» Announcements | Everyone Log on at 9:00PM Thursday December 4th to set a members online record.  | » Online Users: 74 | | 34 members and 40 guests | | Andy Casiello , blackemmons , Canuck , christopheralan , DaveO , Dcoop , Don Kohl , dpanda , erasmussen , flatheadfisher , Gofor , Gotcha6 , GregSmith , G_ville_worker , HillsboroughWW , jerrye , JohnW , Jonathan Dees , maomoonshiner , MikeF , Mrfixit71 , NZAPP1 , Ozzie-x , PeteM , Ralrick , redhawknc1 , Robert Arrowood , Robert Brunke' , Sealeveler , stave , TracyP , Travis Porter , Trent Mason , woodArtz | | Most users ever online was 180, 04-22-2008 at 12:18 AM. |  | |
04-11-2006, 07:38 PM
#1 | | Moderator
Name: Wayne City: Cary State: NC County: Wake Join Date: Dec 2005 Age: 61 Avg Visit Freq/Week = 7.00 over 30 days | Have a pretty elementary question. (from a typical newbie  )
If I am using solid wood for 3/4" plywood edge banding, how do I prepare the plywood edge? Do I just depend on the accuracy of my tablesaw or should I cut the ply a wee bit oversize and make a couple of passes with a flush trim bit, prior to securing the edge banding?
Thanks in advance for your suggestions.
__________________ ..............found out many years ago that Elbow Grease doesn't come in a bottle!!!! |
04-11-2006, 08:20 PM
#2 |
Name: D L Ames City: Fayetteville State: NC County: Cumberland Join Date: Oct 2005 Age: 50 Avg Visit Freq/Week = 0.00 over 30 days | Wayne, as long as you are getting a good straight, clean cut with your tablesaw blade then you should be able to cut your ply to the finished size (less the thickness of your band edging) then apply your banding.
D L
__________________ People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf. George Orwell (1903 - 1950) |
04-11-2006, 08:24 PM
#3 | | Member
Name: Steve DeWeese City: Horse Shoe State: NC County: Henderson Join Date: Oct 2005 Age: 44 Avg Visit Freq/Week = 0.23 over 30 days | Depending upon the quality of your blade, you may want to do a scoring cut first to prevent tearout on the bottom side of your crosscuts. A zero clearance insert also helps. Otherwise you should be fine to go straight from the tablesaw.
__________________
Home of the USS Crescent battle group.
04-11-2006, 08:45 PM
#4 | | Moderator
Name: Wayne City: Cary State: NC County: Wake Join Date: Dec 2005 Age: 61 Avg Visit Freq/Week = 7.00 over 30 days | Thanks Guys!
As a matter of fact I just installed a zero clearance insert on my saw today. The scoring idea, (along with a strip of painters masking tape) is what I will try.
Thanks again,
04-11-2006, 09:10 PM
#5 |
Name: Jim City: Mount Airy State: NC County: Surry Join Date: Apr 2006 Avg Visit Freq/Week = 4.67 over 30 days | Wayne
If you are using real solid wood as a banding on plywood I would highly recommend you attach it with either a tongue and groove cut or a v-cut. If you are using the roll of edge banding that you buy in the store, then, unless your table saw blade is a disaster, you should be able just to iron on the banding straight from the saw. Any roughness of cut will aid in the glue sticking.
Jim in Mayberry |
04-11-2006, 09:16 PM
#6 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 30 days |
__________________   Nothing left to do but smile, smile, smile
--Dr. Seuss
04-11-2006, 09:42 PM
#7 |
Name: Martin City: Winston Salem State: NC County: Davidson Join Date: Mar 2006 Avg Visit Freq/Week = 7.00 over 30 days | Wayne, have you given much thought to how you'll attach the edgebanding?
If you're planning to glue, keep in mind that edgebanding is the most difficult application of an adhesive. So you'll do well to head the advice above by using a method to increase the surface are of the glueline, by either going the v-groove route or using bisquits.
Good luck and let us know how it turns out.
__________________
My second name is Honey, you need to fix the ....... |
04-11-2006, 11:02 PM
#8 | | Moderator
Name: Wayne City: Cary State: NC County: Wake Join Date: Dec 2005 Age: 61 Avg Visit Freq/Week = 7.00 over 30 days | I am kinda leaning toward using biscuits. Never done it (ie face frame to the carcass). I may need to practice a little to ensure that I get the face frame aligned right. To date, I have only used my BJ to glue up panels.
I like the idea from DaveO, but I think that I have exhausted my router bit budget for the month, as a result of the Woodcraft router bit sale!
Thanks for all of the suggestions.
It seems that every project I get into raises more questions!  By the way, I am taking on that simple television stand for a daughter that I was asking about plans a few weeks back. We will just have to see what develops.
