» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  |
09-23-2009, 05:54 PM
#1 | | lacquer repair? Name: Mike City: Westfield State: NC County: Stokes Join Date: Dec 2005 Age: 52  09-23-2009, 05:54 PM
I have a friend at work whose daughter set a bottle of fingernail polish remover (Acetone free?) on her dining table. It left a ring of dissolved finish.
Is there a way to repair this without refinishing the whole table top?
It is a factory finish on dark stained pine - solid wood, so probably lacquer.
__________________ I meant to tell you, Mors Kochanski said "thats a spoon made by an expert" -BR- | | Views: 190 |
09-23-2009, 06:54 PM
#2 | | Administrator
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 39 Avg Visit Freq/Week = 7.00 over 180 days | Re: lacquer repair? I would think that since lacquer burns into each coat and doesn't build in layers that you should be able to feather out the repair area to blend with the rest of the table. I don't think that you would need to strip and re-finish it all but it might require a single application over the whole surface to get everything even again once the repair is built up.
Dave
__________________   Nothing left to do but smile, smile, smile
--Dr. Seuss
09-23-2009, 07:30 PM
#3 |
Name: Robb City: Sherrills Ford State: NC County: Catawba Join Date: Feb 2008 Avg Visit Freq/Week = 6.77 over 180 days | Re: lacquer repair? Make sure silicon based furniture polish has never been used.(Can you say serious fisheye!)
Robb |
09-23-2009, 08:33 PM
#4 | | Webmaster Administrator Senior Moderator
Name: Tracy City: Salisbury State: NC County: Rowan Join Date: Feb 2008 Age: 48 Avg Visit Freq/Week = 7.00 over 180 days | Re: lacquer repair? As Dave said, we feather this stuff out every day in the body industry. It is a very workable product and is fairly easy to repair. You should have good success.
__________________
Tracy
Making Friends One Post At A Time
The task is always worthwhile if you learn something in the process.
09-24-2009, 03:42 PM
#5 | | Treasurer
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 6.53 over 180 days | Re: lacquer repair? What is the best to use on a table top? Nitrocellulose, pre-cat, etc? |
09-24-2009, 03:59 PM
#6 |
Name: Jeff City: Stovall State: NC County: Granville Join Date: Feb 2009 Avg Visit Freq/Week = 5.83 over 180 days | Re: lacquer repair? Mike a high speed buffer with that pink auto body compound you can get from NAPA works pretty well and will most always heat the lacquer up enough that you can feather the repair. Just take it easy or you'll make it worse. Above all if there was ever any wax like pledge applied, you might as well strip it and start over because you'll never be able to remove all the silicon from within the finish. You can try a little naptha (lighter fluid) but a product like wax wash by mohawk is much better. Keep in the back of your mind to wash an entire top is kind of pointless and would be easier (in the long run) to strip and refinish... |
09-24-2009, 04:01 PM
#7 |
Name: Jeff City: Stovall State: NC County: Granville Join Date: Feb 2009 Avg Visit Freq/Week = 5.83 over 180 days | Re: lacquer repair? Originally Posted by Travis Porter What is the best to use on a table top? Nitrocellulose, pre-cat, etc? Travis I would say pre-cat, it dries FAST and HARD. Just ask FredP  |
09-24-2009, 06:46 PM
#8 |
Name: Fred City: franklinton State: nc County: franklin Join Date: Jun 2006 Age: 52 Avg Visit Freq/Week = 6.84 over 180 days | Re: lacquer repair? Originally Posted by Jeff Mills Travis I would say pre-cat, it dries FAST and HARD. Just ask FredP  yeh real fast and real hard! then ask jeff to come spit on it. believe me it works!  |
09-24-2009, 07:20 PM
#9 |
Name: Jeff City: Stovall State: NC County: Granville Join Date: Feb 2009 Avg Visit Freq/Week = 5.83 over 180 days | Re: lacquer repair? Originally Posted by FredP yeh real fast and real hard! then ask jeff to come spit on it. believe me it works!  Nothing beats a little 400 grit spit sanding...  |
Posting Rules
Members: 3,664
Threads: 25,110
Top Poster: DaveO (14,702) | | Welcome to our newest member, Jose San Vicente | |
