02-06-2008, 12:06 PM
#1
Advice? - salvaging oak flooring
City: Rutherfordton
State: NC
County: Rutherford
Oh wise ones-
We are almost done moving Mom & Dad into their new digs  , which means that the demolition on the old house is coming soon  .
I want to TRY to salvage at least some of the oak floor boards. I THINK it's T&G, so I'm presuming it's toe-nailed. Any advice? Recommended tools?
I'm thinking of starting at the cold air return because I can get under the ends of a few boards.
__________________
"Live like no one else, so later, you can LIVE LIKE NO ONE ELSE!"
-Dave Ramsey
02-06-2008, 12:42 PM
#2
City: Ivan's Corner (Monroe)
State: NC
County: Union
Avg Visit Freq/Week = 7.00 over 180 days
Re: Advice? - salvaging oak flooring
Almost all oak flooring sold is t & g. Salvaging will be a challenge at best. Try & figure out which end they finished on & work your way back into it prizing against the tongue side and at the bottom of the board. On really old homes it will be nailed entirely with cut nails. If it's nailed with a flooring nailer the last few rows could still be cut nailed because it's hard to swing a flooring hammer that close. Get a gorilla bar or crowbar & a good long pincer type nail puller to pull the nails on through. Don't try to back them out. Pry against a floor joist whenever possible. The subfloor will flex & possibly break. When reinstalling, avoid nailing near an old nail hole and BE SURE THERE ARE NO NAILS IN A PIECE BEFORE YOU CUT IT!
GOOD LUCK!
02-06-2008, 01:02 PM
#3
City: Raleigh
State: NC
County: Wake
Avg Visit Freq/Week = 3.58 over 180 days
Charles,
Not sure what you want to do with the flooring, or any other salvagte material, but you might check with a deconstruction group. It's out of the way for the local affiliate, but the Wake county chapter of Habitat for Humanity has a decon group; flooring is just one of the things they will salvage. I think the closest affiliate to you is Asheville.
Ray
__________________
I cut that board twice and it's STILL too short.
02-06-2008, 01:33 PM
#4
City: Raleigh
State: NC
County: Wake
Avg Visit Freq/Week = 0.08 over 180 days
You could cut the nails with a sawzall.
02-06-2008, 01:40 PM
#5
State: NC
County: Union
Nailed properly, oak flooring will be nailed <16" o.c. For 2-1/2" oak flooring this come back at >5 nails per square foot. If it's old 1-3/4" flooring, even more - and it's likely nailed with cut nails. I don't think I could afford the blades to cut the former & couldn't find a blade to cut the latter - but it's worth a try.
02-06-2008, 01:52 PM
#6
City: Raleigh
State: NC
County: Wake
They make diamond coated blades.
02-06-2008, 02:01 PM
#7
City: Rutherfordton
State: NC
County: Rutherford
Avg Visit Freq/Week = 3.50 over 180 days
GOOD LUCK!
Dennis,
Thanks for all the info.
__________________
-Dave Ramsey
02-06-2008, 02:04 PM
#8
City: Rutherfordton
State: NC
County: Rutherford
Originally Posted by Ray Martin
Charles,
Not sure what you want to do with the flooring, or any other salvage material, but you might check with a deconstruction group. It's out of the way for the local affiliate, but the Wake county chapter of Habitat for Humanity has a decon group; flooring is just one of the things they will salvage. I think the closest affiliate to you is Asheville.
Ray
Ray,
I have some water and pet damaged oak flooring in my own house that needs to be replaced. Not sure if the floor boards will be compatible. but I won't need a lot - maybe 10-15 sq. ft. If it comes up easy  , with a little investment in a metal detector, once I have a planer, I've got FREE WOOD.
__________________
-Dave Ramsey
02-06-2008, 03:05 PM
#9
City: Mebane
State: NC
County: Alamance
Avg Visit Freq/Week = 0.47 over 180 days
I just did this back in late 2004 in my 1927 bungalow in MA. The wood was standard 2" oak T&G installed with cut nails.
I carefully pried up each board with a "flat bar" (I think one of the trade names for similar tools is "Wonderbar.") and tapped the nails out after getting each board up. They come out easily when the wood is dry, and they also pry up easier when everything is dry (such as now -- during the low-humidity time of year). You have to be careful around each butt joint and just work on prying up the whole "course" at a time before trying to separate the individual pieces.
The old wood is generally of better quality than the mass-market products offered today -- partially because the wood came from older-growth trees.
