» Announcements | Everyone Log on at 9:00PM Thursday December 4th to set a members online record.  | » Online Users: 61 | | 26 members and 35 guests | | AndyBarnhart , Bas , cpowell , cskipper , Dan Bowman , Dcoop , farmerbw , flatheadfisher , FredP , GeorgeL , jeff... , Partman , ptt49er , RayH , redhawknc1 , Robert Brunke' , rsitzejr , sapwood , sediener , Splint Eastwood , Tarhead , TedAS , TexasTimbers , torrice , TracyP , zapdafish | | Most users ever online was 180, 04-22-2008 at 12:18 AM. |  |
12-30-2007, 07:58 PM
#1 |
Name: Reggie City: Albemarle State: NC County: Stanly Join Date: May 2007 Avg Visit Freq/Week = 7.00 over 30 days |
How do most of you "attach" templates for cutting out with your routers? We need to cut quantities of identical pieces, and I have found no real good method so far.
All input is welcome.
__________________
I'm a great believer in LUCK! I find the harder I work, the more I have of it.
Thomas Jefferson
12-30-2007, 08:07 PM
#2 |
Name: Bruce City: Apex State: NC County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 6.77 over 30 days | If piece has a "blind side" that won't be seen, then THREE screws through the template. I always use three, because if one failed there would still be two holding assembly. Double stick tape is a PITA for me. If I were making several multiples, I would add some vacuum tape and a fitting to template. Place on stock, turn on vacuum and route away. Joewoodworker.com has best price on vacuum tape that I know of. |
12-30-2007, 08:33 PM
#3 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 30 days | I like double stick "duct" tape. It is a little bit of PITA to work with but holds like the dickens.
Dave
__________________   Nothing left to do but smile, smile, smile
--Dr. Seuss
12-30-2007, 08:44 PM
#4 |
Name: Reggie City: Albemarle State: NC County: Stanly Join Date: May 2007 Avg Visit Freq/Week = 7.00 over 30 days | I have been using screws to this point. Has anyone ever tried a small amount of hot melt glue? I hate DS tape,  it's a REAL PITA. Thanx for the input so far.
__________________
Thomas Jefferson
12-30-2007, 08:53 PM
#5 |
Name: Bob City: Hillsborough State: NC County: Orange Join Date: May 2007 Avg Visit Freq/Week = 7.00 over 30 days | I'm a big believer in DS tape. My wife and I have used it extensively over that past few years for template work. Sorry, no help for you Reggie... |
12-30-2007, 09:00 PM
#6 |
Name: Jeremy City: Charlotte State: NC County: Mecklenburg Join Date: Mar 2006 Age: 30 Avg Visit Freq/Week = 6.77 over 30 days | I've been using DS tape as well -- usually the "turners tape" from WC. It's strong and easy to peel ... though can be a PITA when it sticks really good. |
12-30-2007, 09:11 PM
#7 |
Name: jeff... City: Stovall State: NC County: Granville Join Date: Mar 2006 Avg Visit Freq/Week = 6.77 over 30 days | If I'm going to free hand with a router then it's c-clamps, it's it's going on the router table then I'll use double sided duct tape like Dave. The tape reside cleans of with Naphtha - Wikipedia, the free encyclopedia
(lighter fluid) pretty easily. Just be careful with it, it is light fluid after all... Mineral spirits - Wikipedia, the free encyclopedia
also works pretty well, but not near as well at naphtha.
Thanks
__________________ "Do, or do not. There is no 'try'." -- Jedi Master Yoda |
12-30-2007, 09:14 PM
#8 |
Name: Mark City: Goldsboro State: NC County: Wayne Join Date: Mar 2006 Avg Visit Freq/Week = 6.30 over 30 days | If you are using screws, could you use several wire nails instead. extend them only a 1/4" past the template. Tap on, pry off. A small recess in the bottom of the template for the pry tool would speed it up.
