North Carolina Woodworker
Changes to DQ as of 12/1/2008 Very important that you read
Go Back   North Carolina Woodworker > Woodworking > Wood
Notices
Wood This is the place to discuss wood. Species, Properties,etc.
» Announcements
Everyone Log on at 9:00PM Thursday December 4th to set a members online record.
Featured Photos
by Hook
24863 photos
9957 comments
by Otto Matic
24863 photos
9957 comments
by gordonmt
24863 photos
9957 comments
by rausrh
24863 photos
9957 comments
Closed Thread
Old 01-10-2008, 02:44 PM   #1
City: Davidson
State: NC
County: Cabarrus
Threads: 16
Avg Visit Freq/Week
= 2.80 over 30 days
What do the numbers 8 and 4 mean? And please don't laugh too hard I really don't know. One of these days I'll have enough experience to consider my self a rookie...
Show Printable Version Email this Page   Quote this post in a PM to BarryC
Old 01-10-2008, 02:58 PM   #2
jeff...'s Avatar
City: Stovall
State: NC
County: Granville
Threads: 455
Avg Visit Freq/Week
= 6.77 over 30 days
Barry to answer your question without much rabbit chasing. Say eight quarter, not to state the obvious but there are four quarters in an inch so eight quarter would be 2 inches, twelve quarter would be three inches, etc...
Easy enough... Now the more difficult to understand (and explain)
__________________
"Do, or do not. There is no 'try'." -- Jedi Master Yoda
Show Printable Version Email this Page   Quote this post in a PM to jeff...
Old 01-10-2008, 03:00 PM   #3
sediener's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 33
Avg Visit Freq/Week
= 5.83 over 30 days
Those designate the thickness in quarter inches.
8/4 = 2 so it is a little over 2" thick.
4/4 =1 so it a little over 1" thick.
Good sawyers give you a bit over the actual 1" or 2" to account for shrinkage during drying.
- Steve
Show Printable Version Email this Page   Quote this post in a PM to sediener
Old 01-10-2008, 03:17 PM   #4
City: Davidson
State: NC
County: Cabarrus
Threads: 16
Avg Visit Freq/Week
= 2.80 over 30 days
Thats easy enough! So neither number has anything to do with width? How would an 8/4 that is 5 inches wide be noted? 8/4 x 5? or am I over complicating this?
Old 01-10-2008, 03:30 PM   #5
walnutjerry's Avatar
City: Salisbury
State: NC
County: Rowan
Threads: 102
Avg Visit Freq/Week
= 7.00 over 30 days
Barry---------you have stated it correctly.
Lumber grading and terms can be confusing when you are not familiar with the terminology. Go to the National Hardwood Lumber Association site and browse the standards for grading etc. I think there is a glossary on the site but not sure. Been a while since I browsed the site.
http://www.natlhardwood.org/
Jerry
__________________
We make a living by what we get...............We make a life by what we give
Show Printable Version Email this Page   Quote this post in a PM to walnutjerry
Old 01-10-2008, 03:35 PM   #6
Bas is offline Bas
Asst. Webmaster
Bas's Avatar
City: Cary
State: NC
County: Wake
Threads: 119
Avg Visit Freq/Week
= 7.00 over 30 days
I don't think there's a real standard for describing the width and length. A typical description for lumber is "8/4 hard maple, 8-10' long, 4-7" wide" Boards are never uniform, the thickness is typically the only "constant" when buying a load of lumber.
Generally, boards are between 6'-10' long, and 5" - 10" wide. Longer/ wider boards sell for more, shorter/ narrower boards sell for less.
(Of course, _some_ people insist on 40ft boards for their projects.....)
If you got all that, ask about board feet You may also want to check out episode 4 on http://thewoodwhisperer.com/
__________________
Bas.
I don't need it. I just want it.
