North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > Finishing
Finishing Anything to do with finishing
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 10-07-2009, 01:52 PM   #1
India Ink
Jeff Mills's Avatar
City: Stovall
State: NC
County: Granville
Threads: 119
Show Printable Version Email this Page   Quote this post in a PM to Jeff Mills
Jeff Mills Jeff Mills is offline 10-07-2009, 01:52 PM
I just ordered a quart of black water proof India Ink to finish some tables for my daughter.
http://www.dickblick.com/products/bl...oof-india-ink/
Being a newbie with india ink I have a couple of questions...
* Should I brush the stuff on bare wood or spray it on? I would think you would treat it like a dye?
* Seeing it's water proof... is it cool to top coat with water based poly?
* Any pointers or tips would be greatly appreciated.
Thanks
Old 10-07-2009, 02:29 PM   #2
Trog777's Avatar
City: Asheboro
State: NC
County: Randolph
Threads: 17
Avg Visit Freq/Week
= 2.14 over 180 days
Re: India Ink
I use those cheapo traveling tool show disposable foam brushes to apply India Ink. I usually brush a coat on, let it sit for a bit, wipe it down with a rag, let it dry overnight and repeat. Two, sometime three coats will get you black black. I let it dry 48 hours then spray on a water based clear (Target Coatings USL) and have never had a problem
Show Printable Version Email this Page   Quote this post in a PM to Trog777
Old 10-07-2009, 02:51 PM   #3
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 188
Avg Visit Freq/Week
= 3.50 over 180 days
Re: India Ink
Trog discribed my method perfectly! one other thing - DON"T SAND until you have at least two coats of top coat on. You will be tempted because the ink raises the grain, but don't......
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Show Printable Version Email this Page   Quote this post in a PM to DavidF
Old 10-11-2009, 05:36 PM   #4
Jeff Mills's Avatar
City: Stovall
State: NC
County: Granville
Threads: 119
Avg Visit Freq/Week
= 5.83 over 180 days
Re: India Ink
My first experience with India Ink. Does it turn stuff black YES, check your gloves frequently for holes... It does wash off with soap and water if you catch it before it dries.
India Ink on Red Oak = instant grain raise. I think I'm going to need to build up atleast 3 maybe 4 coats of water based poly before I even think about sanding the grain flat. Takes 2 coats of ink to completely turn RO black because it raises the grain so bad. All that pretty wood is now gone to the black side...
Old 10-12-2009, 01:34 AM   #5
Kyle's Avatar
City: Iron Station
State: NC
County: Lincoln
Threads: 75
Avg Visit Freq/Week
= 5.06 over 180 days
Re: India Ink
Wipe it down with acetic acid first. The acetic acid(vinegar) act as as a mordant to bind the ink to the fiber of the wood. I would try a sample first to see how well it works on the wood. red Oak I would imagine is pretty receptive..
A lot stain and dye failures are due to not using a mordant to bind the dye to the wood fiber.
Here is a better explanation of mordant than I could write. I use to make stains and dyes in a previous life at UNC Hospital as a Histologist.
http://en.wikipedia.org/wiki/Mordant
__________________
http://www.sawmillnc.com
704-258-8985 (cell) its sprint/nextel so I may not always get the call
Show Printable Version Email this Page   Quote this post in a PM to Kyle
Old 10-17-2009, 01:14 AM   #6
Jeff Mills's Avatar
City: Stovall
State: NC
County: Granville
Threads: 119
Avg Visit Freq/Week
Re: India Ink
Thanks Kyle
I now have all the pieces inked and am looking at the worst grain raising I have ever had to deal with. I applied the ink directly to the bare RO sanded to 220. It takes two coats of ink to completely turn the wood and grain black, there's a good 2 hours of dry time in between coats. I bought a quart of India ink and have about 1/4 left.
I let the second coat of ink dry for atleast 12 hours before I spayed a seal coat of water based satin poly. It's black, really black but the way the grain has raised I'm going to have to build up several layers of water based poly before I start sanding in between coats. How many coats of water based poly it going to take to get a good finish is a guess at this point. But I'm guessing at least 7 before it starts looking half way decent. It's a good think I got a few weeks to get this project done.
Any words of wisdom would be greatly appreciated.
Thanks
Old 10-17-2009, 02:20 PM   #7
Kyle's Avatar
City: Iron Station
State: NC
County: Lincoln
Threads: 75
Avg Visit Freq/Week
Re: India Ink
the Glacial acetic creates an inorganic salt called iron acetate when applied and that is the mordant.
here is a method i found on the "internets"
You may have to sand between application while damp to knock off the fuzz.
