» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  | |
09-29-2009, 10:13 AM
#1 | | ShellaWax Name: Phillip City: Lexington State: NC County: Davidson Join Date: Jun 2008  09-29-2009, 10:13 AM
After I tell a good friend, TracyP, that I really like to use ShellaWax - "Houston I have a problem" a few of my stoppers - I noticed yesterday - have some bad finish on them - one looks like it has flaked off and the other looks like it didn't even take the SW in a certain spot - They where not that way before I took them out Saturday to the festival - It was raining and a few got wet - well actually all of them got wet but we managed to dry all of them off - I am guessing - Does anyone else use this finish? Have you had problems with it later after application? Does it need to cure for awhile so that something like this will not happen? Thanks
__________________
Phillip
My Saw Is Making Dust
Time waits for no one. Treasure every moment you have. You will
treasure it even more when you can share it with someone special. (Arthor unknown)
| | Views: 235 |
09-29-2009, 11:03 AM
#2 |
Name: Phillip City: Lexington State: NC County: Davidson Join Date: Jun 2008 Avg Visit Freq/Week = 6.92 over 180 days | Re: ShellaWax Found this while surfing trying to find the info "The hardener in the polish is activated by the heat generated during the application of the Shellawax. As soon as the surface is dry (almost instantly) a cross-linking begins in the finish. It is this cross-linking process which creates the harder surface. It takes around 3 weeks for the entire process to complete. However, in the mean time the work can be handled and used without fear of upsetting the process. Just keep it away from alcohol, water, etc during this time." Learned something new - I guess I should read all of the directions
__________________
Phillip
09-29-2009, 11:31 AM
#3 |
Name: Randy City: Macon State: NC County: Warren Join Date: Jan 2006 Age: 59 Avg Visit Freq/Week = 5.48 over 180 days | Re: ShellaWax Directions? We don need no stinkin' directions... .gif) .gif)
A lesson was learned and shared  . Thanks!
__________________
Randy
Any compromise between the truth and a lie can ONLY be something less than the truth.
09-29-2009, 12:31 PM
#4 |
Name: Ken City: Liberty State: SC County: Anderson Join Date: Nov 2005 Age: 63 Avg Visit Freq/Week = 7.00 over 180 days | Re: ShellaWax Originally Posted by PChristy Found this while surfing trying to find the info "The hardener in the polish is activated by the heat generated during the application of the Shellawax. As soon as the surface is dry (almost instantly) a cross-linking begins in the finish. It is this cross-linking process which creates the harder surface. It takes around 3 weeks for the entire process to complete. However, in the mean time the work can be handled and used without fear of upsetting the process. Just keep it away from alcohol, water, etc during this time." Learned something new - I guess I should read all of the directions Phillip, IMO the heat is the key. When I finish sanding at a lower speed I crank the speed up for finishing. I use t-shirt material, about a 4" square, folded double both ways to give 4 layers. This makes it small enough to not get caught and provides padding.
I apply the finish and rub it in till the pad gets hot as I move it along the blank. I'm a believer in 'if it aint burning yo finger, it aint working', but that's just my way and may not be agreed with by others.
Reason: can't spell!
09-29-2009, 12:46 PM
#5 |
Name: Phillip City: Lexington State: NC County: Davidson Join Date: Jun 2008 Avg Visit Freq/Week = 6.92 over 180 days | Re: ShellaWax Ken, that is basically the same way I have done mine with the exception of the t-shirt material - I have shop grade paper towels and With the ones that I have the Corian in I have got the blank so hot that I can't touch it after I have applied the SW -Right or wrong I don't know - With the ones that I have the problem with I did about the same thing but not as hot - I think that we didn't get them dried off all the way and they where not cured enough to get wet  - I have plenty of old t-shirts I will try that the next time - thanks for your input
__________________
Phillip
09-29-2009, 05:04 PM
#6 |
Name: Guy Belleman City: Troutdale State: VA County: Grayson Join Date: May 2007 Avg Visit Freq/Week = 3.69 over 180 days | Is Shellawax really that great When I used it, a couple of years ago, it was okay, but I wasn't that impressed and went back to my previous finish method. I have and tried both the Shellawax creme in the can and the liquid. |
09-29-2009, 05:05 PM
#7 |
Name: Phillip City: Lexington State: NC County: Davidson Join Date: Jun 2008 Avg Visit Freq/Week = 6.92 over 180 days | Re: Is Shellawax really that great Originally Posted by Guy in Paradise When I used it, a couple of years ago, it was okay, but I wasn't that impressed and went back to my previous finish method. I have and tried both the Shellawax creme in the can and the liquid.