BTW, you can easily mill tongues and grooves into the ends if you need to cut any of the pieces due to damage, etc.
I re-laid this flooring (had to remove around some old fire damage that was all covered with W-W carpet) with new flooring mixed in and the whole lot sanded and stained with Golden Oak stain to get a better match between new and old. It came out well (I'll have to post pics later).
__________________
Time flies like an arrow.
Fruit flies like a banana.
Reason: typo, clarifications.
02-06-2008, 03:12 PM
#10
City: Rutherfordton
State: NC
County: Rutherford
Steve,
That's encouraging. Thanks a bunch.
__________________
-Dave Ramsey
02-06-2008, 03:29 PM
#11
City: Mebane
State: NC
County: Alamance
Just a couple of other things I thought of after posting:
If there were gaps in the flooring when it was down, you may have build-up of finish in there. You can either scrape it to get perfectly-tight joints or leave it and the floor will look like it has some years on it.
I like the old look so didn't worry about it unless there was "excessive" buildup of finish. A painter's scraper lightly along each edge gets rid of any dirt or sludge that got down there.
It really is a lot less work than it sounds like. Once you get your rhythm pulling it up, it really goes fast!
A 10 x 12 room @ $3.00 sq ft will cost you almost $400 in material costs for new material. That's using "mainstream" clear unfinished flooring from the BORG.
I just think the old stuff also looks better.
__________________
02-06-2008, 04:25 PM
#12
City: Raleigh
State: NC
County: Wake
Charles,
I stopped by a decon site not far from here where my Habitat friends had just finished pulling up several rooms of oak t & g flooring. They tell me you should use a number of Wonderbars (flat pry bar). Hammer the bar under the tongue side, push the bar toward the board to be pulled, then pull back away from the board being pulled. They showed me the results... they will sell most of the material at the ReStore. Even with very old, rather brittle wood, they were able to save most of it.
Ray
__________________
02-06-2008, 04:43 PM
#13
City: Rutherfordton
State: NC
County: Rutherford
Charles,
Ray
Ray,
Thanks for the legwork.
__________________
-Dave Ramsey
02-06-2008, 07:02 PM
#14
City: Mebane
State: NC
County: Alamance
Pics, as promised.
What I had was sound oak flooring, with a rather large piece that had been taken out, covered by particle board (!) and covered up with w/w carpeting. I knew there was something weird going on under the carpet, but I had to pull the rug up to find out what!
There had been a small fire in the living room -- probably a Christmas tree, judging by where it was but maybe started by a candle. Embers must have popped off, as there were burn marks 8 feet away in some places. I had to patch some and was able to sand away others.
Over in the dining room, there was the old oak flooring plus evidence that the dining room/kitchen wall had been moved and that there had been a built-in hutch in the dining room -- thus an area with maple (kitchen), oak (dining room) and subfloor (built-in).
In order to make it look decent, I had to pull up the flooring in the living room out past the fire damage, into the dining room pas where pieces had been removed, then reinstall everything. Of course, I was about 150 sf short of flooring.
The first shot shows where I tore up the particle board in the living room. The second shot shows the flooring trifecta. The third shot shows the dining room after I finished the old floor. It came out nice.
__________________
Reason: pic labeling
02-06-2008, 07:12 PM
#15
City: Mebane
State: NC
County: Alamance
Here are some more,showing where the new BORG oak went in, and the dining room before sanding. It blended in a lot better after the sanding and staining. The only way you could really tell was that the new flooring fit together a lot tighter. If I was to do it again, I would mix the flooring randomly as it would have hid easier.
I thought I had taken a closeup of the patch area but apparently I did not. I cut a straight line across, put one piece of old flooring all the way across (about 7 feet), then ran shorter old flooring on the other side that ran in the same orientation as all the rest of the floor (so that there was one piece that was perpendicular). You can barely make it out.
Bottom line here is that you can get a really nice floor from reusing the old stuff!
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
flooring stapler
bman |
Power Tools and Their Use |
5 |
12-07-2007 08:16 AM |
wide board flooring
bman |
General Woodworking |
11 |
03-29-2007 12:02 AM |
rubber flooring
rhett |
Where Can I Find, Buy or Sell |
4 |
01-18-2007 09:46 PM |
» Stats |
Members: 4,228
Threads: 28,170
Top Poster: DaveO (15,032)
| Welcome to our newest member, Bill Clemmons |