__________________
Old 10-17-2009, 06:55 PM   #8
Jeff Mills's Avatar
City: Stovall
State: NC
County: Granville
Threads: 119
Avg Visit Freq/Week
Re: India Ink
I think I got it finally uggg... one of the toughest finishes I ever did and don't think I will ever do it again there are much easier ways to get a black finish. Here's the steps, for quick drying satin water based poly finish.
Sand red oak piece progressively from 80 grit to 220
Apply (flood) India ink to RO
Wait 2 hours
Wipe with cloth
Apply (flood) next coat India ink to RO
Wait 2 hour
wipe with cloth
let piece dry over night
apply coat water based poly
wait 1 hour
apply next coat water based poly
wait 1 hour
apply third coat water based poly
wait 1 hour
apply forth coat water based poly
Let dry over night
Sand with ROS 220 grit till smooth (some grain will be exposed - sand trough finish)
Wipe with cloth (save cloth this is important)
Wait 1 hour
wait 1 hour
Sand with ROS 320 grit till smooth (only a little grain will be exposed sand trough finish)
Wipe with saved cloth from before (cloth still pretty wet with India ink)
wipe dry with new cloth
wait 1 hour
Sand with ROS 400 grit till smooth (very little grain will be exposed)
touch up spots sanded through with cloth still wet with india ink
wipe dry touch up spots with dry cloth
wait 1 hour
Sand with ROS 600 grit till smooth (no grain should be showing now)
wait 1 hours
wait 1 hours
wait 2 hours
Done for now...
Old 10-17-2009, 10:25 PM   #9
Gotcha6's Avatar
City: Ivan's Corner (Monroe)
State: NC
County: Union
Threads: 87
Avg Visit Freq/Week
= 6.73 over 180 days
Re: India Ink
If the poly wasn't going on thick enough, could you have just sanded & re inked between sandings down to a smaller grit before any poly? Would that have made the places where the grain was low get too dark?
__________________
WHAT BOX?
Show Printable Version Email this Page   Quote this post in a PM to Gotcha6
Old 10-17-2009, 11:18 PM   #10
City: Vass
State: NC
County: Moore
Threads: 6
Avg Visit Freq/Week
= 5.72 over 180 days
Re: India Ink
Did you try Kyle's suggestion re: applying a mordant?
Show Printable Version Email this Page   Quote this post in a PM to woodlaker2
Old 10-18-2009, 01:15 AM   #11
Jeff Mills's Avatar
City: Stovall
State: NC
County: Granville
Threads: 119
Avg Visit Freq/Week
Re: India Ink
I think the problem is that India ink is about the consistency of water maybe thinner than water. As soon as it hits bare RO the grain raises instantly, you can actually see it raising the grain.
Old 10-18-2009, 01:18 AM   #12
Jeff Mills's Avatar
City: Stovall
State: NC
County: Granville
Threads: 119
Avg Visit Freq/Week
Re: India Ink
No I did not I had already started by the time Kyle posted. I don't think I'll be messing with India ink again anytime soon. Kyle has some really good info that I would have used if I hadn't already started.
Old 10-18-2009, 02:11 AM   #13
Kyle's Avatar
City: Iron Station
State: NC
County: Lincoln
Threads: 75
Avg Visit Freq/Week
Re: India Ink
Only because I have messed up a few times as well on wood. ..Knowledge only happens with experience good and bad..
__________________
Old 10-19-2009, 10:59 AM   #14
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 188
Avg Visit Freq/Week
Re: India Ink
Two things to add. From my ink project: I did two flood coats of the ink and thin added 3 black tinted coats of clear finish before adding 3 more coats of plain clear.
At the end I said that next time I wanted a true black that obscures the grain I would spray paint with black (duh) and then apply the clear finish to give me the depth I needed.
__________________
Old 10-19-2009, 02:50 PM   #15
jlwest's Avatar
City: Apex
State: NC
County: Wake
Threads: 16
Avg Visit Freq/Week
= 4.59 over 180 days
Re: India Ink
Jeff,
I built a red oak corner TV stand with shelves for components and stuff. My wife wanted it black so I just used flat black paint, two coats lighly sanded, and two coats of urathane as final coat. Seems to have worked fine.
Show Printable Version Email this Page   Quote this post in a PM to jlwest
Closed Thread
india , ink
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,104
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
