North Carolina Woodworker
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Workshops
Notices
Workshops Tell us about your workshop, or get help with workshop planning and setup
» Announcements
Raffle is now closed. Raffle numbers have been Email Please Read . Drawing 12:30 pm Thursday 1/8/09 (GOOD LUCK)!!
1st Qtr
Donation Drive Please Donate! Please Read!
Featured Photos
by Grgramps
26248 photos
9607 comments
by b4man
26248 photos
9607 comments
by DeCe
26248 photos
9607 comments
by Chuck Seehuetter
94 photos
12 comments
Closed Thread
Old 09-16-2008, 08:07 PM   #1
Splinter's Avatar
City: Wallace
State: NC
County: Duplin
Threads: 156
Avg Visit Freq/Week
= 5.17 over 180 days
This is like my DC.. http://www.cpojettools.com/products/710700ck.html
It is a 2HP 1200 CFM at 4" DC machine. Now for the questions.....
I can remove the y (for 2 4" ports) at the machine and it has a 6" port. If I was to run 6" S&D pipe out to my tools and then reduce the pipe down at each tool to 4" to connect to the tool's port would I get better dust collection than leaving it at 4" and running all 4" pipe?
I will probably have a short piece of 4" flex at each machine to get the pipe to the DC port.
I have 4" blast gates at all machines and only run one machine at a time with all other blast gates closed (If I don't forget to close one).
__________________
You can't work without tools.
So many tools so little money.
Show Printable Version Email this Page   Quote this post in a PM to Splinter
Old 09-16-2008, 10:05 PM   #2
GeorgeL's Avatar
City: Fuquay Varina
State: NC
County: Wake
Threads: 19
Avg Visit Freq/Week
= 6.96 over 180 days
Dolan,
Absolutely. A 6" main would be much more efficient than a 4". Some say to run 6" all the way to the machine and increase the port size to 6". I have a similar Dc from Penn State and went your route with 6" S&D mains with 6" drops to the planer and miter saw, 5" drop to the jointer and 4" drops to the lathe, table saw, band saw and router table. The biggest bottleneck you will find in your system is the 5" outlet from the blower to the filter. I increased mine to 6" and it made a world of difference. Also look for good flex hose that is nearly smooth on the inside to eliminate friction. I went with Wynn Environmental and am very satisfied.
George
Show Printable Version Email this Page   Quote this post in a PM to GeorgeL
Old 09-16-2008, 10:42 PM   #3
Bas is online now Bas
Asst. Webmaster
Bas's Avatar
City: Cary
State: NC
County: Wake
Threads: 142
Avg Visit Freq/Week
What George said. I used 4" PVC all the way, but that's because (a) 4" is cheap and 6" is expensive and (b) my DC isn't powerful enough for 6" (velocity would drop too much). But if I ever upgrade to a better unit, I'd redo the pipes.
__________________
Bas.
I don't need it. I just want it.
Show Printable Version Email this Page   Quote this post in a PM to Bas
Old 09-17-2008, 12:18 PM   #4
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Threads: 208
Avg Visit Freq/Week
= 6.73 over 180 days
Run 6" all the way. Look at the inlet, and if there is a screen or something similar blocking the inlet, remove it (unless you have plastic impeller). Enlarge your outlet. Enlarge your blast gates and machine ports to 6." See my comments about stepping down duct size your DC Pipe Layout Tool thread.
Other notes- that blower has only a 12" impeller and that CFM rating is given for 4" pipe (likely measured with no reasonable resistance) so is likely much less than stated when in operation as part of a system. It should do fine in a small (to medium?) hobby woodshop, but won't do it for a larger shop (or with long/convoluted duct runs.) You would be better off discharging directly outside (if you live in the sticks), outside to a bag system, or adding a separate cyclone and a cartridge filter. Despite claims to the contrary, cartridges in a system like the Jet will become impacted with dust and quickly lose efficiency. That is why most of them have some sort of beater bar rig. The whole purpose of a cyclone is to separate out the dust and chips so they do not clog the filter (of whatever type).
Remember, flow is affected by inlet resistance (machine ports, blast gates, ductwork design, etc.) but is affect just as much or more by stuff on the other side of the blower (clogged dust bags, clogged cartridge filters, ductwork, etc.)
You can upgrade your system to a cyclone at any time using your existing DC blower. It can be added to either the inlet or outlet side of the blower and does not need to be the typical motor/blower-over-cyclone stacked system as sold by Oneida, Grizz, Clearvue, etc. (most also sell just the cyclone unit w/o blower). My cyclone is configured in a push-through mode- I added it downstream from a motor/blower unit from an old, bag style, Griz DC.
For those who haven't visited my shop, here is a pic of my DC and cyclone. I finally found my DC and cyclone construction pics on my old computer so will upload them later and start a separate post for those who might want to bend some metal and build one someday. (yes it is tall! This version of the Pentz design cyclone has a cone length 3X the diameter of the cylinder. Clearvue and others based on the Pentz design are typically 1.64X. 3X is purportedly better at separating the fines?)
Show Printable Version Email this Page   Quote this post in a PM to Alan in Little Washington
Closed Thread
collector , dust , pipe , question
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
PVC pipe based dust collection Pop Safety & Health 19 03-04-2008 11:20 PM
Dust Collector golfdad General Woodworking 6 01-11-2007 06:20 PM
Dust Collector question jeff... Power Tools and Their Use 26 05-16-2006 10:21 AM
Dust collector Sweetgum Where Can I Find, Buy or Sell 5 04-28-2006 11:06 AM
Dust collector pipe upgrade Travis Porter Power Tools and Their Use 7 03-24-2006 09:12 AM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,313
Threads: 17,270
2nd Top Poster: jeff... (6,590)
Welcome to our newest member, chelliot
» Today's Birthdays
bwat
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
