| Wood This is the place to discuss wood. Species, Properties,etc. |
| | LinkBack | Thread Tools | Display Modes |
| | #1 |
| Member | Finally maxed out my mill Well been waiting for just the right sized log to max out my woodmizer. I hit the limit today with around a 40" small end Pecan log. Pecan is member of the Hickory family and pretty rough on bands, it'll set bands on fire. I had to sharpen a few bands to almost a 0 degree hook angle, with water and Joy dish washing soap lube, I was able to creep the blade along through the 28"sq cant without stalling the engine. For those of you who have sawed with a woodmizer you'll appreciate that I had to raise the cant over the bed stop blocks and push the cant over on to the track a little bit to tweak out 28". Let's just say a 28" sq tree is right heavy. I timed the cut, it took 1 minute 38 seconds for my woodmizer to cut through 28" wide 14' long pecan. This is the first time I have maxed my mill and it just had to be pecan - least I know what the mill will do now... I must say it's quite a good feeling sawing out over 1000 board foot from just one log. Sorry no pictures, didn't bring my camera along today... Now if we can just get DaveO to post his 10,000th reply, life will really be good, won't it? |
| | #2 |
| Member | Re: Finally maxed out my mill Originally Posted by jeff... 1000 board feet out of a single log? Now _that's_ impressive. Wood good. More wood...better
__________________ Bas. I don't need it. I just want it. |
| | #3 |
| Member | Re: Finally maxed out my mill I do like watching large machinery get bogged down...from a safe distance, of course. ![]()
__________________ The Tao of Tom: Be good to your pet(s). Invest in good Karma. |
| | #4 |
| Member | Re: Finally maxed out my mill Jeff: Can you give us some pics of the sawed lumber? Those must be some NICE boards. Any of it for sale?
__________________ I'm a great believer in LUCK! I find the harder I work, the more I have of it. Thomas Jefferson |
| | #5 |
| Member | Re: Finally maxed out my mill |
| | #6 |
| Member | Re: Finally maxed out my mill Thats alot of lumber from one log! ![]() Reggie if you want pecan just let me know. Jeff, no pictures, must have been a dream ![]()
__________________ Beaver Branch Sawmill 910-540-0705 |
| | #7 |
| Member | Re: Finally maxed out my mill Originally Posted by jeff... ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Hey Jeff, Sounds like work !!! ![]() Did you slice any boards 8 or 9 quarters thick? Might want to dull some blades buiding a rocker with it. I did a silverware box in Hickory/Pecan maybe 15 years ago, and the grain/ color was superb. The QS Sycamore rocker is underway...will post some progress pictures in the Gallery soon Don |
| | #8 |
| Member | Re: Finally maxed out my mill Originally Posted by Touchwood Don, Let me check and see what pecan logs are out there that are not customer logs and I'll get back to you.
| | #9 |
| Member | Re: Finally maxed out my mill stuff that big I split using the lucas mill until under 30" and then put the "small" section on the woodmizer. Pecan sucks to cut. I dont saw that stuff any more for anyone. Its harder than purpleheart
__________________ http://www.sawmillnc.com 704-258-8985 (cell) its sprint/nextel so I may not always get the call |
| | #11 |
| Member | Re: Finally maxed out my mill Originally Posted by Kyle Wow! Ive never used Pecan before but ive turned some Purple heart, that stuff is awful! it dull my tools so fast I didnt even rough it out before my gouge was dull already
But the color is Nice!![]()
__________________ My house is full of wood shavings....... |
| | #12 |
| Member | Re: Finally maxed out my mill I have been watching for an opportunity to get a piece of pecan or hickory. My oldest daughter wants a bow and I am thinking of building her one of these: http://www.vintageprojects.com/archery/Flatbow.pdf The info is a little out of date. It says you can find a lemonwood stave for $1.75 to $3. They have gone up a little: http://www.constantines.com/index.as...OD&ProdID=2871 Ouch! Osage orange is another possibility but there is some difficulty in getting the grain orientation and spawood/heartwood mix just so. I have read some FAQs that say I should be able to use white oak with decent results and I have a little, but supposedly pecan/hickory is less prone to splitting and breaking than white oak. |
| | #13 |
| Member | Re: Finally maxed out my mill Originally Posted by Kyle I got a few more logs to cut from this tree, then I'll be done - been putting it off but I'll have to finish it up soon. There is one wild looking three limbed crotch section left. It's way to big for the mill so we are going to open it up with the chain saw first. Wished I had your Lucas slabber Kyle, it sure would make life easier...
I snapped a pin holding the forks to the bobcat and bent the other one - log came rolling off the bobcat and rolled quite a distance on the ground before it came to a stop. I replaced the pins with 1" x 8" grade 8 (Made in American - Rockford IL) bolts. I'll break something else before I snap one of those. It really would be nice to set up around the log where it is instead of dragging the log to the mill. Little does everyone know - to be a sawyer is to be a jack of all trades, something always needs fixing...
__________________ Mills Custom Sawing |
| | #14 |
| Member | Re: Finally maxed out my mill Originally Posted by jeff... Massive hunks of wood rolling around...........I think you can add that being a sawyer is definitely not for the faint hearted !!!!!
__________________ " I get knocked down but I get up again" - Chumbawamba |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| the mill | bman | Power Tools and Their Use | 13 | 06-27-2007 05:35 PM |
| need advice for a saw mill | taandctran | Old Off Topic Forums | 6 | 03-26-2007 09:45 AM |
| Pen Mill Help | JRD | Woodturning | 5 | 11-15-2006 07:01 AM |
| local saw mill | Travis | Where Can I Find, Buy or Sell | 14 | 06-30-2006 09:49 AM |
| Circular saw mill? or Bandsaw mill? | NCPete | Power Tools and Their Use | 10 | 04-02-2006 07:50 AM |
