» Announcements |
The Woodworking Source Grand Opening
Saturday November 22
» Online Users: 66 |
| 20 members and 46 guests |
AndyBarnhart
BKind2Anmls
Bob T
Bryan S
FredP
Keye
Matt Schnurbusch
MikeH
peteb301
PeteM
PeteQuad
ptt49er
rcflyer23
SkintKnuckle
Sully
TedAS
thrt15nc
toolman
| Most users ever online was 180, 04-22-2008 at 12:18 AM. |
09-03-2006, 11:55 AM
#1
This Space for rent
City: Thomasville
State: NC
County: Davidson
Avg Visit Freq/Week = 3.02 over 125 days
Why is my cherry burning?
I thought the blade may be dull since the blade has cut alot of wood.
I went out and bought a new blade and it stills burns.
It is on a ridgid radial arm saw.
I have went slow medium and fast thru the wood.
I have checked square and it appears to be squared.
so what am i doing wrong?
09-03-2006, 12:17 PM
#2
Libraries Administrator
City: Hendersonville
State: NC
County: Henderson
Avg Visit Freq/Week = 6.78 over 125 days
Re: Why is my cherry burning?
You may be cross-cutting through the pieces too slowly. Yep -- too slow. Try cutting through a little more aggressively on some scrap pieces first.
HTH -- Rob
__________________
 Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
09-03-2006, 12:19 PM
#3
This Space for rent
City: Clemson
State: SC
County: Pickens
Avg Visit Freq/Week = 0.00 over 125 days
Ordinarily I would have suggested the things you have already checked. Since you did that, do you remember what you were doing on those cuts that didn't burn? Maybe you went slightly faster than those the did burn? I would usually suspect feed rate, I suspect that is still behind it.
09-03-2006, 12:38 PM
#4
This Space for rent
City: Horse Shoe
State: NC
County: Henderson
John, First let me explain that I don't own a radial arm and have had little experience with one. Ken and Rob have made good suggestions. If their ideas don't resolve the problem, try to determine if the blade is perfectly aligned with the path that it is taking i.e. 90 degrees. If the trailing edge of the blade is dragging as it comes through the cut it will most certainly burn regardless of how sharp it is.
Cherry is one of my favorite woods to work with and I keep my tools sharp. Nevertheless, I get burn marks if I'm not giving it 100% of my attention. Sometimes I think it burns because I look at it too hard.
Roy
P.S. I have noted however that I don't get burn marks using a hand plane or chisel.
09-03-2006, 12:39 PM
#5
This Space for rent
City:
State:
County:
Any climbing going on while you were cutting? Sometimes a radial arm saw wants to grab the wood and climb and that results in a binding/burning cut.
Is the blade grabbing as you cut? Perhaps the tooth configuration you are using is too fine for this operation. Sometimes for rough cuts on a radial arm saw, I never use it for finish cuts as I don't find them to be very accurate for long, I use a combination blade and although I don't get quite as smooth a cut I don't get the burning either.
Is your radial arm flexing as you cut/are you pulling straight as you cut? Both of these situations will cause the blade to pinch a little and get burn marks like the ones you have pictured.
Is your fence straight? Seems to be a ridiculous question but if it is not straight then as you cut the wood while pushing against it to hold it against the fence when enough wood is cut the remainder of the piece can flex and that can pinch the blade.
Is your wood straight/jointed? If it is slighly bowed, even a little bit, when you cut part way through the remainder can flex and that can pinch the blade.
Sometimes cherry just wants to burn but usually when you see burn marks like you have the blade is pinched during the cut somehow.
09-03-2006, 12:40 PM
#6
Asst. Webmaster Senior Moderator
City: Clayton
State: NC
County: Johnston
Avg Visit Freq/Week = 7.00 over 125 days
Cherry is bad about burning. The wood has a high sugar content. In addition to your feed rate you might want to check that you don't have a toe in or out on the blade. Radial arms saws can be touchy to dial in perfectly.
Dave
__________________
  Nothing left to do but smile, smile, smile
--Dr. Seuss
09-03-2006, 12:49 PM
#7
This Space for rent
City: APO
State: AE
County: ARMY
Avg Visit Freq/Week = 4.37 over 125 days
One thing you can do is push the radial arm saw rather than pull it. You can control the feed rate across the cut. I hope this helps you.
