» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  |
10-18-2007, 03:30 PM
#1 | | Blast gate construction Name: Trog City: Asheboro State: NC County: Randolph Join Date: Sep 2007  10-18-2007, 03:30 PM
Any recommendations for which glue to use when joining PVC to MDF? Was going to use epoxy, but was wondering if anyone had an easier sure fire product suggestion. As tight as they fit, it doesn't have to be bullet proof. | | Views: 350 |
10-18-2007, 05:53 PM
#2 | | Administrator
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 39 Avg Visit Freq/Week = 7.00 over 180 days | Re: Blast gate construction I have found that Polyurethane glue stick just about anything to anything. Try some Gorilla glue, but scuff up the PVC with some sandpaper first.
Dave
__________________   Nothing left to do but smile, smile, smile
--Dr. Seuss
10-18-2007, 11:32 PM
#3 | | Executive Vice-President Libraries Administrator
Name: Rob City: Hendersonville State: NC County: Henderson Join Date: Nov 2005 Age: 67 Avg Visit Freq/Week = 6.88 over 180 days | Re: Blast gate construction Dave's got it dead-on! Here's a picture from my Album showing how I made some for my shop -- I used a coarse rasp on the PVC to get some deep scratches to improved the bond and used Gorilla Glue (polyester resin glue) that fills any gaps quite well.  Setup for glue  Finished (see foam in gaps).
Go to this part of our Link Library to see three examples of methods used by others (I patterned mine after the one shown by Terry Hatfield in the 3rd link).
__________________
Rob Payne  Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way! |
10-18-2007, 11:37 PM
#4 |
Name: Trog City: Asheboro State: NC County: Randolph Join Date: Sep 2007 Avg Visit Freq/Week = 2.10 over 180 days | Re: Blast gate construction Great. Anything I should know about the Ape Sticky? Never used any before. Fumes? Skin issues? Does it foam rapidly? |
10-19-2007, 01:15 AM
#5 |
Name: Alan Schaffter City: Washington State: NC County: Beaufort Join Date: Dec 2005 Avg Visit Freq/Week = 6.69 over 180 days | Re: Blast gate construction Yup, poly glue and roughing the pvc are the ticket.
Something to think about- instead of using two sections of pipe I made my blast gates with a section of pipe on one side, and half of a pipe connector on the other side. That way my blast gates have male and female sides. I can remove, relocate, or work on my blast gates very easily. |
10-19-2007, 12:58 PM
#6 |
Name: Dave Snider City: Advance State: NC County: Davie Join Date: Oct 2007 Age: 65 Avg Visit Freq/Week = 0.12 over 180 days | Re: Blast gate construction Originally Posted by Trog777 Great. Anything I should know about the Ape Sticky? Never used any before. Fumes? Skin issues? Does it foam rapidly? Quite honestly, the best glue I have ever used. Just don't get it on your skin. It will have to wear off.
It does foam pretty quickly, but always be sure to wet one side with water before applying the glue and assembling. Normally sets up in a couple hours.
Dave in NC |
10-19-2007, 01:42 PM
#7 |
Name: John City: Raleigh State: NC County: Wake Join Date: Sep 2005 Avg Visit Freq/Week = 4.36 over 180 days | Re: Blast gate construction The foam is not as strong as the cured glue, so make sure you have a tight fit and clamp, if the glue can push the joint apart as it foams.
I will disagree with others, I don't use ape sticky for anything other than joining dissimilar materials. I agree with the recent Fine Woodworking test, polyurethane glues are the weakest when gluing wood to wood. I like Titebond III.
__________________
"Anything worth cutting down a tree for, is worth doing right."
Cut to size, and hammer to fit. |
Posting Rules
Members: 3,663
Threads: 25,093
Top Poster: DaveO (14,701) | | Welcome to our newest member, quaffin1 | |