04-11-2006, 11:15 PM
#9 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 30 days | Wayne, using your biscuit jointer for this application is very easy. Just make sure to reference the adjustable fence off of the matching faces. And when you do the wood edging stack a couple pieces together to give the fence more bearing surface.
Also you could always leave the wood edging a little proud and then use a flush trim router bit to shave it down perfectly (WC has a couple of those in the $5 bit selection  , and if you didn't get one you can borrow mine.)
Dave
--Dr. Seuss
04-11-2006, 11:22 PM
#10 | | Moderator
Name: Wayne City: Cary State: NC County: Wake Join Date: Dec 2005 Age: 61 Avg Visit Freq/Week = 7.00 over 30 days | Thanks DaveO! I picked up a 1" flush trim bit last week, so I think that I am all set to go. I appreciate your tips on how to reference the BJ fence as well!
04-11-2006, 11:51 PM
#11 |
Name: Jim City: Mount Airy State: NC County: Surry Join Date: Apr 2006 Avg Visit Freq/Week = 4.67 over 30 days | Wayne,
I sure understand about having spent all one can, esp. at this time of year! But to you and all other "termites" out there, check out www.pricecutter.com They have very good bits and at the best prices I have found.
Yes, you can certainly use biscuits, assuming of course that the band is wide (or thick) enough to allow for the cut. I guess I have stayed away from biscuits because, after time, you can see the outline of the biscuit cut on the surface of the work. Don't know why you can with biscuits but not with tongue and groove but there are a lot of things I don't understand.
Keep up posted on how it goes.
Jim in Mayberry |
04-12-2006, 12:15 AM
#12 |
Name: Mark City: Goldsboro State: NC County: Wayne Join Date: Mar 2006 Avg Visit Freq/Week = 6.30 over 30 days | I do this quite a bit, as the budget requires me to use ply, and quite often cheap (i.e pine -hiss, hiss), but the object is to make presentable, serviceable furniture, in my case.
If making a full faceplate and gluing it to the ply carcass, I have found that running a shallow dado around the exterior edge of the face and the interior edge of the carcass pieces gives the best matchup and least grief. By shallow, I mean slightly less then the saw blade kerf, and I use a 60T blade to get a smooth enough glue-up surface.
If gluing the face pieces on individually, I spline the carcass and the pieces (not running all the way to the end on exposed corners) to get a good match. (Using this method, I also index the pieces to one surface as DaveO outlined). I usually use oak, etc, for the spline material.
I use plenty of support (ie featherboards, etc) when cutting the 3/4 (or 23/32) edge pieces and when cutting the splines to ensure the indexed surface stays flush with the fence for either the dado or spline cuts.
If there are any surface mismatches (and I always get some) I true them up with a hand plane or by sanding.
Hope this helps. I am definitely not one of the experts, but this has worked for me
__________________
My only regret in life is that I did not listen more and talk less
04-12-2006, 12:54 PM
#13 |
Name: Bob City: Cary State: County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 5.13 over 30 days | Hi Wayne,
Unless you have a real bad blade you can go from the saw to glue up when doing the banding on the plywood.
It you ain't to busy walk on down this afternoon and we'll play in the shop. I gotta fix the back garage door unless my son comes over for me to work on his car. He was suppose to be here Sunday but didn't show, then it was yesterday and now it's today.
Bob |
04-12-2006, 03:24 PM
#14 |
Name: David City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 51 Avg Visit Freq/Week = 3.73 over 30 days | I think a lot depends on the width of the edge banding. If it's just to cover the edge and is say 1/4" wide then just going from the saw and a plain glue joint will suffice. I have put 3mm (1/8") maple banding around a fairly tight curve with yellow glue and had no problems. If it is much wider and will be subject to a side load; say some one leaning on it or pulling it; then I would go the loose spline route; has worked for me in the passed. Still keep it a hair wider that the ply even when you use DaveO's registration method because sod's law says it will still be off one side  DAMHIKT
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux |
04-12-2006, 06:10 PM
#15 | | Moderator
Name: Wayne City: Cary State: NC County: Wake Join Date: Dec 2005 Age: 61 Avg Visit Freq/Week = 7.00 over 30 days | DavidF I have decided to go with a 3/4" oak face frame to cover the ply endgrain. Then, I will add some molding on the top and bottom sides as well. I will try and attach it with biscuits, as DaveO suggested. Jim...I will just have to hope that the biscuits don't swell enough to cause "lumps" on the outside of the carcase. Haven't actually seen this happen before? But, then again I have never used biscuits in 3/4 ply before. BobN... I have been busy all afternoon cutting up ply for the carcass for this TV stand and missed your message! I would really like to see your shop! Maybe when I get to point of adding this faceframe to the carcass, I will give you a shout for some expertise and guidance. Thanks for the invite! Thanks, Wayne
| |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
Members: 2,136
Threads: 16,390
2nd Top Poster: jeff... (6,363) | | Welcome to our newest member, Notorious T.O.D. | |