__________________
"As iron sharpens iron, so one man sharpens another." (Proverbs 27:17)
“Our doubts are traitors; they make us loose the good we oft might win by fearing to attempt”
“If I had my life to live over again, I'd be a plumber.” Albert Einstein
09-03-2006, 01:09 PM
#8
City: Hope Mills
State: NC
County: Cumberland
Avg Visit Freq/Week = 6.94 over 125 days
didn't think you were supposed to push RAS's? it's ok with Sliding Compund Miter Saw, but not RAS for some reason?
__________________
Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it. Henry David Thoreau
They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin
09-03-2006, 01:18 PM
#9
This Space for rent
City: Bolivia
State: NC
County: Brunswick
Avg Visit Freq/Week = 5.99 over 125 days
I have owned and still use a RAS for crosscutting. What you are seeing can be fixed with a complete alignment of your saw. Your instuction book will lead you through the process. Take it step by step as each step is dependent on the accurate completion of the prior step. Pay particular attention to the skew adjustments. It appears your blade is not absolutely parallel to the cutting line. That's different from the cut line being perpendicular to the fence. It's similar to the blade not being parallel to the miter slot on a tablesaw.
I'm sure your problems will be long gone with a good and careful alignment.
BTW, cherry and maple are two woods that contain lots of sugar. That's the reason they burn so easily. But a well set up saw, with sharp and proper blade, should not cause burning on either
09-03-2006, 02:59 PM
#10
This Space for rent
City: Thomasville
State: NC
County: Davidson
I will check my alignment again.
I must of misunderstand something when you use the radialarm saw.
when you use it i thought you where supposed to push the blade into the wood(away from you). Vs pulling the blade toward you.
Have i been using my saw wrong?
09-03-2006, 03:26 PM
#11
City: Clayton
State: NC
County: Johnston
Yes, you pull the blade to you. That action causes the wood to push against the fence. I don't think that it is very safe to push the blade towards the fence. That could be some of your burning problem.
Dave
__________________
--Dr. Seuss
09-03-2006, 03:31 PM
#12
This Space for rent
City: Stovall
State: NC
County: Granville
Got the moisture content of that cherry? Could be it's a little wet, that could cause the wood to burn also. Don't ask me how I know that  .
__________________
"Do, or do not. There is no 'try'." -- Jedi Master Yoda
09-03-2006, 03:47 PM
#13
This Space for rent
City: Bolivia
State: NC
County: Brunswick
Nope, pull it evenly without too much speed.
09-03-2006, 04:57 PM
#14
This Space for rent
City: Iron Station
State: NC
County: Lincoln
Avg Visit Freq/Week = 5.82 over 125 days
I believe you will find your cutting feed rate is too slow. I use a radial arm a lot and the same thing happens if I feed my sawmill, molder and table top router. Cherry burns easily in fact all wood burns pretty easy especially the harder woods if the feed rate is off.
09-03-2006, 06:07 PM
#15
State: NC
County: Henderson
We had a discussion about push versus pull on RAS several months ago -- I am a strong proponent of the push cut for cross-cutting since it is not a climb cut. The blade is pushing the stock toward the fence and is cutting the same way a table saw cuts. The stock must be held down as there is a slight tendency for the stock to lift. With a pull cut, the teeth may grab as the blade tries to climb onto the stock. And, as we said the last time when this was discussed, I never rip cut on a RAS because I believe it is too dangerous (DAMHIKT). Was this cherry cut with a pull cut? If so, that may explain the burning (along with the other factors DaveO mentioned) -- you may have taken a slow pull to avoid grabbing -- my recommended faster cut is with a push cut with a sharp, trued blade.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Cherry stain
Alan in Little Washington |
General Woodworking |
13 |
07-27-2006 02:41 PM |
Finish on cherry
Tom Dunn |
Finishing |
12 |
06-27-2006 04:14 PM |
Looking for 12/4 Cherry
mtrager |
Where Can I Find, Buy or Sell |
2 |
04-30-2006 10:48 PM |
Burning on shaper
windknot |
Power Tools and Their Use |
2 |
01-11-2006 12:51 AM |
