» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  | |
06-11-2008, 05:17 PM
#1 | | Ideas for workbench top Name: Steve City: Carrollton State: VA County: Isle of Wight Join Date: Jan 2008  06-11-2008, 05:17 PM
Just welded up some 2x2 tube for legs and a piece of angle to attach the legs to the top. I need some ideas for top material. Can't believe the cost of maple work tops from Grainger. $300 for a 72 x30 I remember paying $100 for the same just awhile ago. Looked at Lumber Liq for the butcher block counter top stock and that is still about $200. I need a cheap solution to a good top that will accept pin style dogs and thick enough to mount a vise etc. | | Views: 2370 |
06-11-2008, 05:22 PM
#2 | | Development Director
Name: Stuart City: Chapel Hill State: NC County: Orange Join Date: Jan 2006 Avg Visit Freq/Week = 6.84 over 180 days | Re: Ideas for workbench top A cheap alternative would be a solid core door. I bought two new ones for $10/each a couple of months ago. They are solid and heavy. |
06-11-2008, 05:27 PM
#3 |
Name: George City: Oxford State: NC County: Granville Join Date: Jul 2005 Age: 70 Avg Visit Freq/Week = 6.92 over 180 days | Re: Ideas for workbench top At 2" thick that is 30 bdft. Current Hardwood Store of NC pricing for 8/4 hard maple is5.35/bdft = $165.00 for wood (plus some percentage for waste). Laminate it together and drill 3/4" holes for dogs.
Some here have shown beautiful benches with laminated 2x4 tops so you might want to go that way for cost.
George
__________________
2B1ASK1
06-11-2008, 05:31 PM
#4 | | Moderator
Name: Pete Davio City: Hope Mills State: NC County: Cumberland Join Date: Dec 2005 Avg Visit Freq/Week = 5.99 over 180 days | Re: Ideas for workbench top Grizzly has tops, too. do not recall the price, tho!
__________________ Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it. Henry David Thoreau They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin
06-11-2008, 06:53 PM
#5 |
Name: Steve City: Carrollton State: VA County: Isle of Wight Join Date: Jan 2008 Avg Visit Freq/Week = 0.70 over 180 days | Re: Ideas for workbench top I might be up for building one. Do I need to watch out for anything in order to keep everything flat. |
06-11-2008, 06:57 PM
#6 | | Moderator
Name: Glenn City: Baskerville State: VA County: Mecklenburg Join Date: Jan 2008 Age: 60 Avg Visit Freq/Week = 6.30 over 180 days | Re: Ideas for workbench top Originally Posted by gator At 2" thick that is 30 bdft. Current Hardwood Store of NC pricing for 8/4 hard maple is5.35/bdft = $165.00 for wood (plus some percentage for waste). Laminate it together and drill 3/4" holes for dogs.
George Personally, like Tar Heel I grabbed some of the CL $10 doors. Bas has built benches using the lamination route : http://www.ncwoodworker.net/pp/showp...hp?photo=19755
__________________ " I get knocked down but I get up again" - Chumbawamba |
06-11-2008, 08:20 PM
#7 | | Senior Moderator Events Director
Name: Scott City: Cary State: NC County: Wake Join Date: Jul 2007 Avg Visit Freq/Week = 6.49 over 180 days | Re: Ideas for workbench top Steve, Bas made a great bench out of quality 2X lumber. Here is a link to that thread. Will the 2X bench last a long as the hard maple bench ? Probably not but it will provide many many years of service. http://www.ncwoodworker.net/forums/f...rkbench-11726/
__________________
Making Saw Dust With a Scroll Saw
Scott |
06-11-2008, 08:54 PM
#8 | | Secretary
Name: Scott Smith City: New Hill State: NC County: Chatham Join Date: Mar 2007 Avg Visit Freq/Week = 6.53 over 180 days | Re: Ideas for workbench top What about laminating one out of 4/4 x 2" wide maple flooring strips? You could use some inexpensive flooring, and laminate it so the 2" flooring width becomes the depth of the bench top.
Out to be strong as an ox...
Scott |
06-11-2008, 09:07 PM
#9 |
Name: Mark City: Goldsboro State: NC County: Wayne Join Date: Mar 2006 Avg Visit Freq/Week = 4.59 over 180 days | Re: Ideas for workbench top One of the problems using pin dogs in a pine top is that the soft wood "wallows" out and the pins won't stay tight. This can be solved by drilling a 1" hole, gluing in a section of 1" hardwood dowel, and trimming it flat. Re-drill for the bench dog size.
You can also use a larger size (ie 1 1/4 or 1 3/8 ) and use a piece of hardwood mop handle which will work better.
If using a Borg or local builder supply 2 x lumber, I would go with SYP instead of SPF. This means you will probably have to go with 2 x 8s minimum and rip to the thickness. The SYP may harden enough (if it has enough resin in it) so you never need the inserts. The SPF will probably split or wallow out if you put much force on the bench dogs.
If using the plastic "pins" or dogs, the pine will probably work, or you can double layer some 3/4 cabinet ply. I have an old Workmate that has a single layer 3/4 Baltic Birch top (28 1/2" x 35 1/2") that has lasted me for over 15 years using the plastic dogs that came with it.
