» Announcements |
The Woodworking Source Grand Opening
Saturday November 22
» Online Users: 69 |
| 22 members and 47 guests |
blackemmons
dave "dhi"
dino drosas
FredP
fsdogwood
G_ville_worker
jeff...
Makinsawdust
matt roberts
NC Scroller
PeteM
PLC'woodart
Robert Brunke'
rsitzejr
saw4you
sawman
Sealeveler
Tarhead
TopKnot
TracyP
| Most users ever online was 180, 04-22-2008 at 12:18 AM. |
07-19-2008, 09:34 PM
#1
This Space for rent
City: Greensboro
State: NC
County: Guilford
Avg Visit Freq/Week = 4.43 over 109 days
Wood storage: another question re garage
I read thru a few of the threads before posting this, didn't see an exact answer, so...
I've got a stock of cherry/oak boards already finish-cut, mostly 3/4-1" thick, 3-4" wide to be stored in an attached garage - temp and humidity won't be as good as the living room, but wife is happier! Anyway, besides elevating them off the floor with scrap wood, and keeping them separated and supported with thin even wood scraps (I believe the phrase is stickered), is there anything else necessary? Should the ends be painted (and if so, with what?)
Thanks in advance!
07-19-2008, 09:46 PM
#2
Libraries Administrator
City: Hendersonville
State: NC
County: Henderson
Avg Visit Freq/Week = 6.78 over 125 days
Re: Wood storage: another question re garage
Larry, if your stock is kiln-dried lumber, then you don't need to paint the ends. Technically, you don't need to sticker them either, but the advantage is that they will all acclimate to the storage space equally. If this is also the location of your shop, then you should be fine to take the material from your stockpile and use it immediately; however, if you have your shop in another location, then you'd be better taking what you need into the shop space to acclimate for several days unless conditions are identical.
__________________
 Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
07-19-2008, 11:38 PM
#3
Moderator Advisory Panel
City: Raleigh
State: NC
County: Wake
Avg Visit Freq/Week = 6.89 over 125 days
Larry:
You should be fine. If your wood is not kiln dired what you have described is fine. If you do not have a moisture meter, I suggest you buy or borrow one. Keep check the wood periodically until it reaches the desired moisture content, then away you go.
As Mcrabbit said all wood, kiln dried or not, should sit for awhile in the location where you plan to work it so that it acclimates to the temp and humidity of your shop.
Doug
__________________
Just because you can, doesn't mean you should. Unless you are Travis and you are considering buying a new tool!
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
» Stats |
Members: 2,072
Threads: 16,111
2nd Top Poster: jeff... (6,248)
| Welcome to our newest member, jcconv |
» Today's Birthdays |
None
