Originally Posted by cll
Is there any suggestions as to who I can call to help clear felled oak & pine trees and mill them into lumber in the Raleigh area? Or mill on-site, etc?? About how much woud it cost, etc? 8 to 36 in dia trunks
Any help or connections on this would be appriciated.
.gif)
Charles if you look up in the top Brown menu you will see a listing for Woodworking in NC. In that drop down menu is a list of
sawyers by region you might try contacting some of them and see if they can help you out. I know that Jack Murdock does some great work, but I am not sure if he is mobile.
Cost is going to be very dependent on the mill operator and if they need to come to you or you can bring the logs to them. Expect to pay a blade charge if metal is found in the logs, which is a very common problem with "urban" timber. Log diameter at the narrow end is the most important measurement, as the log will have to be squared up first before milling into boards. Anything under 12" dia at the top end isn't going to result in much lumber and should be put on the lathe
Good luck in your quest and keep us posted. There is nothing like going from a tree to furniture, it give you a much greater appreciation for the wood and all that goes into it.
Dave
__________________
Nothing left to do but smile, smile, smile
Honestly Honey, that will cost around
$100 $150 $200, and I need a few more tools.
--Dr. Seuss