__________________ "The three hardest things to make in your shop are time, space, and money" - Buz Buskirk (quoted in Woodworking Magazine, Spring 2009) |
06-11-2008, 09:59 PM
#10 |
Name: Steve City: Carrollton State: VA County: Isle of Wight Join Date: Jan 2008 Avg Visit Freq/Week = 0.70 over 180 days | Re: Ideas for workbench top Thanks for all the ideas. Here is a view of the legs. The photo makes them look bent but it's just the camera. I don't have any span support for the top so it needs to be thick so the glue up designs are probably the best for this app.  |
06-11-2008, 10:23 PM
#11 | | Senior Administrator
Name: Bas City: Raleigh State: NC County: Wake Join Date: Aug 2007 Age: 36 Avg Visit Freq/Week = 6.96 over 180 days | Re: Ideas for workbench top Steve, Originally Posted by Chipper I don't have any span support for the top so it needs to be thick so the glue up designs are probably the best for this app. I made a top out of Southern Yellow Pine, 6'x2'x3". That's not going to sag unless you stack a couple of table saws on it. Originally Posted by Chipper I might be up for building one. Do I need to watch out for anything in order to keep everything flat. Not really, just be careful with positioning the clamps. Parallel clamps are best, but cheap Harbor Freight bar clamps work just fine, that's what I used. I glued up the top in stages, re-jointing and planing along the way, until the final glueup. You can rip the boards wide enough out of a 2x8 to give you enough material for this strategy. A biscuit joiner might help, but I didn't have one at the time.
Home Depot sells SYP, but not all the stores have it. Also, buy your lumber during the week, not on the weekend. That's the stuff left by the contractors during the week! (Don't ask me how I know this.....)
__________________
Bas.
I don't need it. I just want it.
06-11-2008, 10:33 PM
#12 |
Name: Stacey City: Jacksonville State: NC County: Onslow Join Date: Jan 2008 Avg Visit Freq/Week = 6.22 over 180 days | Re: Ideas for workbench top Here's how I did it, split top:  . A couple more shots in my gallery.
Basic info: 2" tube legs and bottom, 4x layers of MDF covered with reclaimed 100 yr old piano, other wood is WO, 24 x 60 x ~36 tall, center trough has removable bottom. T-track rails on each side. The MDF gives the weight, the hardwood top can be replaced if needed eventually. Mainly used 'bed bolts' to tie all the components together.
This doubles as a long outfeed table for my tablesaw/RT combo.
Why go into all this, just another perspective on what can be done, maybe a point of departure.  |
06-11-2008, 10:55 PM
#13 |
Name: Jim City: Lexington State: SC County: Lexington Join Date: May 2008 Avg Visit Freq/Week = 0.12 over 180 days | Re: Ideas for workbench top My bench has a top of 1 layer of 3/4 plywood plus one replaceable layer of 1/4 inch plywood. The next top will be 1/4 MDF. It has an inch edging of oak. I mounted a vise but had to make it thicker at that location. It is supported by a torsion box. The 3/4 plywood is the top layer of the torsion box. Norm of New Yankee Workshop did the same sort of thing on one of his shows. Norm's was a worktable instead of a bench but the construction was like what I did. I have bench dog holes 3/4 inch diameter for the plastic dogs Rockler sells.
Jim |
06-11-2008, 11:28 PM
#14 |
Name: George City: Oxford State: NC County: Granville Join Date: Jul 2005 Age: 70 Avg Visit Freq/Week = 6.92 over 180 days | Re: Ideas for workbench top I laminated mine from maple. When finished, I took it to a local cabinet shop with a wide belt sander and paid them $25 to flatten it perfectly. I put retractable wheels on it from Norm's assembly table and when it is flat on the floor (wheels retracted) it is the same height as my table saw. www.ncwoodworker.net/pp/data/198/100_0287.JPG www.ncwoodworker.net/pp/data/198/100_0288.JPG
And speaking of dogs, I did not drill my dog holes all the way through and use 3/4" dowels for dogs. I bought a 3' length of dowel rod and cut it to the lengths I wanted for dogs. I also occasionally use the little plastic dogs that came with my WorkMate.
George
__________________
2B1ASK1
06-11-2008, 11:37 PM
#15 |
Name: Dave Snider City: Advance State: NC County: Davie Join Date: Oct 2007 Age: 65 Avg Visit Freq/Week = 0.12 over 180 days | Re: Ideas for workbench top I went to a local hardwood supplier in my area, (Clemmons Hardwoods) and had them to glue up an edge grain Maple top-2 1/2" thick. It wasn't that overly expensive-I didn't think. Been a few years ago, though.
__________________
Dave in NC
"A man's gotta know his limitations"!
| |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Need some ideas | 02ranger | General Woodworking | 12 | 05-19-2008 08:27 PM | | Looking for ideas for cherry | Jon | General Woodworking | 4 | 04-11-2007 03:17 PM | | Gift Ideas ... | WoodWrangler | General Woodworking | 4 | 09-13-2006 09:31 AM | | Ideas | Arcrist | General Woodworking | 9 | 03-29-2006 08:23 PM | | Any ideas on corian | scoobyJ | Where Can I Find, Buy or Sell | 3 | 03-07-2006 02:19 AM | | » Stats |
Members: 3,663
Threads: 25,107
Top Poster: DaveO (14,702) | | Welcome to our newest member, Keith Senderak | |