Show Printable Version Email this Page   Quote this post in a PM to Bas
Old 01-10-2008, 03:44 PM   #7
jeff...'s Avatar
City: Stovall
State: NC
County: Granville
Threads: 455
Avg Visit Freq/Week
= 6.77 over 30 days
whoops hit the Submitt Reply button by mistake (my secret to high post count )
Anyways on a saw mill there are usally 3 scales
* a regular inch scale graduated in 16ths of an inch
* a softwood quarter inch scale
* a hardwood quarter inch scale
Width and general cant sawing, the guy running the saw mill will use the regular inch scale ok - so I have a bunch of 6" wide boards to cut I use the inch scale for width. If I'm cutting softwood I use the softwood quarter inch scale for thickness. lets say I get an order for a bunch SYP 1x6's I would use the regular inch scale for my width and the softwood quarter inch scale for thickness. Why because when softwood is dry and has finished drawing up, I could expect a finished board of 3/4" thick by 5 1/2" wide... Softwood like SYP, Hemlock, Spruce, Cedar, etc... rarely is kiln dried to anything below 15% moisture content. So the Softwood quarter inch scale will saw to a thickness of 1" ~ 1 1/8", so when the lumber shrinks it will dress out @ 3/4" thick. If it don't make 3/4" then it's considered cull.
The hardwood scale is the same principle but it will leave a thickness of an 1/8 to a 1/4" over. So freshly sawed off the log (NOT Kiln Dried) 4/4 would measure 1 1/8" ~ 1 1/4" Hardwood is usually dried to 6 ~ 10% moisture content thereby shrinking even more than softwood. So you need to start with a thicker board fresh off the log to meet your final thickness target once the lumber is fully dried.
Here is an easy way to remember thickness take a fresh cut board, measure it's thickness and subtract 1/4 for softwood and 3/8 for hardwood. Assuming proper during technique is used that will be your finished thickness.
Also another easy way to remember dry lumber is subtract 1/4 for a final target thickness and 1/2 for width when looking at dry rough cut lumber. So lets say your looking at a kiln dried rough cut board that was cut @ 4/4x6 when it was sawn off the log. The board will probably measure a little under 6" wide and right around 1" in thickness. By the time you joint and plan the board it should clean up to a min of 3/4 x 5 1/2 - if it cleans up thicker thats better for you but a minium of 3/4 x 5 1/2 is the rules.
One thing I caution folks on is buying green lumber that is miscut... 4/4 hardwood should measure 1 1/8 to 1 1/4" and softwood 1" ~ 1 1/8". Make sure your saw mill guy is using the right scale and not just cutting by the regualr inch scale or you'll wind up with a bunch of 5/8 ~ 1/2" thick boards and get ticked off .
Thanks
__________________
Old 01-10-2008, 04:18 PM   #8
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 157
Avg Visit Freq/Week
= 3.73 over 30 days
excellent post Jeff, clear as a bell.
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Show Printable Version Email this Page   Quote this post in a PM to DavidF
Old 01-10-2008, 04:54 PM   #9
Kyle's Avatar
City: Iron Station
State: NC
County: Lincoln
Threads: 63
Avg Visit Freq/Week
= 7.00 over 30 days
That is assuming all your wood is uniform, knot free and equipment is 100% in tune. It also makes a difference on the type of blade and the tension applied as well as the lubricant.
We sawyers all know our blades never waiver and tension is always 110%
For hardwood I use the grade scale which is 1 and 1/8" for a 4/4 board. On a woodmizer that scale is already set as standard on your machine on others I dont know.
For softwood I use actual measurement for scale. It is graded differently than HW.
__________________
http://www.sawmillnc.com
704-258-8985 (cell) its sprint/nextel so I may not always get the call
Show Printable Version Email this Page   Quote this post in a PM to Kyle
Old 01-10-2008, 09:37 PM   #10
jeff...'s Avatar
City: Stovall
State: NC
County: Granville
Threads: 455
Avg Visit Freq/Week
= 6.77 over 30 days
Yeah never any wave, always sharp, never a tooth off pitch - In my dreams
__________________
Closed Thread
8 or 4 , sawn , wood
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Worm holes in rough sawn oak, what to do? Travis Wood 23 08-08-2007 02:54 PM
Quarter sawn white oak sammy Where Can I Find, Buy or Sell 4 09-08-2006 10:40 AM
Planing rough sawn pine Richgod Where Can I Find, Buy or Sell 5 04-18-2006 02:12 PM
Rough Sawn Lumber Davis General Woodworking 7 01-10-2006 02:18 PM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,136
Threads: 16,390
2nd Top Poster: jeff... (6,363)
Welcome to our newest member, Notorious T.O.D.
» Today's Birthdays
Red Sonja (39)
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
