» Online Users: 75 | | 33 members and 42 guests | | Bas , Charlie , DaveO , dpsnyder , Dudelive , Edwhite911 , erasmussen , ErnieM , flatheadfisher , gesiak , Glennbear , jeff... , Joe Scharle , Jon , junquecol , Kicbak , Marcus Masencup , McRabbet , MrAudio815 , NCPete , NCTurner , P Crews , PChristy , ptt49er , Rescue U , rsitzejr , ScottM , striker , tmwassack , TopKnot , wdkits1 , woodlaker2 , yrsears | | Most users ever online was 180, 04-22-2008 at 12:18 AM. |  |
01-27-2008, 08:01 PM
#1 |
Name: Bill City: Raleigh State: NC County: Wake Join Date: Feb 2007 Avg Visit Freq/Week = 5.95 over 180 days | I just never have enough space in my shop so this weekend I decided to install some overhead storage in the shop (garage).
My shop has a walk in storage area above it so I was able to hang 2x4s from the 2x6 cross beams with lag bolts. The whole structure is lag bolted together, measures 8 X 12 feet and just like the cross beam is built on 24 inch centers  so I have no idea how much weight I can safely put up there. I will have to be careful about storing to much wood or the whole mess might come down on my head. I crawled around in it so I know it can handle 200lbs. At least I will get some of the little used stuff up there and maybe a sheet of 2 or plywood out of the way while I am working on a project
Here is a picture...I am fairly sure that I will have to crawl out of bed in the morning after this project....I am getting to old for this kind of work!  |
01-27-2008, 08:21 PM
#2 |
Name: Dennis City: Ivan's Corner (Monroe) State: NC County: Union Join Date: Jan 2007 Avg Visit Freq/Week = 6.92 over 180 days | Good idea, but go back & take a 2 x 4 support to the top chord (rafter) of the truss. This will go along way towards adding support to the unit. If you bolted the verticals to the truss like you did the horizontals, just move those bolts up to the top & buy longer ones, sandwiching the truss in between. If the additional support goes by other truss members do the same - but not through a tie plate.  |
01-27-2008, 08:23 PM
#3 | | Administrator
Name: Chad City: Hookerton State: NC County: Greene Join Date: Feb 2006 Age: 54 Avg Visit Freq/Week = 6.92 over 180 days |
__________________
Chad Pen turning is fast and fun!
It is highly addictive!
All your free time you once had will become a thing of the past!! And Down The Dark Side Of Woodworking You! Will!
Goooooo!!  |
01-27-2008, 08:33 PM
#4 | | Vice-President Libraries Administrator
Name: Rob City: Hendersonville State: NC County: Henderson Join Date: Nov 2005 Age: 66 Avg Visit Freq/Week = 6.81 over 180 days | Good advice by Dennis to insure proper load distribution. And great use of that dead space overhead! BTW, I move this thread to the Workshops Forum.
__________________
Rob  Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way! |
01-27-2008, 09:11 PM
#5 |
Name: Bill City: Raleigh State: NC County: Wake Join Date: Feb 2007 Avg Visit Freq/Week = 5.95 over 180 days | Originally Posted by Gotcha6 Good idea, but go back & take a 2 x 4 support to the top chord (rafter) of the truss. This will go along way towards adding support to the unit. If you bolted the verticals to the truss like you did the horizontals, just move those bolts up to the top & buy longer ones, sandwiching the truss in between. If the additional support goes by other truss members do the same - but not through a tie plate.  I am not sure I can do what you are suggesting..I have included a picture that shows the the 2x4 bolted to the crossbeam in the storage area. It maybe that I can't do anything else and just need to keep the load on the storage unit reasonable...however I am open to suggestions on how to improve this setup structurally...Thanks!  |
01-27-2008, 09:36 PM
#6 |
Name: Dennis City: Ivan's Corner (Monroe) State: NC County: Union Join Date: Jan 2007 Avg Visit Freq/Week = 6.92 over 180 days | The suport you show is close enough to the vertical truss brace that no additional support shuld be needed on that line. You may want to reexamine the other verticals, though. Looks like you have about a 12/12 pitch roof there. They're very strong when they're that steep. BTW, I didn't floor my attic because of (Fred)Sanford's Law. That is, "Junk expands to fill the space available." With your trusses having a 2 x 6 bottom chord you shouldn't have too much trouble with storage there. Just keep it reasonable & slip some 6" batts under that OSB. |
01-28-2008, 01:24 AM
#7 |
Name: Bill City: Raleigh State: NC County: Wake Join Date: Feb 2007 Avg Visit Freq/Week = 5.95 over 180 days | Originally Posted by Gotcha6 The suport you show is close enough to the vertical truss brace that no additional support shuld be needed on that line. You may want to reexamine the other verticals, though. Looks like you have about a 12/12 pitch roof there. They're very strong when they're that steep. BTW, I didn't floor my attic because of (Fred)Sanford's Law. That is, "Junk expands to fill the space available." With your trusses having a 2 x 6 bottom chord you shouldn't have too much trouble with storage there. Just keep it reasonable & slip some 6" batts under that OSB. Thanks for your help - you are correct it is very steep roof that ties all this together. |
Posting Rules
Members: 2,313
Threads: 17,270
2nd Top Poster: jeff... (6,588) | | Welcome to our newest member, chelliot | » Today's Birthdays | bwat | |
