North Carolina Woodworker
Kreg Router table raffle drawing this afternoon!!! Please jump up and down in anticipation...
Go Back   North Carolina Woodworker > Woodworking > Finishing
Notices
Finishing Anything to do with finishing
» Announcements
Raffle is now closed. Raffle numbers have been Email Please Read . Drawing 12:30 pm Thursday 1/8/09 (GOOD LUCK)!!
1st Qtr
Donation Drive Please Donate! Please Read!
Featured Photos
by Touchwood
42 photos
114 comments
by Terry
385 photos
19 comments
by jack briggs
32 photos
76 comments
by PurpleThumb
26255 photos
9608 comments
» Online Users: 77
33 members and 44 guests
Adirondax , Badabing , Bas , Bigdog72 , Bill Kallam , ChrisMathes , dancam , DavidF , dferg , DIYGUY , ErnieM , gesiak , Glennbear , Jim Murphy , JimmyC , Joe Lyddon , JohnsonMBrandon , Larry Rose , michaelgarner , MIKE NOAH , MikeF , mkepke , PeteM , ptt49er , RandyJ , rbdoby , reprosser , RSM , Sharp Blade , Tar Heel , thrytis , woodArtz , zapdafish
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 01-02-2007, 02:02 PM   #1
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 163
Avg Visit Freq/Week
= 3.81 over 180 days
Many have followed the questions I had from many months ago as I began the journey to "spraymanship" I had decided that enough was enough of the wipe on stuff and brushing finishes and time to get serious!!
After much investigation I ended up with this spray gun:
Amazon.com: Titan 4-Pc. HVLP Triple Setup Paint Spray Gun Kit, Model# 19220: Tools & Hardware
A good value gun I think. I have a 3 hp 10.3 cfm @ 90psi compressor to go with it. I bought a new 3/8th hose to give as much flow as possible. Spraying the bases which were roughly 4' square the compressor kicked in just once per side.
After much input from the guys here I decided to go with this finish system:
Target coatings Shellac sealer: Target Coatings - Products - Oxford UltraSeal-WB™
And Target coatings Lacquer: Target Coatings - Products - OXFORD ULTIMA SPRAY LACQUER
One coat of the sealer followed by 3 finish coats. The sealer was rubbed down with 400 paper before the next coats. I applied 2 more coats of the lacquer, rubbed down again with 400 and then applied the top coat. Spay interval was 1hr between coats unless I was sanding and for those I left 2 hrs. Both products sanded perfectly, sanding off a fine white dust without clogging the paper.
I was truly concerned about the gun setup so practised and practised and practised and practised...... until I was happy that I knew what all the adjustments on the gun were for! I started with spraying water and then moved to the lacquer (see later for **** up). I could not quite get the beautiful, even horizontal fan with equal dipping over the full length that I saw in some pics, but I could see the effects of the controls.
I found that above 30 psi at the gun inlet there was no real difference in atomization, the noise just got louder and the product bounced back more! The gun actually has the stamp "HVLP max 20psi) on the handle and I found that this means that to "comply" with regulations governing HVLP and to ensure that you do not have more than 10psi at the tip, then this is the max pressure. I actually ended up using 25 psi for all the spraying. The inlet restricter valve was fully open all the time.
For the base boxes I used the largest fan width which with this gun wasn't that big, say max 6" long. for this setting I used a material flow control of 2 turns out from fully closed. and this gave me a full wet coat.
For spraying the frames etc I tuned the fan down to about 50% full width and turned the material control in a half turn.
I sprayed the bases without the shellac sealer, they just had 3 coats of the lacquer.
When It came to the frames my first mistake was to assume that the shellac would spray the same - wrong!!!! it was worse than spraying water!!! it was dripping all over the place and going on way to much. Ok, I thought lets just try wiping it off, it can only mess it up completely and wreck 6 months work Much to my amazement I was able to wipe off the excess and clean it all up and when it was dry it was perfectly flat and all nice and smooth -an amazing product. Gun settings for this were the same inlet pressure but flow control was only one full turn out from closed, much better.
