North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > Finishing
Finishing Anything to do with finishing
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 02-21-2006, 10:25 AM   #1
Painting Southern Yellow Pine?
PeteM's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 162
Show Printable Version Email this Page   Quote this post in a PM to PeteM
PeteM PeteM is offline 02-21-2006, 10:25 AM
Any issues painting SYP?
I'm a bit concerned as it's a lot more resinous (sp?) than common pine.
I'm thinking a thin coat of shellac as a sealer and exterior gloss oil base enamel topcoat.
It's for some deck chairs that will be outside year round.
TIA - pete
Old 02-21-2006, 10:48 AM   #2
Joe Scharle's Avatar
City: Holly Springs
State: NC
County: Wake
Threads: 159
Avg Visit Freq/Week
= 7.00 over 180 days
Re: Painting Southern Yellow Pine?
Due to it's liquid content SYP will move a lot. The nearest I've come to success is with barn paint. But even then, it hasn't been great. Sorry to waste your time, but I want to be on the notification list for your thread in case someone does have the answer.
Show Printable Version Email this Page   Quote this post in a PM to Joe Scharle
Old 02-21-2006, 11:16 AM   #3
PeteM's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 162
Avg Visit Freq/Week
Hey Joe - Don't be sorry!
After posting this I did some googling and the result was that painting SYP is a no win deal. Like you said, between the movement and moisture/resin content paint just ain't gonna stick to it.
Most places say use cedar instead.
pete
Old 02-21-2006, 01:09 PM   #4
Treasurer
City: Wake Forest
State: NC
County: Wake
Threads: 184
Avg Visit Freq/Week
= 6.53 over 180 days
Painted it, does ok. Sealing the knots is key. Trim on my shop is SYP and put two coats of Sherwin Williams best paint and has held up pretty well. I wouldn't say great, but pretty well.
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 03-24-2006, 03:06 PM   #5
Gillie's Avatar
City: Wilmington
State: NC
County: New Hanover
Threads: 4
Avg Visit Freq/Week
= 0.00 over 180 days
Behr opaque stain might be an option, but it's meant for exterior and might stink for a while.
Show Printable Version Email this Page   Quote this post in a PM to Gillie
Old 03-24-2006, 04:43 PM   #6
4yanks's Avatar
City: Southern Pines
State: NC
County: Moore
Threads: 17
Avg Visit Freq/Week
I have painted a few SYP projects and so far no issues (several years later). I did seal them with de-waxed shellac first. For an outdoor project you may wish to consider an oil-based paint.
Show Printable Version Email this Page   Quote this post in a PM to 4yanks
Old 03-24-2006, 08:50 PM   #7
Ozzie-x's Avatar
City: Clyde
State: NC
County: Haywood
Threads: 18
Avg Visit Freq/Week
= 6.65 over 180 days
I fought the yellow pine german siding on my first house for years and never really found a good solution. I tried various brands of oil base paints, the best grades by various manufacturer's and still the paint would start going to crap after only a couple of years. I tried priming, sanding, pressure washing, hot rod expensive paint additives, all to no avail. A lot of it has to do with the environment here, we have a lot of moisture here in the mountains and I think that is one of the biggest factors. Combine that with 40+ degree temperature swings during the day and it's a real test for paint, especially on yellow pine. So I don't really have any good advice for you to solve your problem, just some more experiences to underscore the dilema. Like someone ,entioned, some of the new exterior stain products might be worth a try and contact the stain mfgr for any tips or advice they may have for using their product on YP. Most mfgrs are usually helpful with such things.
