North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > Finishing
Finishing Anything to do with finishing
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 01-24-2009, 09:28 PM   #1
Favorite finish: Sapelle?
City: Charlotte
State: NC
County: Mecklenburg
Threads: 30
Show Printable Version Email this Page   Quote this post in a PM to fergy
fergy fergy is online now 01-24-2009, 09:28 PM
I'm looking for input regarding favorite finishes for sapelle. I want to pop the grain a little, and accent the reds in the wood.
Anyone have a preference or advice? This is my first sapelle project. This sapelle will be the rails and stiles for panels veneered in curly bubinga.
Old 01-24-2009, 10:01 PM   #2
FredP's Avatar
City: franklinton
State: nc
County: franklin
Threads: 120
Avg Visit Freq/Week
= 6.84 over 180 days
Re: Favorite finish: Sapelle?
danish oil then wipe on poly or formbye tung oil if its a small area. the oil realy pops the grain.
__________________
fred p
Hey ya'll watch this!
www.ncwoodencreations.com
Show Printable Version Email this Page   Quote this post in a PM to FredP
Old 01-24-2009, 10:02 PM   #3
Administrator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 692
Avg Visit Freq/Week
= 7.00 over 180 days
Well my favorite finish for just about all woods is a home brewed Danish Oil type finish. About equal parts MS, BLO, and gloss Polyurethane. The oil will give an amber cast to the wood, the thinned poly will add protection without building a plastic type coating, and the MS helps it to be wiped on. I also really like Waterlox Original Sealer/Finish for its repair-ability and color, but it's costly and doesn't have a good shelf life when opened so I reserve it for larger projects. I will probably use it on the cherry stereo cabinet I am working on right now. I have also just recently become a big fan of water based lacquer (poly-acrylic) it's great to spray and doesn't add any color if that is what you are looking for.
I have not worked with Sapelle, but I have used my home brewed Danish oil on Mahogany, which is similar, with great results.
Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 01-25-2009, 09:05 AM   #4
pcooper's Avatar
City: Maiden
State: NC
County: Catawba
Threads: 15
Avg Visit Freq/Week
= 6.07 over 180 days
I worked with some of that wood recently for the first time, and just for fun picked danish oil to finish with, and highly recommend it. The grain looked like it was standing proud of the wood, almost 3D. I was very surprised and pleased with the way it turned out.
__________________
Today a pile of wood, tomorrow a pile of sawdust......
Show Printable Version Email this Page   Quote this post in a PM to pcooper
Old 01-25-2009, 09:19 AM   #5
Mike Davis's Avatar
City: Westfield
State: NC
County: Stokes
Threads: 139
Avg Visit Freq/Week
I use a home brew similar to DaveO except I use Marine Spar Varnish instead of Polyurethane. The Spar Varnish is more forgiving and will not show a line if you sand through it. Marine Varnish has UV inhibitors which may or may not help depending on the location of the finished piece.
This has about 5 coats of my blend. Rubbed with steel wool between coats and finished with Johnson paste wax a month after the last coat.
__________________
I meant to tell you, Mors Kochanski said "thats a spoon made by an expert" -BR-
Show Printable Version Email this Page   Quote this post in a PM to Mike Davis
Old 01-25-2009, 09:24 AM   #6
Rob is offline Rob
Rob's Avatar
City: Sanford
State: NC
County: Lee
Threads: 112
Avg Visit Freq/Week
= 6.81 over 180 days
What is MS? Do you use the Minwax poly you get from the BORG?
__________________
Learning to turn one stick at a time.
http://www.woodsitzestudio.com/
Show Printable Version Email this Page   Quote this post in a PM to Rob
Old 01-25-2009, 09:26 AM   #7
Webmaster
Administrator
Senior Moderator
TracyP's Avatar
City: Salisbury
State: NC
County: Rowan
Threads: 332
Avg Visit Freq/Week
MS is mineral spirits.
__________________
Tracy
Making Friends One Post At A Time
The task is always worthwhile if you learn something in the process.
Show Printable Version Email this Page   Quote this post in a PM to TracyP
Old 01-25-2009, 09:28 AM   #8
City: Charlotte
State: NC
County: Mecklenburg
Threads: 30
Avg Visit Freq/Week
= 6.53 over 180 days
Thanks for the inputs, guys.
The pieces will wind up getting a lot of UV on them, as well as being in a high humidity environment, in that they are being used for a reef aquarium stand and canopy. The canopy will get the most of the humidity as well as high temperature.