Guy what was it that you did not like about it - and what are you using now
__________________
Phillip
09-29-2009, 05:36 PM
#8 |
Name: Fred City: franklinton State: nc County: franklin Join Date: Jun 2006 Age: 52 Avg Visit Freq/Week = 6.84 over 180 days | Re: ShellaWax I have not done any stoppers but have done many many pens. IMO you are doing your customers a disservice by using a wax only finish. I started out using various wax finishes and found they wear off fairly quickly. CA is my finish of choice for pens and would be for stoppers too [if I ever do any]. It's not that hard to learn and it outlasts wax a hundred fold. things that sit on a shelf are good candidates for wax. things that are handled a lot are not. I would not use shelac either because alcoholic beverages may dissolve it.  5-6 coats of CA can be applied in a few minuits. micro-mesh to 12000 without skipping any grits and you are done. I generally use a mylands wax topcoat just because. It will wear off but the CA finish will be shiney enough that most folks would never notice that it's gone. .gif) YMMV
Next time you are in town give a shout. I'll show you how I do it. |
09-29-2009, 06:20 PM
#9 |
Name: Phillip City: Lexington State: NC County: Davidson Join Date: Jun 2008 Avg Visit Freq/Week = 6.92 over 180 days | Re: ShellaWax Originally Posted by FredP I have not done any stoppers but have done many many pens. IMO you are doing your customers a disservice by using a wax only finish. I started out using various wax finishes and found they wear off fairly quickly. CA is my finish of choice for pens and would be for stoppers too [if I ever do any]. It's not that hard to learn and it outlasts wax a hundred fold. things that sit on a shelf are good candidates for wax. things that are handled a lot are not. I would not use shelac either because alcoholic beverages may dissolve it.  5-6 coats of CA can be applied in a few minuits. micro-mesh to 12000 without skipping any grits and you are done. I generally use a mylands wax topcoat just because. It will wear off but the CA finish will be shiney enough that most folks would never notice that it's gone. .gif) YMMV
Fred, I have tried the CA on a pen or two and even on a stopper or two - but I just can't figure out how to rub that CA glue into those curves and steps that I have on some of my stoppers with out it drying so quick - I can see it used on pen/pencils - I just need to come up and see ya - Fred do you not think that after it cures it will be ok
__________________
Phillip
09-29-2009, 06:54 PM
#10 |
Name: Fred City: franklinton State: nc County: franklin Join Date: Jun 2006 Age: 52 Avg Visit Freq/Week = 6.84 over 180 days | Re: ShellaWax Originally Posted by PChristy Fred, I have tried the CA on a pen or two and even on a stopper or two - but I just can't figure out how to rub that CA glue into those curves and steps that I have on some of my stoppers with out it drying so quick - I can see it used on pen/pencils - I just need to come up and see ya - Fred do you not think that after it cures it will be ok it may work but I dont believe it will last.  I have used hut wax, [the brown and white sticks] mylands friction polish, crystal coat,carnuba wax and renesance wax. none have lasted very long on pens. |
09-29-2009, 07:03 PM
#11 |
Name: Phillip City: Lexington State: NC County: Davidson Join Date: Jun 2008 Avg Visit Freq/Week = 6.92 over 180 days | Re: ShellaWax Originally Posted by FredP it may work but I dont believe it will last.  I have used hut wax, [the brown and white sticks] mylands friction polish, crystal coat,carnuba wax and renesance wax. none have lasted very long on pens.
I have sent an e-mail to U Beaut polishes that makes this to see what they say - In the mean time I have four-five with this shellawax on it here at home - I will hang on to them for the three weeks to run a test on them with some water and see what they do - then take them and rub -pull them for a week or so to see how it holds up  - I hate to know that I have spent that much for that bottle and can't use it
__________________
Phillip
09-29-2009, 07:53 PM
#12 |
Name: Gary City: Raleigh State: NC County: Wake Join Date: Sep 2008 Avg Visit Freq/Week = 6.88 over 180 days | Re: ShellaWax I personally prefer poly, it is made to stand up to the wear and tear of foot traffic, CA will actually crack and turns yellow, and does wear over time.
__________________
I have not failed. I've just found 10,000 ways that won't work.
Thomas A. Edison
09-29-2009, 08:10 PM
#13 |
Name: Fred City: franklinton State: nc County: franklin Join Date: Jun 2006 Age: 52 Avg Visit Freq/Week = 6.84 over 180 days | Re: ShellaWax Originally Posted by NCTurner I personally prefer poly, it is made to stand up to the wear and tear of foot traffic, CA will actually crack and turns yellow, and does wear over time.
yes but poly does too. the problem with poly is the drying time between coats and some of the exotic woods like rosewood are hard to get poly to dry at all.
CA lasts for years from what I can tell and it goes on and dries in less than a minute per coat. oils like poly usually add an amber tint where CA is clear. If there is a lot of details in the piece you can use medium CA. This gives a little more time to work the finish into the details. Some folks use laqeur and dip the blanks. I've not tried that but it sounds workable. Deft spray works too.  |
09-29-2009, 08:15 PM
#14 |
Name: Phillip City: Lexington State: NC County: Davidson Join Date: Jun 2008 Avg Visit Freq/Week = 6.92 over 180 days | Re: ShellaWax Originally Posted by FredP Some folks use laqeur and dip the blanks. I've not tried that but it sounds workable. Deft spray works too.  I have thought about dipping some of by stopper tops but didn't know what I could dip them in and still have a uniformed finish - will lacquer work for this process
__________________
Phillip
09-29-2009, 08:28 PM
#15 |
Name: Fred City: franklinton State: nc County: franklin Join Date: Jun 2006 Age: 52 Avg Visit Freq/Week = 6.84 over 180 days | Re: ShellaWax Originally Posted by PChristy I have thought about dipping some of by stopper tops but didn't know what I could dip them in and still have a uniformed finish - will lacquer work for this process  I'm not sure how it works because I havent tried it but seems like you would have to keep the finish out of the tubes for pens and out of the tapped hole on stoppers.
I kinda think all runs would be free!  the ideal finish would be one that dries in a few minutes but stays fluid long enough to self level. so far I haven't found it.....  I wonder how water based poly would work? what is the drying time on WB poly? |
| |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
Members: 3,663
Threads: 25,104
Top Poster: DaveO (14,701) | | Welcome to our newest member, Keith Senderak | |