The lacquer coats went really well with one hr between coats. My other major screw up was forgetting to change from a horizontal fan I was using on the legs to a vertical fan for most of the spraying! there I was wondering why I had all this thick white mass of finish going on to the side rails! I was playing with flow, pressure etc, etc before I realized and then smacked myself in the head!! I had no choice but to leave it and get on with the other frames.
When the stuff had dried it was a real mess with runs all over the place. I took some 180G and sanded away all the runs, of course going through the original shellac as well!! Well I just got some of that shellac on cloth and rubbed it on and let it dry. As before it dried perfect
I made a similar mistake on the last coat on one of the bases and was spraying with the wrong fan orientation (will I never learn?) and again ended up with a coat of finish about 1/16" thick!! well as before, nothing ventured etc.... So I got a slightly damp cloth and wiped it off!! It dried perfectly!!!!!! this stuff rocks...
End result was very, very nice straight off the gun although I will probably wire wool and wax the most "tactile" parts of the bed!!
The colour with the shellac base was a warm, almost pink shade on the cherry which I loved. I really don't go for the very red cherry that one see's on commercial furniture.
I was glad I went the spray route and will not be going back to the old ways very soon. It was much easier than I thought it was going to be and I am sure that is mainly because of the most forgiving nature of the Target coatings products - highly recommended. The Titan gun was $87 from amazon and I would also recommend this gun to anybody just starting out.
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Show Printable Version Email this Page   Quote this post in a PM to DavidF
Old 01-02-2007, 02:14 PM   #2
MikeH's Avatar
City: Indian Trail
State: NC
County: Union
Threads: 138
Avg Visit Freq/Week
= 6.69 over 180 days
Thanks for the insight David. It's always great to gain insight and knowledge from others experience. Do you have pics of the project? I'd like to see the finished product.
__________________
__________________________________________
Take the attitude of a student, never be too big to ask questions, never know too much to learn something new. Og Mandino
Show Printable Version Email this Page   Quote this post in a PM to MikeH
Old 01-02-2007, 02:18 PM   #3
Travis Porter's Avatar
City: Wake Forest
State: NC
County: Wake
Threads: 139
Avg Visit Freq/Week
= 5.83 over 180 days
Good to hear you survived Dave. I am getting ready to use the exact same finishes on my dresser so I know what not to do with the shellac now. The Target stuff is great stuff in my opinion. This will be my first time with the shellac, but I have no regrets with it whatsoever in the Lacquer.
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 01-02-2007, 02:38 PM   #4
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 163
Avg Visit Freq/Week
Hi Travis, If you haven't bought the shellac yet then I have a lot spare. I bought a gallon, but only used one spray gun full!! offer is there to anybody else also if you want a pint or two FOC please give me a shout.
I just ordered some of their Emtech 8000 series conversion varnish to re-finish our dining room table.
__________________
Old 01-02-2007, 02:40 PM   #5
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 163
Avg Visit Freq/Week
Right here: http://www.ncwoodworker.net/pp/showgallery.php?cat=772
__________________
Old 01-02-2007, 02:49 PM   #6
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 163
Avg Visit Freq/Week
This was the respirator I purchased to wear during the spraying. Very comfortable and the quick latch is a great idea.
<br>QUICKLATCH™ PRO Dual Cartridge Respirator
__________________
Old 01-02-2007, 03:34 PM   #7
City: Wake Forest
State: NC
County: Wake
Threads: 139
Avg Visit Freq/Week
Thanks for the offer, but unfortunately, I have a gallon as well. Bought it at the same time as the Lacquer. When you say a "gun full", one quart cup? I am planning to spray the drawers and all with it so maybe I will use a bit more.
Old 01-02-2007, 03:36 PM   #8
dancam's Avatar
City: Asheville
State: NC
County: Buncombe
Threads: 46
Avg Visit Freq/Week
= 6.73 over 180 days
David,
Many thanks for sharing your experience with HVLP spraying. I bought a cheap HVLP gun from HF and will be giveing it a try in the near future, so your experince will come in handy.
I also really like the bed....great design and the integrated lights are super...good work.
Dan C.
