I picked up a mini-Ligno E/D and the manual is almost non-existent. Can someone explain the 'best practices' for using a pin-type moisture meter ?
For example, I've heard that you should cut off the end of a board before testing. How far back ?
The meter comes stock with 3/16" pins ? Should I be using the 7/16" pins instead ?
The manual provides a MC correction table based on the temperature of the lumber being tested. How does one estimate the temperature of the wood when the ambient temperature varies from, say, 70F to 90F (typical summer day) ?
Just to show my ignorance
a simple stab into the end of the 4/4 green walnut I bought from Jeff last fall puts the MC at <6%.
-Mark