But, I've always been a Danish oil fan. I guess it's time to test that out again. I was leaning toward the Arm-r-seal stuff again, but as stated in another thread I've had troubles with it in the past.
I was pondering spraying catalyzed lacquer, as I've got a setup for that. I just want to make sure I get the grain to pop as much as I can.
So is anybody using a grain filler with this stuff, or dying it at all to increase contrast?
Old 01-25-2009, 09:32 AM   #9
mlzettl's Avatar
City: Morehead City
State: NC
County: Carteret
Threads: 11
Avg Visit Freq/Week
= 6.65 over 180 days
I concur with the above posts recommending a penetrating oil. Depending upon the intended use, varying degrees of protection can be achieved according to the product that you're using.
I've used both Danish Oil and Waterlox for over 30 years, and have preferences of one or the other depending upon the project. I'm currently putting on the last coats of Waterlox on a dining table. An excellent product, but pricey as Dave remarked, and it's best if you can use the whole can, as the shelf life is quite disappointing, no matter what you do to try to prolong it.
Just about any finish that you decide upon will look good if you take your time with surface prep and finish application. In my experience, it is not the particular product that is most important. When finished well, sapele is almost indistinguishable from true mahogany (Swietenia macrophylla). In fact, I would defy most people to be able to distinguish the two.
Be sure to show us the results!
Show Printable Version Email this Page   Quote this post in a PM to mlzettl
Old 01-25-2009, 09:41 AM   #10
City: Charlotte
State: NC
County: Mecklenburg
Threads: 30
Avg Visit Freq/Week
Not just pics of the final piece. I promise I'll post a documentary of the work in progress.
In a related question, do any of you happen to know the Genus/species of what's being passed as "African mahogany"? I know sapelle is often used as a substitute, but I'd like to know what this other wood I've got truly is.
Old 01-25-2009, 10:16 AM   #11
bluthart's Avatar
City: Iron Station
State: NC
County: Lincoln
Threads: 41
Avg Visit Freq/Week
= 5.02 over 180 days
If you have that much moisture, I think McClosky's Man-O-War Spar Varnish might do well after your oil finish. I have used it on Brazilian Cherry and it really pulls out the grain, and is great protection against UV and moisture. This is so cool - I have actually have experience with something you guys are talking about on here!
Show Printable Version Email this Page   Quote this post in a PM to bluthart
Old 01-25-2009, 10:25 AM   #12
bluthart's Avatar
City: Iron Station
State: NC
County: Lincoln
Threads: 41
Avg Visit Freq/Week
I believe it is Khaya, or Khaya ivorensis. Another species is Sipo, which grows in Africa and is an excellent substitute for Pattern grade Honduras Mahogany.
I own some of each of this but haven't had a chance to play with it yet.
Old 01-25-2009, 11:30 AM   #13
mlzettl's Avatar
City: Morehead City
State: NC
County: Carteret
Threads: 11
Avg Visit Freq/Week
African mahogany is Khaya ivorensis.
Sapele is Entandrophragma cylindricum.
Sipo is Entandrophragma utile, also known as Utile,which is the name that I have seen most often.
None of these woods is true mahogany, which grows naturally only in the Western Hemisphere. True mahoganies belong to the genus Swietenia and include Honduran (macrophylla) and East Indian or Cuban (mahogani), the most highly prized of all mahoganies, rare and expensive. Most Honduran now comes out of Brazil.
Old 01-25-2009, 01:45 PM   #14
FredP's Avatar
City: franklinton
State: nc
County: franklin
Threads: 120
Avg Visit Freq/Week
if it will be around a reef [salt water] tank I recomend spar urathane for sure. salt water reeks havok with most finishes.
__________________
fred p
Old 01-25-2009, 01:49 PM   #15
City: Charlotte
State: NC
County: Mecklenburg
Threads: 30
Avg Visit Freq/Week
I've actually had fine results with sprayed polyurethane before, on a piece that came out of a production shop. I've also been okay with the Arm-r-seal. I don't want to get nuts with spar urethane except on the inside, because it tends to look plastic.
I'd be fine with several coats of catalyzed lacquer as well. I'm not submerging anything. But I'm worried that the danish oils wouldn't be enough.
Closed Thread
favorite , finish , sapelle
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wood - what's your favorite / least favorite jeff... Wood 50 07-06-2008 12:19 PM
My Favorite Pen jeff... Woodturning 18 05-12-2008 12:09 AM
Favorite Wood jeff... Wood 30 11-19-2007 09:47 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,667
Threads: 25,111
Top Poster: DaveO (14,702)
Welcome to our newest member, Brockmania
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
