» Announcements | Everyone Log on at 9:00PM Thursday December 4th to set a members online record.  | » Online Users: 63 | | 31 members and 32 guests | | Alan in Little Washington , AlexL , Andy Casiello , bluewing92 , Canuck , cyclopentadiene , Dan Bowman , Dcoop , Don Kohl , dpanda , flatheadfisher , gator , JackLeg , Joe Scharle , Mike Davis , MikeF , Ncdawgs1882 , PeteQuad , rcflyer23 , redhawknc1 , russellellis , saw4you , scsmith42 , SRhody , Stanley , stave , tmerrill , TN Woodie , Travis Porter , Trent Mason , woodArtz | | Most users ever online was 180, 04-22-2008 at 12:18 AM. |  |
06-27-2007, 11:51 AM
#1 | | Site Programmer
Name: Jim Campbell City: Hillsborough State: NC County: Orange Join Date: Feb 2006 Age: 38 Avg Visit Freq/Week = 3.03 over 30 days | At the Woodcraft "Make a knife" class last saturday, Joe imparted what might be the single biggest breakthru technique I've ever learned.
When "filing, sanding, scraping, smoothing etc" change directions often.
What does that mean?
Well, lets say you are sanding a board. First move from the lower left to the upper right for say, 4 passes. Now switch, from lower right to upper left. For the sake of argument, make an X pattern.
It makes filing or sanding work a billion times faster.
It has to do with your sand paper/file bottoming out. If you keep going in the same direction, you would reach a point where all your scratches are the same depth. The exact depth of the size of your grit particles.
So, the particles of grit can no longer cut, as the high points of your scratches are hitting the paper backing.
This was amazingly evident when we were shaping our bar of tool steel into a rough knife shape. I'd keep on filing and filing in one direction, making little progress.
Joe stopped by and reinforced his lesson. Suddenly, when I changed filing directions, the material was just coming off at an amazing rate. Also, it was coming off the way I "wanted" it to.
Just yesterday, I was using steel wool to clean off some burnt on food spots in my skillet. I was working and working, making little progress, then I heard Joe's voice.....
Started scrubbing in different, alternating directions, the burnt on food came off almost immediatly.
I hope this helps, it has totally blown my mind.
Thanks,
__________________
"Its not about the destination, its about the joinery!"
06-27-2007, 12:34 PM
#2 | | Moderator
Name: Mike Hall City: Indian Trail State: NC County: Union Join Date: Feb 2006 Avg Visit Freq/Week = 6.53 over 30 days | Great tip Jim! It makes complete sense.
__________________
__________________________________________ Take the attitude of a student, never be too big to ask questions, never know too much to learn something new. Og Mandino |
06-27-2007, 02:01 PM
#3 |
Name: Todd City: Hillsborough State: NC County: Orange Join Date: Nov 2006 Avg Visit Freq/Week = 0.00 over 30 days | 100% true with my microplanes.  |
06-27-2007, 02:20 PM
#4 | | Site Programmer
Name: Jim Campbell City: Hillsborough State: NC County: Orange Join Date: Feb 2006 Age: 38 Avg Visit Freq/Week = 3.03 over 30 days | Todd,
Thats a great example for this tip.
Its easier to see a microplane cutter as opposed to a single piece of sandpaper grit!
thanks,
__________________
06-27-2007, 03:15 PM
#5 |
Name: fred City: franklinton State: nc County: franklin Join Date: Jun 2006 Age: 51 Avg Visit Freq/Week = 7.00 over 30 days | Originally Posted by Mike Davis That's an old one that I forget sometimes, Thanks!
and in return...
If you have baked on or burnt food in a pan fill it with water and let it boil for a few minutes. Now it should wipe right out. For really bad pans it may take a few cycles or longer boil times. The boiling water softens the residue and lifts it right out. I never scrub pans any more.
and if you add some baking soda to the water it is even faster.
fred p |
06-27-2007, 03:47 PM
#6 |
Name: Danny City: Seagrove State: NC County: Montgomery Join Date: Oct 2006 Age: 51 Avg Visit Freq/Week = 6.77 over 30 days | Originally Posted by Mike Davis That's an old one that I forget sometimes, Thanks!
and in return...
If you have baked on or burnt food in a pan fill it with water and let it boil for a few minutes. Now it should wipe right out. For really bad pans it may take a few cycles or longer boil times. The boiling water softens the residue and lifts it right out. I never scrub pans any more. Only way to clean cast iron pans. |
06-28-2007, 12:47 PM
#7 |
Name: Todd City: Hillsborough State: NC County: Orange Join Date: Nov 2006 Avg Visit Freq/Week = 0.00 over 30 days | Heating might take advantage of different expansion rates, and boiling water would soften things.
But why would baking soda help? Draino (lye) I can see  . . . but baking soda? I've heard that said before, but figured it was an old "wife's tale".
Todd |
06-28-2007, 01:40 PM
#8 |
Name: Steve City: Raleigh State: NC County: Wake Join Date: May 2007 Avg Visit Freq/Week = 5.83 over 30 days | I believe that baking soda is a mild abbrasive as well. I use it and a little bit of water to clean out my stainless steel frying pans to keep things from sticking when I make eggs.
- Steve |
06-28-2007, 04:11 PM
#9 |
Name: Todd City: Hillsborough State: NC County: Orange Join Date: Nov 2006 Avg Visit Freq/Week = 0.00 over 30 days | From Arm and Hammer's web site: Q.How does baking soda work as a pot and pan cleaner? A:The alkaline properties of baking soda penetrate and help loosen dried on, burnt on soils to reduce the scrubbing effort. Q.How do I use baking soda as a pot and pan cleaner? A:To clean pots easier and faster, sprinkle baking soda in the pot or the pan and add hot water. Let the pot or pan soak for 15 minutes and wash as usual. The alkaline properties of baking soda penetrate and help loosen dried on, burnt on soils helps to reduce the scrubbing effort.
Alkalinity . . . I think this means my draino idea would work even better
NOT THAT I AM ADVISING ANYONE DO THAT!!!!! |
07-02-2007, 06:48 PM
#10 |
Name: K City: Morrisville State: NC County: Wake Join Date: Jan 2007 Avg Visit Freq/Week = 0.00 over 30 days | I know someone who also uses it as a tooth whitener. Once a week she brushes with a mixture of baking soda and peroxide and I have never seen anyone's teeth whiter than hers. |
Posting Rules
Members: 2,136
Threads: 16,392
2nd Top Poster: jeff... (6,363) | | Welcome to our newest member, Notorious T.O.D. | |
