» Announcements |
The Woodworking Source Grand Opening
Saturday November 22
» Online Users: 50 |
| 22 members and 28 guests |
ashley_phil
Bob Buchholz
clowman
dancam
Douglas Robinson
enm
farmerbw
flatheadfisher
JackLeg
JimmyC
jjahr
MikeH
nelsone
pcooper
ptt49er
Sandy Rose
sediener
skeeter
Touchwood
woodrat
| Most users ever online was 180, 04-22-2008 at 12:18 AM. |
02-11-2008, 12:29 PM
#1
This Space for rent
Name: Fern HollowMan
City: Franklinton
State: NC
County: Granville
Avg Visit Freq/Week = 4.98 over 125 days
Dust fittings, of a sort
Okay, okay, I know you're growing weary of all my duct-dust threads, but I just had to share this.
Getting plastic flex over the S&D pipe is a frustrating challenge. I tried the freezer and hair dryer trick (didn't work well), liquid dish detergent (works great slipping the pipe into the fittings and allowing the fitting to swivel to fit, but sucks trying to get flex over the pipe). So what the heck, I tried making a reducer.
If you look carefully, you can see the seam in the smaller diameter pipe. I sliced out a section lengthwise on my cheapo B&D 3 wheel bandsaw, sanded the edges with 220, applied a liberal amount of PVC cement to the seam (inside and out) and then around the perimeter, and slipped the section in the standard pipe. I wouldn't use this for a pressure fluid application, but for dust work, it works real well. Feeding the pipe slowly into the blade is helpful.
Now, I know you hate math, but it can be your friend. The wall thickness of my 4" D2729 pipe is 0.085" (for the 6" stuff, it's 0.11~ or thereabouts). By doubling the wall thickness, and muliplying by that nefarious constant Pi (3.14159), we derive the value of 0.53". Mark that width on the outside of the pipe, slice it out, and glue it up. The plastic flex slips easily over the reducer.
If I had thought to do this before I bought my expensive acrylic tubing, I would have had enough pocket $$ to buy something worthwhile.
__________________
...I have finally reached the age where my wants and needs have regressed to my early childhood:
---I want everything and need nothing.
02-11-2008, 12:41 PM
#2
This Space for rent
City: franklinton
State: nc
County: franklin
Avg Visit Freq/Week = 7.00 over 125 days
Re: Dust fittings, of a sort
these are what Im using.
http://woodcraft.com/family.aspx?familyid=3947
the flex screws on one end and the other end fits perfectly inside S&D fittings. I used PVC glue to attach to the pipe fittings and it works good.
fred
02-11-2008, 12:44 PM
#3
Asst. Webmaster
City: Cary
State: NC
County: Wake
Avg Visit Freq/Week = 6.94 over 125 days
Now that is a great solution. Given that the PVC cement pretty much fuses the pipe back together, I think it's an extremely strong joint, especially since it's inside another pipe.
__________________
Bas.
I don't need it. I just want it.
02-11-2008, 01:51 PM
#4
This Space for rent
City: Chapel Hill
State: NC
County: Durham
Avg Visit Freq/Week = 6.16 over 125 days
Nice solution. Of course, now that I know how the cheapskate in me will insist on making my transitions from scrap instead of paying $4.50 per...
Funny thing, my first reaction was "that's pretty thin walled stuff - can it really be 1/2" difference in the circumference between inside and outside walls?".
You're right, of course. Almost any calculation with circles is hard to estimate: would you have guessed that the total area would be constricted by 1 inch for this modification? That's a 8% reduction in area! (more fun with your friend, pi, if my memory of geometry is right)
02-11-2008, 01:55 PM
#5
This Space for rent
City: New Hill
State: NC
County: Chatham
Avg Visit Freq/Week = 4.82 over 125 days
Jim, that's a neat idea!
02-11-2008, 02:15 PM
#6
This Space for rent
City: Raleigh
State: NC
County: Wake
Avg Visit Freq/Week = 4.76 over 125 days
That is a fantastic idea Jim. I was looking at the threaded adaptors this weekend. Right on time.
02-11-2008, 03:24 PM
#7
Libraries Administrator
City: Hendersonville
State: NC
County: Henderson
Avg Visit Freq/Week = 6.78 over 125 days
Ironically, three years ago when I built this Chip Separator  from plans in ShopNotes (No. 55, IIRC), they showed how to make adapters for the 4" flex entering and exiting the top of the unit by taking a slice out of a piece of Schedule 40 PVC as you described and then cutting kerfs with your bandsaw on the inside of the pipe every 1/2" or so to allow it to be more bendable when closing the gap.
There is a neat trick they explained in how to calculate the size of the cut you must remove to reduce the pipe size with no math involved. Use a strip of copy paper and make a "hoop" with it to fit inside your flex. Mark the point of overlap on the inside of the hoop. Then wrap the paper around the larger pipe and the cutout is the difference between the mark and where the end intersects the wrapped end. Works for any size as long as the paper strip is long enough.
__________________
 Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
02-11-2008, 03:50 PM
#8
This Space for rent
City: Asheville
State: NC
County: Buncombe
Avg Visit Freq/Week = 4.03 over 125 days
Originally Posted by FredP
I used the same system, Fred. Work extremely well and have the added advantage of being able to take them apart if needed.
02-11-2008, 06:14 PM
#9
This Space for rent
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Avg Visit Freq/Week = 6.66 over 125 days
You need to be careful- the threads on some flex are backwards from those fittings.
02-11-2008, 07:15 PM
#10
State: NC
County: Henderson
And you won't find them for 6" flex, either!
__________________
02-11-2008, 08:19 PM
#11
This Space for rent
Name: earl rasmussen
City: Pikeville
State: NC
County: Wayne
Avg Visit Freq/Week = 6.83 over 125 days
Looks like a good fix
__________________
Earl
"If you want to learn how to build a house, build a house.
Don't ask anybody, just build a house."
"Oland tool, better than a bowl gouge, a lot cheaper to make." Darrell Feltmate around the woods
02-11-2008, 09:42 PM
#12
This Space for rent
City: Ivan's Corner (Monroe)
State: NC
County: Union
Glad to see a solution so simple. This stuff don't hafta be rocket surgery or brain science. Keepin' it in mind....
02-11-2008, 11:56 PM
#13
This Space for rent
City: Wake Forest
State: NC
County: Wake
Avg Visit Freq/Week = 5.26 over 125 days
Was this one of those  moments? I seem to have them frequently myself.
__________________
Wife changed my perspective. I need want some additional tools. I need want a
multi-spindle line borer - unlikely in 2008
pocket hole machine - unlikely in 2008
Festool sander and vacuum -told I don't need 2 not going to happen
Edge bander - unlikely this decade
oscillating edge sander - unlikely in 2008
floor model chisel or slot mortiser - unlikely in 2008
and a bigger shop - maybe in 2009
02-12-2008, 10:20 AM
#14
This Space for rent
City: Franklinton
State: NC
County: Granville
Yep. Without doubt, IMO, the most perceptive and salient tag line on this board belongs to Bas.
His axiomatic aphorism relating to experience and when it is gained is profound beyond words.
| tip o' the hat
to Bas.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
