» Online Users: 74 | | 31 members and 43 guests | | Bas , bluthart , clowman , DaveD , DaveO , dino drosas , dpanda , Dudelive , Glenn Hudson , Glennbear , James Davis , jeff... , John Jankowski , Kyle , Marcus Masencup , MarkP , mbeach , MIKE NOAH , MikeF , MikeH , NCTurner , Outa Square , Ralrick , rsitzejr , striker , toolman , Travis Porter , Trent Mason , wchipper , woodlaker2 , yrsears | | Most users ever online was 180, 04-22-2008 at 12:18 AM. |  |
01-06-2008, 04:24 PM
#1 |
Name: Robert City: Matthews State: NC County: Union Join Date: Feb 2007 Avg Visit Freq/Week = 5.60 over 180 days | As a follow-up to Bas's "absolutely baffling" post here is the super sized trashcan separator I've just completed. The collector is a 3hp, 4 bag Delta. So far it works pretty well. I'm sure it will require some tweaking as I go along. |
01-06-2008, 04:47 PM
#2 | | Asst. Webmaster
Name: Bas City: Cary State: NC County: Wake Join Date: Aug 2007 Age: 35 Avg Visit Freq/Week = 6.96 over 180 days | Impressive! Don't forget you have to empty the can once in a while too
How is the 'scrubbing' with a 3HP DC, i.e. how much of the sawdust stays in the can vs. being pulled through? And is that 6" pipe?
__________________
Bas.
I don't need it. I just want it.
01-06-2008, 05:28 PM
#3 |
Name: Robert City: Matthews State: NC County: Union Join Date: Feb 2007 Avg Visit Freq/Week = 5.60 over 180 days | Bas,
It is 6" pipe and that's the reason for a bigger can. Both of your questions is answered with what direction the 90 degree elbow is turned. The scrubbing as you call it is the cyclonic action which is desired up to a degree. With the elbow turned to fire the chips into the side with some force there is little blow by. I have emptied it several times (planed 250 bdft of lumber since Fri. at lunch) and yes it is heavy but because I'm in a commerical building/shop I need to use grounded metal whenever possible. With no employees other than me I don't have to be OSHA perfect but I need to be as safe as I can. You guys that are in your own building and not in business, can use a plastic can or fiber drum. When taking the picture, I realized that I need to move that fire extingisher to a differ local.
BTW, I reallize that using a 90 degree take off just above the can is not ideal but with what I needed to do there using a wye probably wouldn't have worked well either.
Rob |
01-07-2008, 11:27 PM
#4 |
Name: Scott Smith City: New Hill State: NC County: Chatham Join Date: Mar 2007 Avg Visit Freq/Week = 5.44 over 180 days | Hey Rob - I wonder how it would do if you replaced the elbow in the can with a "T" fitting, with the side of the T facing the outlet?
My thought is that inertia would keep the chips flowing straight down the T into the can, but the air flow would go out the side of it and up through the outlet.
Bas and I were kicking that idea around the other day... If you try it, pls let us know if / how well it worked.
Thx!
Scott |
01-08-2008, 12:24 AM
#5 | | Asst. Webmaster
Name: Bas City: Cary State: NC County: Wake Join Date: Aug 2007 Age: 35 Avg Visit Freq/Week = 6.96 over 180 days | Lots of stuff with DC is never ideal. We all know about not making tight turns, minimizing flex hose, using wyes and not tees etc. But in the end, you gotta go make it work. Looks like a pretty nice setup, and kudos for thinking about safety. A fire extinguisher should be mandatory in every workshop, commercial or not.
__________________
Bas.
01-09-2008, 12:02 AM
#6 |
Name: Robert City: Matthews State: NC County: Union Join Date: Feb 2007 Avg Visit Freq/Week = 5.60 over 180 days | Scott,
I don't know if that will work cause ideally you want the cyclonic action to cause centrifical force to push the chips against the sides and spiral down. That configuration would definately change the flow pattern. I think that if you made a fin that spirals downward toward the bottom that attaches to the walls of the can it would help move the chips down without disturbing the flow. You could always fabricate an inline cyclone. If memory serves me right, that's what the guy on "Woodworking at Home" has on his. He also has an interesting damper on his that keeps from colapsing the light guage pipe just incase he accidently closes all the blast gates. Based on some of the pictures of your "little" machines I would think you would be looking for a cyclone to mount on the roof of the shop.
