North Carolina Woodworker
Donation Drive Ends March 15
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > Finishing
Finishing Anything to do with finishing
» Upcoming Events
Piedmont Wood Workers Guild March 20thFor more details......
Geodesic Shop Crawl April 10th Click for more info
Welcome New Member Chat! Every Thursday evening at 7:30pm Click here for more!
Closed Thread
Thread Tools Display Modes
Old 06-03-2009, 11:26 AM   #1
Exterior finish for pine chair
Tom Dunn's Avatar
City: Duncan
State: NC
County: Harnett county
Threads: 87
Show Printable Version Email this Page   Quote this post in a PM to Tom Dunn
Tom Dunn Tom Dunn is offline 06-03-2009, 11:26 AM
I need to choose a finish for an Adirondack chair, made of pine, that will be left outside.
I'm of the opinion that spar varnish is likely the "standard", but thought I'd also solicit the ideas and advice of the folks here!
Thanks!
Old 06-03-2009, 01:07 PM   #2
City: Bolivia
State: NC
County: Brunswick
Threads: 2
Avg Visit Freq/Week
= 6.03 over 180 days
Re: Exterior finish for pine chair
First, pine is a very poor outdoor wood. It easily rots when it gets wet. There are other woods that would have been better choices.
Second, no finish lasts long when it is continually exposed to sunlight and other outdoor conditions. The more clear the finish, the quicker the finish will deteriorate. Even with the best true marine clear finishes, the best you can expect is about a year at which time the finish will need to be sanded and a couple of new coats applied. Stay away from any of the Big Box exterior "spar" poly varnishes. Any finish containing polyurethane is quickly attacked by the UV in sunlight. It quickly gets cloudy and loses adhesion and then chips off.
The more opaque the finish, the longer it will last. Therefore, a good exterior oil based paint is the longest lasting finish you could use. Good paints can last 3-5 years in many cases.
The bottoms of the legs are the most prone to water absorption and therefore, the part that rots first. The best plan is to thin your finish one part finish to four parts mineral spirits. Pour it into a container that the leg will fit into. Let the leg sit in the liquid for 24 hours. Then prop it up so the leg can dry for 48 hours. Once you have all the legs treated, you can begin applying your clear of colored coat.
Show Printable Version Email this Page   Quote this post in a PM to Howard Acheson
Old 06-03-2009, 01:26 PM   #3
Site Programmer
froglips's Avatar
City: Hillsborough
State: NC
County: Orange
Threads: 571
Avg Visit Freq/Week
= 7.00 over 180 days
Howard nailed it.
Adding to what he said, look at adding feet to the legs. Something to keep the end grain wood off the ground.
Even nailing on some edge grained wood like cedar, ipe, mahogonay or teak.
Also, an old time wood treatement is 50/50 turpentine/BLO blend is pretty good. Apply this and let it dry for maybe a week or longer. Then paint. You could also soak the legs in this mix.
__________________
If I were a frog and my friends were in a pot of boiling water I would be of better use if I stayed on the outside and turned the heat off.
216
Hillsborough Orange Woodworkers Meetup
Show Printable Version Email this Page   Quote this post in a PM to froglips
Old 06-03-2009, 01:37 PM   #4
City: Winston Salem
State: NC
County: Forsyth
Threads: 2
Avg Visit Freq/Week
= 1.28 over 180 days
The May/June 2009 issue of FWW (No. 205) did a review of different finishes and concluded that penetrating oil finishes were essentially worthless, water-based finishes and spar varnish finishes not much better. They found 2 that worked quite well after one year, both made by epifanes (www.epifanes.com) But one required 7 coats! And it ain't cheap. ( I haven't tried epifanes and prolly won't but just to let you know it's out there.)
As others have said, pine's not your best choice for outdoor applications. You might try coating exposed grain with Titebond III waterproof glue. And recoat periodically. My parents used a colored stain on their deck three years ago and it still looks quite good. So if you don't care about showing the wood's grain, might go with a stain rather than paint. Paint cracks and peels and is difficult to renew. Stain is easier to refresh.
Good luck!
Show Printable Version Email this Page   Quote this post in a PM to Adirondax
Old 06-03-2009, 05:37 PM   #5
Tom Dunn's Avatar
City: Duncan
State: NC
Threads: 87
Avg Visit Freq/Week
= 1.52 over 180 days
The point about pine outdoors is well taken.
However, if you follow my twisted thinking.....
There ain't no cypress in the Adirondacks.
There ain't no oak in the Adirondacks.
There is, however, PINE in the Adirondacks! LOTS of pine!
And, superior protection or not, **** will be a glacier before I paint wood.
Poor ol pine, it don't get no respect.........
Closed Thread New posts
chair , exterior , finish , pine
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
General 450 Exterior Finish JackLeg Finishing 2 03-26-2008 04:06 PM
Most Durable Finish for Exterior Door thesource Finishing 4 01-27-2008 11:06 PM
exterior oil finish jeeves Finishing 3 01-23-2008 06:31 AM
finish new knotty pine paneling for rapid darkening dedeonce Finishing 3 08-10-2007 11:50 AM
White Pine Finish ? owen299 Finishing 5 03-30-2006 02:14 PM
» Stats
Members: 4,212
Threads: 28,017
Top Poster: DaveO (15,002)
Welcome to our newest member, phil.waller
» Today's Birthdays
None
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
