» Announcements |
The Woodworking Source Grand Opening
Saturday November 22
» Online Users: 42 |
| 10 members and 32 guests |
CaptnA
cliff56
NC Scroller
NCPete
Partman
rick7938
Sanders Woodworking
Splint Eastwood
woodylarry
| Most users ever online was 180, 04-22-2008 at 12:18 AM. |
03-10-2008, 11:05 PM
#1
This Space for rent
City: Greensboro
State: NC
County: Guilford
Avg Visit Freq/Week = 2.41 over 125 days
Motor turns on then off
Hi guys, I just posted this over at the ClearVue forum but I thought I'd ask here too!
I've been running my ducting around the shop and finally got to the point where I could turn on the cyclone and test it out on the table saw. Well, the motor cranks up, then slows down, then back up, then back down until I shut it off. I'm not sure what's wrong. I've doubled and triple checked my wiring and I'm 99% sure that I have it correct. I'm using a 30A breaker with the relay and remote from ClearVue.
Please Help!!!!!
Thanks,
03-10-2008, 11:44 PM
#2
City: Hope Mills
State: NC
County: Cumberland
Avg Visit Freq/Week = 6.94 over 125 days
Re: Motor turns on then off
Geoff, do you have a 'run' capacitor on your machine??? sounds like the start capacitor is doing its job, then the secondary capacitor (run cap - handles when the motor encounters a big load) is firing. the motor slows down as the cap is charging, slowing down may trigger a load sensor, then the cap fires - hence the increase in speed..... If you have the motor contacts wired correctly, I suspect you may not have the outlet wired right???
I am basically talking out my third point of contact, so you may actually want professional advice, to, but that is something to consider.
__________________
Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it. Henry David Thoreau
They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin
03-10-2008, 11:58 PM
#3
This Space for rent
City: Greensboro
State: NC
County: Guilford
I'm not sure if I have a run capacitor or not...I'll look into that. Thanks for the tip. I'm pretty sure I have the outlet wired correctly too but I'll check it tomorrow.
I do have a dumb question though...Is there a difference between L1 and L2?
03-11-2008, 12:54 AM
#4
Libraries Administrator
City: Hendersonville
State: NC
County: Henderson
Avg Visit Freq/Week = 6.78 over 125 days
There are two capacitors on the side of the Leeson and they are pre-wired (it is conceivable that one of them is bad). I am using crimp-on terminal lugs on my 230 V contactor to insure good connections. Be sure to recheck that you did the L1 and L2 connections per the description on page 20 of the ClearVue Assembly Instructions -- on mine, P3 & T1 and T5 came tied together with a wire nut on them. L1 connects to P1. L2 connects to T4 & T8. Be sure to use the correct sized wire nuts (I am using G-B #86 Large Red "WingGard" nuts) and pre-twist the stranded wires clockwise before adding the wire nuts. And be sure that your bare wire coming in -- the Neutral -- has a good connection to the green screw inside the motor connection box (scrape away any paint and be sure it is tight). L1 and L2 are each 115 Volts but are the opposite sides of the 230 Volt incoming power from your breaker panel. If you are confused, read Note 1 at the top of page 20. If still confused, read Note 2 and/or 3.
__________________
 Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
03-11-2008, 01:25 AM
#5
This Space for rent
Name: Bob Christensen
City: Pittsboro
State: NC
County: Chatham
It does sound as if it could be a wiring error as McRabbet posted in his note. In trouble shooting the problem, I would also disconnect the DC from the remote and plug directly into the wall outlet just to make sure the relay is not causing a problem.
Bob
03-11-2008, 10:44 PM
#6
This Space for rent
City: Greensboro
State: NC
County: Guilford
I've double checked all the connections...except the ground. I didn't think about that one. Thanks McRabbet. I took the relay out of the equation tonight by plugging the motor into the outlet. The motor still did the same thing so it's not the relay. Ed emailed me and said if the connections are good, then take it to a Lesson service center. I never checked the ground, but since I just dismantled the cyclone tonight to get to the motor to the service center, I'm just going to bring it there tomorrow. If it all checks out, I'll check the ground and other connections and see what happens.
03-12-2008, 10:58 AM
#7
This Space for rent
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Avg Visit Freq/Week = 6.66 over 125 days
If not the capacitors, then maybe the centrifugal switch, bad contacts?- the start capacitors work but when it gets up to RPM the switch doesn't cut in the run capacitor?
03-12-2008, 09:38 PM
#8
This Space for rent
City: Greensboro
State: NC
County: Guilford
It works! I took it to a motor repair shop that was on the Lesson website. Great place! They tested the motor and it worked perfectly there...so what was wrong? The motor wiring was good, the outlet was good, the relay was good, the plug that plugged into the outlet???? bad. I mis-wired it...I followed the directions green to ground, black wire to X and white wire to W. oops, white was really supposed to go to Y since it's my other hot wire...  I fixed that, re-hung the cyclone and cranked it up and it works. My wife even hung out in the shop and watched it suck the dust from my tablesaw!
Thanks again, this site rocks. .gif)
03-12-2008, 09:42 PM
#9
This Space for rent
City: Ivan's Corner (Monroe)
State: NC
County: Union
Avg Visit Freq/Week = 7.00 over 125 days
Don't ya just love epiphanies?
03-13-2008, 04:18 PM
#10
State: NC
County: Henderson
 And thus proving that honking big motors that are meant to run on 230 Volts don't do so well on 115! Glad you got it sorted out and the CV is up and running -  -  -
Out of courtesy, you might want to drop Ed Morgano an email to let him know.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
» Stats |
Members: 2,066
Threads: 16,070
2nd Top Poster: jeff... (6,242)
| Welcome to our newest member, Ray Irvin |
» Today's Birthdays |
MikeF (40)
