» Online Users: 77 | | 40 members and 37 guests | | Adirondax , ashley_phil , bwat , ChuckC , crokett , cudamom , dancam , decibel , FredP , gordonmt , JimmyC , JohnsonMBrandon , JohnW , Kyle , Larry Rose , lottathought , Marlin , Matt Schnurbusch , max_in_graham , mburke911 , merrill77 , michaelgarner , Mike Davis , MIKE NOAH , MikeF , mlzettl , NCTurner , NZAPP1 , PChristy , ptt49er , rcflyer23 , redhawknc1 , RSM , Tar Heel , TedAS , TracyP , Trog777 , woodArtz , woodnick , woodylarry | | Most users ever online was 180, 04-22-2008 at 12:18 AM. |  | |
02-16-2006, 12:32 PM
#1 |
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 5.83 over 180 days | Based on DavidF's and SteveD's comments on spraying, I have broken down and bought a Porter Cable PSH1 gravity fed conversion HVLP spray gun and want to use it to finish a toy box (once I finish the construction).
The directions/manual for the gun is the pits. I want to spray water based as I am a bit scared to do anything oil based without a spray booth, so any suggestions on what to beware of, what not to do, etc?
I am going to practice a bit before doing a piece of furniture, etc. but this is definitively going to be different for me. I expect I will use an oil based stain on the piece wiping it on by hand and will probably seal it with a coat of dewaxed shellac.
This will also be one of my first attempts with shellac. I suspect I will need to sand the shellac with 400 grit wet/dry paper. Do I need to use a lubricant, or anything before I topcoat? Speaking of which, what should I topcoat with? Water based poly maybe? Do I need to thin the poly to get it to work? I have been reading about Target USL which seems to be the best out there, but no experience. Will the standard needle work or do I need to get a larger one?
Any and all suggestions comments would be appreciated. |
02-16-2006, 02:19 PM
#2 | | Member
Name: Steve DeWeese City: Horse Shoe State: NC County: Henderson Join Date: Oct 2005 Age: 44 Avg Visit Freq/Week = 0.23 over 180 days | Travis,
Cardboard boxes make for great practice, spray them inside & out, flats & verticles. You've got the goods, forget wiping stain, spray dye. I use the Target/Emtech USL for lacquer and have also used Target oxford hybrid varnish (poly). Shellac as a sealer would be a good move if you mix oil stain and water finish but not needed if you use dye with water or alcohol as the base. There isn't a need to sand the shellac sealer if you go that route. I always spray at least 3 coats before sanding to make sure there is sufficient build. On a typical finish I will spray 3-4 coats, sand with 300 grit and spray 1-2 topcoats. If you are planning to rub out the finish (lacquer) you may want to build more. 3-4 coats, sand, 3-4 coats, sand, 1 coat. Let it cure for several days and then rub out. Emtech can recoat in 30 minutes so you can spray an entire schedule in a day. If you spray the dye, wait overnight to topcoat. Let me know if you want more details on the dye.
__________________
Home of the USS Crescent battle group.
02-16-2006, 03:49 PM
#3 |
Name: John Richards City: Hickory State: NC County: Burke Join Date: Oct 2005 Age: 33 Avg Visit Freq/Week = 4.71 over 180 days | Standard needle works fine. I use the same needle for spraying all my finishes with my HVLP system. The key is setting up the fluid and air controls. You want the fluid control to where you are fully wetting the surface but not puddling. Once the fluid control is right you adjust the air to where you orange peel and then increase by 1 psi. Once your controls are set you can leave it for the most part and thin everything to the same viscosity.
Practicing on a carboard box is a good idea. The key for spraying boxes is keep your air down to a min. Too much air and you'll have a very rough surface due to overspray. You want just enough air to avoid orange peel and no more.
