» Announcements | Everyone Log on at 9:00PM Thursday December 4th to set a members online record.  | » Online Users: 65 | | 28 members and 37 guests | | Alan in Little Washington , Andrew A , AndyBarnhart , bluewing92 , Canuck , cyclopentadiene , Dcoop , Don Kohl , dpanda , erasmussen , flatheadfisher , JackLeg , MikeF , Ncdawgs1882 , NZAPP1 , PeteQuad , ptt49er , RayH , redhawknc1 , russellellis , Scott Kuykendall , Sealeveler , stave , SteveColes , TracyP , Travis Porter , Turtlewood , woodArtz | | Most users ever online was 180, 04-22-2008 at 12:18 AM. |  |
11-19-2006, 04:01 PM
#1 |
Name: Marvin Watkins City: Hillsborough State: NC County: Orange Join Date: Sep 2005 Age: 45 Avg Visit Freq/Week = 0.00 over 30 days | My wife and I purchased a house in north Raleigh about five years ago. The kitchen countertop was in a black speckled laminate. We didn't have a major issue with this 'color' choice. However, five years on, my wife has decided that she is tired of not being able to see when the countertop is dirty. She would like to change to a color that is easier to see dirt on.
Can anyone give me a quick rundown on what is involved in re-laminating countertops? The existing ones are in good shape. Would I have to strip the existing ones off or just apply new ones on top of the old ones. We are not changing the configuration of the cabinets. We have one section that is about 9' x 4' and appears to have been cut from one section of laminete.
Any help would be appreciated.
__________________
Marvin A. Watkins
Raleigh, NC
Making sawdust when I can...
11-19-2006, 04:10 PM
#2 | | Moderator
Name: Nick City: Clemmons State: NC County: Davidson Join Date: Jun 2006 Age: 50 Avg Visit Freq/Week = 6.77 over 30 days | Marvin
The countertop must not be water damaged or have signs of rotting as this will cause the new laminate to come away after a while. If there are any bubbles in the old laminate you should cut them out and fill the cutout area with an appropriate filler.
You then simply roughly sands the old laminate to provide a ‘key’ so that the contact adhesive has a good hold. Then apply the new laminate and trim away the excess. What kind of back splash do you have? Can it be removed? If not it may present a problem when you go to relaminate it. I also think the laminate comes in 9' x 4' sheets
__________________ Nick Z To do important deeds, two things are necessary; a plan and not quite enough time. |
11-19-2006, 07:08 PM
#3 | | Vice-President Libraries Administrator
Name: Rob City: Hendersonville State: NC County: Henderson Join Date: Nov 2005 Age: 66 Avg Visit Freq/Week = 7.00 over 30 days | If they are the rolled edge/backsplash type, you will have real problems adding a layer of laminate over the tight curves. I'd recommend replacing the entire top; the big Home Improvement stores have a limited lelection of colors or you can special order them in your color choice.
__________________
Rob  Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way! |
11-19-2006, 08:56 PM
#4 |
Name: Marvin Watkins City: Hillsborough State: NC County: Orange Join Date: Sep 2005 Age: 45 Avg Visit Freq/Week = 0.00 over 30 days | Thanks guys.
The laminate is in great shape, i.e. no water damage or any damage. The only reason to consider changing it is because it will make my wife's life easier.
The backspash is a 3" laminated backspash. In theory you should be able to remove it.
All of the edges are 90 degree edges. No drip guards or bent laminate. The only bending is on the 1 1/2" edge band on some of the corners. This is a very simple countertop collection.
Is this something I should consider tackling myself or might it be simpler and quicker to get someone in to handle it for me?
__________________
Marvin A. Watkins
Raleigh, NC
11-19-2006, 10:47 PM
#5 |
Name: Bruce City: Apex State: NC County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 6.77 over 30 days | Marvin, If you are going to Triangle Woodworkers on Tues nite, we have Marc Adams video on laminating in the library. Well worth taking a look at  . Laminate comes in sizes from 3X4 to 5X12. Both Raleigh Hardwood and Web-Don sell laminate. Web-Don does only wholesale though. I can buy direct, but usually go to Lowes/ Home Depot and order for customer pickup. This way, I get "National Pricing", which is less than what I would pay direct. Go figure! Are you going back with same style of edgebanding, or something different, like "wood"? No larger than this project, I think I would get some stock for the substrate and make a whole new counter. You could cut up old counter to make router table top, extension wing, or outfeed for table saw. Nice thing about that black laminate is it won't show grease, but will show wooddust. |
11-20-2006, 10:11 AM
#6 |
Name: Marvin Watkins City: Hillsborough State: NC County: Orange Join Date: Sep 2005 Age: 45 Avg Visit Freq/Week = 0.00 over 30 days | Thanks Bruce. I will have to stop by and pickup the video.
Hmm, new shop work surfaces.... hadn't thought about that!!!
__________________
Marvin A. Watkins
Raleigh, NC
11-22-2006, 12:59 PM
#7 |
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 6.53 over 30 days | IMO, it is a PITA, but it is something you can do. Contact cement bonds quickly, and you need good ventilation. Personally, I like to have all of my parts cut to rough size, I use masking tape to hold the joints together, and stick dowels underneath to keep it from touching until I have it right.
A laminate trimmer or flush trim bit is a must, but be careful as they "goop up" a lot and need cleaning. Also, a couple of files helps to smooth rough edges and get into the places the laminate trimmer won't reach.
My .05 (went up from .02 due to inflation) |
11-22-2006, 10:52 PM
#8 |
Name: Bruce City: Apex State: NC County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 6.77 over 30 days | Originally Posted by Travis Porter IMO, it is a PITA, but it is something you can do. Contact cement bonds quickly, and you need good ventilation. Personally, I like to have all of my parts cut to rough size, I use masking tape to hold the joints together, and stick dowels underneath to keep it from touching until I have it right.
My .05 (went up from .02 due to inflation) I find that if I wait long enough for the contact cement to completely dry, I get very little "gooping" on the cutters. I take a 1/2" flush trim bit and add an oversized bearing from my rabbeting set to it. Then I trim laminate oversize on first trimming, and then go back with a flush trim bit. After edge banding is on and top laminate glued and rolled in place, I coat upper edge of edge banding with petrolium jelly. This prevents either cutter (solid carbide) or bearing from leaving tracks. |
11-24-2006, 09:07 AM
#9 |
Name: Travis City: Hickory State: NC County: Catawba Join Date: Jun 2006 Avg Visit Freq/Week = 0.23 over 30 days | I did this once and was told that I had to remove the old laminate. I used an iron to release the contact cement. The over lay method sounds much easier. Let me know the results you get becasue my mom wants me to do hers.
__________________
" the good thing with me and woodworking .... I have nothing to unlearn" |
11-24-2006, 09:45 AM
#10 |
Name: Mark City: Vass State: NC County: Moore Join Date: May 2006 Avg Visit Freq/Week = 0.00 over 30 days | i had a tenant the was kind enough to relaminte a counter top for me, over the origional. my wife was able to pull it all off without tools and cemicals in about 10 minutes. im sure that the person who put it down did not scuff it with sand paper first, but i would never go over another layer.
the cost of rebuilding the top is a lot cheaper than what the laminate is going to cost you.
if ou want to strip it the eaziest way is with laquure thiner, i spry it on with a small bottle that u can get for free at haie hair dresser |
Posting Rules
Members: 2,136
Threads: 16,392
2nd Top Poster: jeff... (6,363) | | Welcome to our newest member, Notorious T.O.D. | |
