North Carolina Woodworker
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Workshops
Notices
Workshops Tell us about your workshop, or get help with workshop planning and setup
» Announcements
Raffle is now closed. Raffle numbers have been Email Please Read . Drawing 12:30 pm Thursday 1/8/09 (GOOD LUCK)!!
1st Qtr
Donation Drive Please Donate! Please Read!
Featured Photos
by cranbrook2
26248 photos
9608 comments
by gordonmt
26248 photos
9608 comments
by Alan in Little Washington
26248 photos
9608 comments
by MikeL
135 photos
7 comments
» Online Users: 61
17 members and 44 guests
bluthart , DaveO , Elmojo , Glenn Hudson , jeff... , jglord , Joe Lyddon , kenger22 , mbeach , NCTurner , P Crews , PeteQuad , Ralrick , redhawknc1 , Tar Heel , TedAS , thrytis
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 01-21-2008, 09:02 PM   #1
SRhody's Avatar
City: Jacksonville
State: NC
County: Onslow
Threads: 4
Avg Visit Freq/Week
= 5.83 over 180 days
Ok, looking for some comments here, beware jumping in with both feet.
Situation: Small workshop, good table saw w/fence and a Delta SH100 Router/Shaper (which does a good job for my level of projects).
My problem is the SH100 doesn't really have enough surface area , but I don't have enough room for an adequate sized router table.
So do I merge the SH100 into the table saw? I know it will work, a bit unconventional as most people use a handheld base.
Let the flood gates open.
Show Printable Version Email this Page   Quote this post in a PM to SRhody
Old 01-21-2008, 10:18 PM   #2
Director
toolferone's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 152
Avg Visit Freq/Week
= 6.92 over 180 days
Delta, used to make a large mdf piece that mounted around the sh100 to add more surface area. I beleive it has a ledge all the way aound it. You might be able to buy one or make one and just mount it when you are doing large items. Or you could mount it with the tablesaw. One of the main problems wit that is you might be stuck in one set up and need the other and well it is a pain to change around. My .02 cents worth.
__________________
Tom
www.dreamshopwoodworks.com
TWA
Triangle Woodworking Association Member
Membership chairperson.
Show Printable Version Email this Page   Quote this post in a PM to toolferone
Old 01-21-2008, 10:51 PM   #3
City: Apex
State: NC
County: Wake
Threads: 246
Avg Visit Freq/Week
= 6.26 over 180 days
If you are using a right tilt contractor's saw, consider mounting router in the left wing. This way, saw could be up against wall on right side, and still have router usable. Plus feed direction would be the same as for saw.
Show Printable Version Email this Page   Quote this post in a PM to junquecol
Old 01-21-2008, 11:00 PM   #4
Gotcha6's Avatar
City: Ivan's Corner (Monroe)
State: NC
County: Union
Threads: 43
Avg Visit Freq/Week
Kinda like this?
http://cgi.ebay.com/WOODPECKERS-TS-R...QQcmdZViewItem
Show Printable Version Email this Page   Quote this post in a PM to Gotcha6
Old 01-22-2008, 12:24 AM   #5
JohnW's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 17
Avg Visit Freq/Week
= 3.66 over 180 days
For small shops another idea would be to make a router table...top only. Two 3/4" sheets of MDF glued together and topped with laminate. Trim the sides with any hardwood and poly the underside to limit moisture intrusion. Cut a recess to hold whatever router plate you have. Takes up very little room when stored leaning against a wall. To use, put it on saw horses.
You can make it as large as you want but locate the router plate off center. Example: You build a router table 36" x 48" long. Locate the router plate so the bit center is 12" from the front edge. This means the bit is 24" from the back edge. The fence can be mounted on either side so you have more flexibility by placing the plate off center.
I got my start in woodworking this way. The only power tool I had was a router kit. Used it for everything including cutting the grass and mixing drinks.
John W
Show Printable Version Email this Page   Quote this post in a PM to JohnW
Old 01-22-2008, 09:08 AM   #6
lottathought's Avatar
City: Garner
State: NC
County: Wake
Threads: 48
Avg Visit Freq/Week
= 4.01 over 180 days
How far does your table saw fence stick out?
I have the Ridgid TS3650.
I also am limited in shop space.
I just built a router table that fits into the extension of the fence.
I have some pics posted...check them out.
Show Printable Version Email this Page   Quote this post in a PM to lottathought
Old 01-22-2008, 09:42 AM   #7
SRhody's Avatar
City: Jacksonville
State: NC
County: Onslow
Threads: 4
Avg Visit Freq/Week
Thanks for the info, this is along the same lines as I've been thinking. Different machines and set ups but the same principal.
Old 01-22-2008, 01:29 PM   #8
Joe Scharle's Avatar
City: Holly Springs
State: NC
County: Wake
Threads: 125
Avg Visit Freq/Week
= 7.04 over 180 days
I've got 2 standalone RTs, but I use the tablesaw ext the most. I think that if you can get it tucked in just right that you'd like it. Especially, handy when you need a lot of 'router table'!
Show Printable Version Email this Page   Quote this post in a PM to Joe Scharle
Old 01-22-2008, 03:27 PM   #9
SRhody's Avatar
City: Jacksonville
State: NC
County: Onslow
Threads: 4
Avg Visit Freq/Week
Thanks. I think I'll start working on (figuring out) a tablesaw extension for my tools.
Closed Thread
routers , saws , tables
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
End Tables Joe Scharle General Woodworking 19 09-12-2007 12:23 AM
Trend Mortise and Tenon Jig (for routers) Nativespec Power Tools and Their Use 4 03-06-2007 04:46 PM
Pathetic Makita routers Redfish Reviews 6 10-12-2006 09:22 PM
Routers and shapers windknot Power Tools and Their Use 2 12-03-2005 10:15 AM
CNC Routers Bernhard General Woodworking 1 11-29-2005 01:19 PM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,314
Threads: 17,270
2nd Top Poster: jeff... (6,590)
Welcome to our newest member, yrsears
» Today's Birthdays
bwat
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
