» Online Users: 60 | | 30 members and 30 guests | | AndyBarnhart , ashley_phil , Canuck , clowman , dancam , decibel , Douglas Robinson , FredP , gesiak , Howard Acheson , jglord , JimmyC , Joe Scharle , Ken Massingale , KWGOOCH , Larry Rose , michaelgarner , MikeF , Outa Square , ptt49er , rsitzejr , Sandy Rose , Stanley , Sully , TracyP , wdkits1 , woodrat , WoodWrangler , woodylarry , yellofins | | Most users ever online was 180, 04-22-2008 at 12:18 AM. |  |
05-10-2008, 10:56 AM
#1 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 180 days | I am working on a project using QSWO with some really nice ray flake figure in it. I would like some suggestions for a finish that is pretty quick and easy that will darken the wood ala A&C style and enhance the ray fleck. Fuming in out of the question  It's a small piece so a length multi-step process with a lot of finishing products I don't have would be difficult. So basically I am looking for a products/schedule that can be obtained locally.
Any suggestions????
TIA
Dave
__________________   Nothing left to do but smile, smile, smile
--Dr. Seuss
05-10-2008, 11:48 AM
#2 |
Name: Jimmy Coull City: Clayton State: NC County: Johnston Join Date: Sep 2006 Age: 49 Avg Visit Freq/Week = 6.38 over 180 days | Dave,
I have an old article from Wood magazine (Dec. 2002), that seems loke a simple way to make the QS figure pop. The steps are below:
1) Mix a stain with water-soluble aniline dye, and aply using a foam brush. Blend all of your lap marks, sometimes using a dry brush will help. It will go on darker than the finished product and allow 12 hrs to dry.
2) Sand with 220 sandpaper, just enough to remove the dyed surface of the QS woods dense rays ( leaving the dark dye in the more porous parts of the grain), this removes the raised grain. Use a sanding block to avoid sanding through the dye on corners and edges. Use shop vac or compressed air to remove dust.
3)Finish to bring the color and pop back into the wood. They used shellac, do not use water-based finishes as they will reactivate the dye and may cause it to run.
Hope it helps.
Good Luck,
Jimmy
__________________
Jimmy "There are no strangers here, only friends that haven't met " I only buy what I need now, not what I want..... except for lumber ! Remember: Support your local Sawyers and Kiln Operators. |
05-10-2008, 01:29 PM
#3 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 180 days | Thanks Jimmy, I was wondering if sanding after coloring would help to highlight the ray fleck. I would suspect that I could acheive similar results using an oil based pigment stain
Dave
--Dr. Seuss
05-10-2008, 02:53 PM
#4 |
Name: Fred City: franklinton State: nc County: franklin Join Date: Jun 2006 Age: 51 Avg Visit Freq/Week = 7.00 over 180 days | I've deen useing formbys tungoil lately and its the simplest finish I've ever used. wipe on and wait. wipe on and wait........ 7-10 coats later and a week or so drying time then wax and buff. If I can do it anybody can! .gif) |
05-10-2008, 06:09 PM
#5 |
Name: Jim City: Mount Airy State: NC County: Surry Join Date: Apr 2006 Avg Visit Freq/Week = 3.62 over 180 days | Try flooding the surface with boiled linseed oil, letting it soak in a little while, then wipe dry. After 24-48 hrs. apply shellac. You can then put on whatever finish you want.
Jim in Mayberry |
05-10-2008, 09:53 PM
#6 |
Name: Mark City: Goldsboro State: NC County: Wayne Join Date: Mar 2006 Avg Visit Freq/Week = 5.91 over 180 days | DaveO: I used the 1 - 1 - 1 wipe-on mix of poly, BLO, MS on the white oak work bench I made, and the end aprons had a quite a bit of ray. It did not "pop" the ray at all, and in fact seemed to tone it down some. I used satin poly as that is what I had, which may account for some of it, but I will be looking for a different method if I use any QS in a nice furniture project. Its now a year later and you have to look for the fleck to see it unless the light is really bright.
Just my experience.
__________________
History will not judge you on the advice you give, but rather on what you yourself have done.
05-10-2008, 10:13 PM
#7 |
Name: Mark City: Concord State: NC County: Cabarrus Join Date: Nov 2005 Age: 53 Avg Visit Freq/Week = 6.96 over 180 days | Here's an attempt to duplicate Stickley White Oak fumed finish from Jeff Jewitt that I like: sand to 120 ros, hand to 150 Olympic special walnut stain X 15min wipe dry, sit overnite rag on Watco dark walnut danish oil sit for 15min wipe off dry over nite rag on coat of zinzer bullseye amber shellac dry overnite lightly rub out w/grey pad wax Want it darker? more Watco or shellac |
05-10-2008, 11:45 PM
#8 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 180 days | Went to Lowe's today to get some Walnut stain and some Watco Walnut Danish oil. Somebody must be doing a lot of A&C styled finishes, as they were flat out of both
Ended up using a bit of Early American stain that I had lying around. I think I will give it a light sanding tomorrow to "pop" the rays, as that did well on my sample piece, then some shellac and lacquer to finish it all off.
Maybe I'll have something to show y'all next Saturday.
Dave
--Dr. Seuss
Posting Rules
Members: 2,318
Threads: 17,288
2nd Top Poster: jeff... (6,592) | | Welcome to our newest member, hogstf | |