Show Printable Version Email this Page   Quote this post in a PM to Ozzie-x
Old 03-24-2006, 11:32 PM   #8
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 56
Avg Visit Freq/Week
= 4.59 over 180 days
I moved here from Fla last Oct. My house there was built in 1982 with R B& B siding, which is mainly a SYP Pine plywood. It was stained originally. That lasted about a year. After paying professionals to paint it every four years with the $21 gal lifetime paint, and having it peel badly, I finally took a sidewinder sander and took it down to bare wood. (84 eight" 35 grit sanding discs later) I primed it with waterbased primer, and topcoated with two coats of Lowe's Signature series semi-gloss. That was in 1999. Before I sold the house in 2005, I pressure cleaned it and put one more coat of paint on it, no chipping or peeling. In the areas under the eaves and where the sun didn't hit it, it still looked as good as the fresh coat I put on it (I didn't paint under the eaves because I didn't need to).
Lessons I think I learned:
1. Don't use oil-based paint. The moisture will get under it and it will peel.
2. Semi-gloss lasts better than flat, and high gloss is best
3. For out door use, use latex on wood, because it "breathes", letting the moisture out after the wood absorbs it.
3. If the furniture will be in the shade most of the time, a quality semi- or high gloss latex will probably meet your needs, altho you probably will need to pressure clean it occasionally.
4. The lighter the color, the better the UV resistance (I had painted the trim white, while the rest of the house was gray. The white trim, even tho it was in the sun, did not require repainting).
My $.02
P.S> The paint may have needed pressure cleaning earlier, but we had several hurricanes that took care of that for me!!
Show Printable Version Email this Page   Quote this post in a PM to Gofor
Old 03-25-2006, 09:11 AM   #9
PeteM's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 162
Avg Visit Freq/Week
After much debate and procrastination I ended up going with the '"Gripper" primer sealer by Glidden (it says it holds on SYP on the label) topcoated with a white semi-gloss latex. Looks good for now. We'll have to wait to see how it looks in a year or two.
Old 03-25-2006, 09:15 AM   #10
NCPete's Avatar
City: Hope Mills
State: NC
County: Cumberland
Threads: 213
Avg Visit Freq/Week
= 5.99 over 180 days
Pete, that is a great looking chair!
__________________
Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it.
Henry David Thoreau
They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin
Show Printable Version Email this Page   Quote this post in a PM to NCPete
Old 03-25-2006, 01:39 PM   #11
D L Ames's Avatar
Name: D L Ames
City: Fayetteville
State: NC
County: Cumberland
Threads: 66
Avg Visit Freq/Week
Great looking chair Pete. Hopefully your finish will hold up for you on the SYP. There was a lot of good input to this thread and I look forward to you providing us with some feed back on how your finish holds up through the seasons.
D L
__________________
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf. George Orwell (1903 - 1950)
Show Printable Version Email this Page   Quote this post in a PM to D L Ames
Old 03-25-2006, 04:15 PM   #12
PeteM's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 162
Avg Visit Freq/Week
Thanks for the kind words
It was supposed to be a prototype but it came out pretty good so I painted it and put it on the porch. Based on a plan from American Woodworker. It has sliding dovetails connecting the front legs to the arms and the back legs to the stretcher. The arms, back rail and back slats are joined by mortise and tenons. It's pretty solid. It might need paint in a year but it ain't fallin' apart
Now I'm working on a loveseat based on the same design out of cypress.
pete
Old 03-25-2006, 08:01 PM   #13
City: Fayetteville
State: NC
County: Cumberland
Threads: 1
Avg Visit Freq/Week
Hi their Pete
Gripper has always been a great tool in my arsenal, if I'am unsure about what someone else did prior to me coming along and painting it, i'll use gripper to be asured that my coat of paint is going to stick. Bye the way, it really turned out good. NICE JOB!!
Show Printable Version Email this Page   Quote this post in a PM to ncpeter6368
Old 03-25-2006, 10:20 PM   #14
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 56
Avg Visit Freq/Week
Looks great. I'll bet the cypress ones will really stand out!
Closed Thread
painting , pine , southern , yellow
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,667
Threads: 25,111
Top Poster: DaveO (14,702)
Welcome to our newest member, Brockmania
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