Good Luck,
__________________ Keeping the Hokie Spirit Alive!! Remember 4/16/2007
First known case of the dreaded "Woodguy Disease" and is highly contagious. Stay away.... stay away! Warning! Not liable for excessive tool buying, drooling, or the sudden urge to spend large amounts of money. www.jsrwoodworking.com |
02-16-2006, 10:43 PM
#4 |
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 5.83 over 180 days | Yep, you started the dye thing with me, and I bought some transtint when Woodcraft had their 10 percent off sale. That stuff is EXPENSIVE. So, water or alcohol, and what mix ratio? Would you spray it as well. Tomorrow night, I expect I will be spraying some cardboard. |
02-16-2006, 11:35 PM
#5 | | Member
It is expensive but highly concentrated (wear gloves DAMHIKT) and it goes a loooooooong way. I have always used water, but if you are in a hurry or working with a wood type that grain raises severely alcohol is great too. Mix ratio is up to you but measure and record what you do in case you comer up short and need to mix more DAMHIKT. I use empty gatorade containers becaue they have a wide wouth and are easy to pour out of.
You can also play around with it and add it directly to your finish to use as a toner if you need to take care of Sapwood (the hat thing kind of freaked me out, i'd keep the toner gun loaded just in case  )
__________________
02-16-2006, 11:46 PM
#6 |
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 5.83 over 180 days | That picture was pretty scary, but after living in Durham myself for many years I have come to realize it is not abnormal there. If you didn't know it, that is why all the institutions are up the road in Butner.  |
02-17-2006, 08:26 AM
#7 | | Member
Name: Steve DeWeese City: Horse Shoe State: NC County: Henderson Join Date: Oct 2005 Age: 44 Avg Visit Freq/Week = 0.23 over 180 days | That explains it...
__________________
02-17-2006, 09:25 PM
#8 |
Name: Michael City: APO State: AE County: ARMY Join Date: Dec 2005 Age: 31 Avg Visit Freq/Week = 3.97 over 180 days | Hey travis,
This is a great website I go to to get info on finishing, I am the classic take-forever-has-to-be-perfect-construction woodworker, I used to just throw anything on there to get it done. I use my HVLP now and love it
Be blessed http://www.thewoodshop.20m.com/finishing.htm#maloof |
02-17-2006, 09:26 PM
#9 |
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 5.83 over 180 days | Thanks, it is new to me and I will check it out. |
03-05-2006, 03:04 PM
#10 |
Name: Keith Mercer City: Morehead City State: NC County: Carteret Join Date: Mar 2006 Avg Visit Freq/Week = 0.00 over 180 days | Don't forget to strain your dye!!! |
03-05-2006, 03:10 PM
#11 |
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 5.83 over 180 days | YOU HAVE TO STRAIN THE DYE??? Those itty bitty bottles of Transtint need to be strained? |
03-05-2006, 08:08 PM
#12 | | Member
Name: Steve DeWeese City: Horse Shoe State: NC County: Henderson Join Date: Oct 2005 Age: 44 Avg Visit Freq/Week = 0.23 over 180 days | If so, that is new to me. I've never stained liquid Transtint in all of the spraying I have done. I do strain the finish though. There is also a Transfast powder dye, that might be a good idea to strain it in case there are clumps.
__________________
03-06-2006, 11:54 AM
#13 |
Name: Keith Mercer City: Morehead City State: NC County: Carteret Join Date: Mar 2006 Avg Visit Freq/Week = 0.00 over 180 days | I buy dye in powder form and after you mix it you should strain it. Powder can be mixed with different mediums other than liquid. |
03-06-2006, 03:42 PM
#14 |
Name: David City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 52 Avg Visit Freq/Week = 3.81 over 180 days | When I was at at the cardboard box stage I found it almost impossible to see any orange peel. When I then tried a piece of wood, I could see it, so maybe also practise on some ply or MDF? Another thing I found and was told my the wagner tech people was to get no further away than 2-3" when sparaying WB because the finish can partially dry before hitting the surface, this gives a rough surface feel.
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux |
03-06-2006, 03:46 PM
#15 | | Member
Name: Steve DeWeese City: Horse Shoe State: NC County: Henderson Join Date: Oct 2005 Age: 44 Avg Visit Freq/Week = 0.23 over 180 days | David,
2-3" sounds awfully close, I can't imagine that much of a fan spread can be accomplished at that range. I have always been told 6-8" FWIW.
__________________
| |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | HVLP - don't laugh | DavidF | Finishing | 49 | 01-27-2006 01:04 PM | | » Stats |
Members: 2,317
Threads: 17,288
2nd Top Poster: jeff... (6,592) | | Welcome to our newest member, Dildayk | |
