Abram built for almost 15 years before building my new one, and it did fine except it was too light and I could push it around while using a hand plane or belt sander.
__________________
Today a pile of wood, tomorrow a pile of sawdust......
Show Printable Version Email this Page   Quote this post in a PM to pcooper
Old 07-22-2007, 11:25 AM   #6
LeftyTom's Avatar
City: Yadkinville
State: NC
County: Yadkin
Threads: 146
Avg Visit Freq/Week
= 6.53 over 30 days
Thanks for the replies. The tables I have are on simple 2x4 legs, so I should think of building a bench with sturdier legs (2x6's or stacked 2x4's) to support the weight of the top. I do have the lumber I removed in my deck re-do, but I gotta dig up that list of what is there. Through a good guess while "legging" the pallets, I have found that a 28" table height works best for me.
__________________
Old 07-23-2007, 11:03 PM   #7
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 47
Avg Visit Freq/Week
= 6.30 over 30 days
As for the base, I would think that stacked 2 x's would give deeper tennons and reduce the possibility of the base "racking". I used Monty's design for mine, (altho I used SYP instead of hard maple), and it is working very well. If you are not going to put a cabinet in the bottom, I would still go with a top and bottom rail, as opposed to just a wide center rail, as it also will reduce the racking by giving lengthwise support to the top and bottom of the legs as opposed to just the center.
2 x 4s will support the weight (they hold up a house's roof), but won't do much to prevent lateral or longitudinal movement as the top is stressed with side-to-side or end-to-end movement (whichever direction the narrow width is facing). If the base is also supported by a cabinet, etc,2 x 4s provide an excellent frame, with the cabinet sides providing the torsional strength.
__________________
My only regret in life is that I did not listen more and talk less
Show Printable Version Email this Page   Quote this post in a PM to Gofor
Closed Thread
thickness , top , workbench
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Does the thickness of wood help stability? macdaddy Wood 3 09-21-2006 04:33 PM
Jewelry box sides thickness ???? DaveO General Woodworking 14 07-01-2006 12:30 AM
Thickness gauge for planer Greybeard General Woodworking 4 06-29-2006 12:08 PM
Thickness Planer Question Matt Power Tools and Their Use 18 02-27-2006 09:19 PM
Time on a thickness sander Richgod Where Can I Find, Buy or Sell 8 01-12-2006 11:29 PM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,133
Threads: 16,361
2nd Top Poster: jeff... (6,350)
Welcome to our newest member, MarkP
» Today's Birthdays
cfelts (66)
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