Just a thought
__________________
My only regret in life is that I did not listen more and talk less
12-31-2007, 01:06 AM
#9 |
Name: Buddy City: Jamestown State: NC County: Guilford Join Date: Dec 2005 Avg Visit Freq/Week = 2.33 over 30 days | ^
Gofor,
That's a common way to do it in most furniture factorys. Use a good 1/2 plywood form, drive in some nails slightly larger than finish nails, clip off the heads and file to a sharp point. They will hold your stock just fine in most situations. If you are getting crazy with the amount of wood you are removing, you might need additonal holding. Are you shaping all the way around? You can use a lever clamp (can't think of the brand name) to help clamp it to the form also. |
12-31-2007, 03:13 AM
#10 | | Vice-President Libraries Administrator
Name: Rob City: Hendersonville State: NC County: Henderson Join Date: Nov 2005 Age: 66 Avg Visit Freq/Week = 7.00 over 30 days | Reggie,
Fellow North Carolina Woodworker member SteveD made a big order of Adirondak chairs several years ago and showed me the vacuum templates he used for pattern routing the cypress parts. It made the process very fast and left no scars on the wood. Each template simply had a weather seal tape around the perimeter and a 1/4" tubing connector to draw the air out between the template and the stock. All of the pieces were cut out on his router table against a starter pin using a pattern bit with the bearing running against the template side.
__________________
Rob  Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way! |
12-31-2007, 03:39 AM
#11 |
Name: jay City: Washington State: NC County: Beaufort Join Date: Apr 2006 Age: 36 Avg Visit Freq/Week = 7.00 over 30 days | I use DS tape and/ or hot glue.
1) There are several brands of DS tape though. Some work much better than others. The kind they sell at Walmart (can't remember the name) is horrible; it leaves a sticky mess that is hard to remove. At Lowes on the other hand they sell a brand (I think it's the 3M brand specifically) that goes on and comes off easily. I'm planning a Lowes run in the morning and will report back with the name brand I normally use.
2) Hot melt glue works well for a lot of applications. I sometimes use it for attaching temporary sacrificial fences on the tablesaw or router table. It normally leaves no residue on the pieces and pops off easily with a plastic putty scraper or glue spreader. I find the hot glue works best if you put down several evenly spaced dots around the workpiece, rather than trying to lay down a thin bead over the surface of the workpiece. For template routing hot glue works fine if you are not hogging off a bunch of material.
__________________
Humility is being corrected by your 4 year old on a woodworking project. |
12-31-2007, 09:10 AM
#12 |
Name: Joe City: Holly Springs State: NC County: Wake Join Date: Sep 2005 Age: 65 Avg Visit Freq/Week = 7.00 over 30 days | I find that with DS tape, little pieces hold just as well as large patches and are a lot easier to pop off. The brand is important and lately I've been using the stuff from Woodcraft. Before DS tape, I used 1/2" brads on the 'back' sides. |
12-31-2007, 10:21 AM
#13 | | Site Programmer
Name: Jim Campbell City: Hillsborough State: NC County: Orange Join Date: Feb 2006 Age: 38 Avg Visit Freq/Week = 3.03 over 30 days | I use a bit of hide glue and a sheet of paper.
The hide glue can be dissolved by hot water or denatured alcohol.
The paper ususally gives out when I twist the pattern off the piece.
Hide glue tacks up quickly.
__________________
"Its not about the destination, its about the joinery!"
12-31-2007, 02:03 PM
#14 |
Name: Gazzer City: Durham State: NC County: Durham Join Date: Aug 2006 Avg Visit Freq/Week = 3.73 over 30 days | Nails or screws if holes won't matter. Otherwise, I use carpet tape. This is a double-sided tape that is cloth rather than paper. It holds well (sometimes too well) and is relatively easy to remove. I just rub my thumb against it to pop up a corner and then roll it up and of.
-G |
12-31-2007, 05:21 PM
#15 |
__________________
Thomas Jefferson
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | HDF for Templates? | JackLeg | Wood | 12 | 12-03-2007 08:35 AM | | » Stats |
Members: 2,135
Threads: 16,387
2nd Top Poster: jeff... (6,363) | | Welcome to our newest member, rsellers | |
