» Announcements | July 15 - 2009 Calendar Contest Opens (See this thread for Categories and Submission Rules) - Be sure your photos meet size and resolution! September 1 - All Calendar Photos Must be Submitted September 27 - Southern Raleigh Shop Crawl October 11 - Fall Gathering in Asheville October 24 & 25 - Klingspor Extravaganza - Hickory, NC |  | |
01-26-2007, 11:08 AM
#1 | | Member
Name: David Fenton City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 51 | Refinishing a new adventure Wish me luck! I am in the middle of the most horrible and infuriating refinishing job. It's our own teak veneer dining table that has suffered over the years from salt scratches, jenga dents, water marks etc.. And to add to the misery there is a centre panel that has not seen the light of day for the last 10 years! other than that; easy!
I have stripped and bleached the top with Oxalic acid to remove some water stains. I have had a **** of a time staining the outer leaves; they do no react in any "normal" way to the stain colours I have put on. It is like working with something out of "harry Potter" "Davids every colour teak" I applied a nice golden orangy/Oak stain and in places the top turned a wonderful vermillian! I thought $%%&! so out came the bleach again and as soon as the bleach hit it turned bright yellow! The centre panel just to be contrary behaves beautifully and is now a lovely golden brown colour whilst the outside leaves are a blondish dirty yellowy sort of mess having been stained and bleached and stained and bleached a few times. I gave up with the staining and decided to go the toner route. I have put two coats of the ultima shellac sealer on to prevent any problems with compatibility with the next steps. I have read copious amounts on the web and am going with "tints all" and or "Transtints" to colour the Target EM8000 conversion varnish. People tell me to increase the air inlet pressure and decrease the material flow to provide a mist coat and gradually creep up on the colour I need. This table will be the death of me and what's more it is stopping work on the new bedside cabinets!!
More on Monday!!!
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux |
01-26-2007, 11:35 AM
#2 | | Member
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 | Re: Refinishing a new adventure Interesting.
Is the EM8000 water based? |
01-26-2007, 12:08 PM
#3 | | Member
Name: David Fenton City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 51 | Re: Refinishing a new adventure Originally Posted by Travis Porter Interesting.
Is the EM8000 water based? Yes. It is much tougher alternative to the lacquer, but appaently completly compatible with their other wb produces
__________________
01-26-2007, 12:43 PM
#4 | | Moderator Advisory Panel
Name: Roger Deese City: Durham State: NC County: Durham Join Date: Jul 2005 Age: 62 | Re: Refinishing a new adventure David,
I suggest a nice cup of tea
Followed by a bottle of wine
Roger
__________________
I ain't never had too much fun!
01-26-2007, 01:04 PM
#5 | | Member
Name: David Fenton City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 51 | Re: Refinishing a new adventure Originally Posted by sapwood David,
Roger Sage advice Roger I'll start now  I guess my signature says it all? must add the bit about the wine!!
__________________
01-26-2007, 01:14 PM
#6 | | Member
Name: jeff... City: State: NC County: Granville Join Date: Mar 2006 | Re: Refinishing a new adventure David, try not to beat the wood up too bad with all those chemicals. One thing you might consider trying is wiping the surface with a little denatured alcohol prior to applying your stain. Or better yet consider not using a stain it at all, mix up a toner coat and apply between your finish coats.
Is your goal to change the color of the wood to make it look like something other than teak (stain) or are you trying to color match the finish (toner)? I think everyone knows how I personally feel about stain - it's some bad ju ju for me, I don't stain wood but am an avid fan of the use toner.
Just my 2 cents, hope it helped.
__________________
Mills Custom Sawing Life is like a jar of Habanero peppers. What you do today, might burn your A _ _ tomorrow. Colonel Sandurz: Prepare ship for light speed.
Dark Helmet: No, no, no, light speed is too slow.
Colonel Sandurz: Light speed, too slow?
Dark Helmet: Yes, we're gonna have to go right to ludicrous speed. |
01-26-2007, 02:10 PM
#7 | | Member
Name: David Fenton City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 51 | Re: Refinishing a new adventure Originally Posted by jeff... David, try not to beat the wood up too bad with all those chemicals. One thing you might consider trying is wiping the surface with a little denatured alcohol prior to applying your stain. Or better yet consider not using a stain it at all, mix up a toner coat and apply between your finish coats.
Just my 2 cents, hope it helped. My goal was to remove the original stains in the table Jeff and in order to do that had to use a fairly long exposure to bleachs. This left the wood with very little "natural" colour, hence the stain to give some "life" to the wood. As I said, the outer leaves did not react as planned to the dye stains I tried first and and had some unacceptable results and had to remove that stain. This left me with the rather horrible result. So toner it is. I am thinking (according to my finishers colour wheel!) that a blend of burnt sienna and raw umber is my best bet added to the next coat of WB em8000
__________________
01-26-2007, 03:21 PM
#8 | | Member
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 | Re: Refinishing a new adventure Are you going to spray the Emglo? If so, inside? |
01-26-2007, 03:29 PM
#9 | | Member
Name: David Fenton City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 51 | Re: Refinishing a new adventure Originally Posted by Travis Porter Are you going to spray the Emglo? If so, inside?
Emglo????
Yes, and yes, inside - the shop you mean?
__________________
01-27-2007, 08:46 PM
#10 | | Member
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 | Re: Refinishing a new adventure Hmmmm... I have been a bit scared to spray VOC's inside the shop. Maybe for a small project (read non-production) it isn't an issue.
What are your thoughts on it? |
01-27-2007, 09:27 PM
#11 | | Member
Name: Jerry City: Salisbury State: NC County: Rowan Join Date: Feb 2006 | Re: Refinishing a new adventure Need rolaids??
Jerry
__________________
We make a living by what we get...............We make a life by what we give
01-29-2007, 09:09 AM
#12 | | Member
Name: David Fenton City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 51 | Re: Refinishing a new adventure Originally Posted by Travis Porter Hmmmm... I have been a bit scared to spray VOC's inside the shop. Maybe for a small project (read non-production) it isn't an issue.
What are your thoughts on it? So far I've survived putting on 3 coats with 2 hr spacing! Plus all the toner coats, plus the 2 shellac coats. I have a good respirator and have my air filter going all the time. Seems ok. Overspary with HVLP is so minimal.
__________________
01-29-2007, 11:03 AM
#13 | | Member
Name: Mark City: Vass State: NC County: Moore Join Date: May 2006 | Re: Refinishing a new adventure all i can say is better u than me
skip the tea pass on the wine
go strait to burbon |
01-29-2007, 11:10 AM
#14 | | Member
Name: David Fenton City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 51 | Re: Refinishing a new adventure I am having a few problems with the surface finish feeling rough. I think it is "dry spray" I think this may affect all middle age men, but in my case I may have my fluid control turned down too far as a result of being paranoid about lack of atomisation! I have posted a question on the Target coatings forum to get an idea of what is considered "too much" flow so that I don't lurch from one problem to another one; I will let you know the answer.
__________________
01-29-2007, 11:17 AM
#15 | | Member
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 | Re: Refinishing a new adventure Did you sand with 600 grit before the finish/final coat? |
| |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
Members: 1,791
Threads: 14,572
2nd Top Poster: jeff... (5,780) | | Welcome to our newest member, Inmyshop | » Today's Birthdays | |
None