I've not had that big of problem with mine but then again I'm not looking for perfection. Seems like most of time, the can and one of the bags are full before I get around to emptying. Since I started using the inexpensive contractor clean-up bags on the DC's I don't care if the lower bags fill up. Tying up a bag is just as easy as emptying the can. I have the separator on there to protect the impeller from a chunk of wood or metal that might find their way into the system.
Rob |
01-09-2008, 01:32 AM
#7 |
Name: Scott Smith City: New Hill State: NC County: Chatham Join Date: Mar 2007 Avg Visit Freq/Week = 5.44 over 180 days | Rob - great info and answer. Thanks for taking the time to provide a detailed response.
Your point about the cyclonic action is valid - however I'm wondering if the "T" concept would work even though it would not be a cyclonic action. Seems to me that the intertia of the material would encourage it to function the same.... (may be worth an experiment).
You're correct re the size of some of my machines... however what I haven't mentioned is that I've purchased a 25HP blower to exhaust the dust from the "production" equipment that I've acquired. I plan to blow it straight into a dump truck and skip the whole filter issue. I don't remember if the inlet on the blower is 12" or 16" - but it's big! (I'll have to be careful that the barn cat's don't get near any of the openings...
I'll still need a smaller system for my "woodworking" equipment though - would hate to power up a 25HP motor just to suck some dust off of the belt sander or table saw! Hence my interest in the cyclone pre-separator.
Thanks again for the feedback - keep it coming!
Scott |
01-09-2008, 09:05 AM
#8 |
I've got a friend that is in the process of setting up a 25hp 36" Baxter Whitney planer. I told him he should warn the neighbors that their lights were going to dim when he cranks it up. That planer has a 10" dust port. I can't wait to see what kinda dust system he has to have to take care of it. Your big sucker may be what he needs.
Rob |
01-10-2008, 03:53 AM
#9 |
Name: Scott Smith City: New Hill State: NC County: Chatham Join Date: Mar 2007 Avg Visit Freq/Week = 5.44 over 180 days | Rob, he'll definitely need something in the same ballpark. My Oliver jointer - planer has a combined total of 38HP of motors (20hp planer, 15hp jointer, and 3hp feed), with two 6" dust ports coming off of it. Granted the 25hp dust collector is a bit overkill, but if I'm running the Oliver, Mattison SLR, and Baker moulder all simultaneously I'll need the flow.
Scott |
01-10-2008, 02:27 PM
#10 |
Name: Robert City: Matthews State: NC County: Union Join Date: Feb 2007 Avg Visit Freq/Week = 5.60 over 180 days | Originally Posted by scsmith42 Rob, he'll definitely need something in the same ballpark. My Oliver jointer - planer has a combined total of 38HP of motors (20hp planer, 15hp jointer, and 3hp feed), with two 6" dust ports coming off of it. Granted the 25hp dust collector is a bit overkill, but if I'm running the Oliver, Mattison SLR, and Baker moulder all simultaneously I'll need the flow.
Some people have way too biga tools!
Rob |
01-10-2008, 03:12 PM
#11 |
Name: Ray City: Raleigh State: NC County: Wake Join Date: Dec 2007 Age: 70 Avg Visit Freq/Week = 6.38 over 180 days | Would that be a "gigatool"??? |
01-10-2008, 07:45 PM
#12 |
Name: Scott Smith City: New Hill State: NC County: Chatham Join Date: Mar 2007 Avg Visit Freq/Week = 5.44 over 180 days | Originally Posted by Makinsawdust Some people have way too biga tools!
my first date said that ...  |
01-10-2008, 09:24 PM
#13 |
Name: Jimmy Coull City: Clayton State: NC County: Johnston Join Date: Sep 2006 Age: 49 Avg Visit Freq/Week = 6.34 over 180 days | I personally think that it's just a matter of time before Scott sets up his own co-generation plant  . Using wood chips for fuel and making electricity with a little steam on the side (do we see steam powered tools in your future Scott  ?
Jimmy Originally Posted by Makinsawdust Some people have way too biga tools!
__________________
Jimmy "There are no strangers here, only friends that haven't met " I only buy what I need now, not what I want..... except for lumber ! Remember: Support your local Sawyers and Kiln Operators. |
01-10-2008, 09:42 PM
#14 |
Name: Scott Smith City: New Hill State: NC County: Chatham Join Date: Mar 2007 Avg Visit Freq/Week = 5.44 over 180 days | Jimmy, that sure sounds like a "hot" idea...
I do plan on making my own bio-diesel this year though.... |
Posting Rules
Members: 2,313
Threads: 17,270
2nd Top Poster: jeff... (6,590) | | Welcome to our newest member, chelliot | » Today's Birthdays | bwat | |