__________________
And in the end, it's not the years in your life that count. It's the life in your years.-- Abraham Lincoln
Show Printable Version Email this Page   Quote this post in a PM to dancam
Old 01-02-2007, 03:40 PM   #9
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 163
Avg Visit Freq/Week
Yep, One qt cup, that stuff goes a looonnngggg way
__________________
Old 01-02-2007, 03:42 PM   #10
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 163
Avg Visit Freq/Week
Originally Posted by dancam View Post
David,
Dan C.
Thanks Dan, I would like to see the difference in finish between a $300 gun and the guns at the Titan end. Certainly in my hands . I guess it would be more even atomization across a larger fan as I mentioned in the posting.
__________________
Old 01-02-2007, 04:43 PM   #11
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 163
Avg Visit Freq/Week
One thing that was a pain was the stiffness of the 3/8th hose I had. Any body know of a super flexible hose that would be great for the final 10 ft or so before the gun?
Thanks.
__________________
Old 01-02-2007, 04:56 PM   #12
NZAPP1's Avatar
City: Clemmons
State: NC
County: Davidson
Threads: 94
Avg Visit Freq/Week
= 6.84 over 180 days
Thanks Dave for sharing your experience with both the spray equipment and the coating product I may have to buy that set up since it has worked so well for you
__________________
Nick Z
To do important deeds, two things are necessary; a plan and not quite enough time.
Show Printable Version Email this Page   Quote this post in a PM to NZAPP1
Old 01-02-2007, 07:12 PM   #13
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 48
Avg Visit Freq/Week
= 5.91 over 180 days
David: Looks like you did very well with it and made some excellent recoveries from your "learning experiences"! As for the air hose, from your post it appears you are getting plenty of air to the gun based on your being able to cut the pressure down significantly from the maximum. With this in mind, a 1/4"id hose for the last 10' should supply sufficient air volume. It can be bought in very flexible formulas, and you could also use vinyl.
Keep in mind that the more flexible the hose, the easier it is to kink it and cut off your air supply. They sell the vinyl in self-coiling packages with fittings attached. Personally I have found these to be a real pain with the loops getting caught or tangled around anything remotely in reach, as well as prone to kinking. They do work very well if you suspend your hose overhead so the vinyl hose drops from the ceiling. This has the added advantage of removing the hose from being a tripping hazard. If you go with a rubber-type hose, you may have to buy it by the foot and install your own fittings. You should be able to get it at an auto-supply outlet or agri-supply, etc. Anything with a burst pressure of double the maximum of your air supply will work.
As for the shellac going on too heavy at first: The thinner the coating (i,e the faster it runs off the stir stick) the less you want coming out (the fluid adjustment closed more for the thinner coating). I noticed from the Target water-based lacquer spec sheet that it has a viscosity of about 40 seconds with a #2 Zahn cup. That's fairly thick as far as spray finshes are concerned. I imagine the shellac would be closer to 15 secs, so closing the fluid adjustment was exactly correct.
Thanks for sharing your experiences and your review of the spray system. There is a lot of good info there for both novices, and the more experienced that have not sprayed the water-borne finishes yet.
__________________
History will not judge you on the advice you give, but rather on what you yourself have done.
Show Printable Version Email this Page   Quote this post in a PM to Gofor
Old 01-02-2007, 07:21 PM   #14
NCPete's Avatar
City: Hope Mills
State: NC
County: Cumberland
Threads: 206
Avg Visit Freq/Week
= 6.96 over 180 days
yeah, I have the vinyl self coiling hose for the last 20 feet of my hose now, and it does catch everything, including my feet, but the tool in hand is soooo much lighter
__________________
Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it.
Henry David Thoreau
They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin
Show Printable Version Email this Page   Quote this post in a PM to NCPete
Old 01-02-2007, 08:26 PM   #15
stoneskippers's Avatar
City: Forest City
State: NC
County: Rutherford
Threads: 27
Avg Visit Freq/Week
= 0.00 over 180 days
Great job on the bed. I really like your design.
__________________
John Skipper
"Don't worry about the mule going blind, load the wagon."
Show Printable Version Email this Page   Quote this post in a PM to stoneskippers
Closed Thread
bed , spraying , story
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Cleanup after spraying BIN snojcb Finishing 3 12-24-2006 04:40 PM
Thinking of Spraying Finishes skysharks Finishing 3 10-07-2006 08:30 PM
Wow, what an incredible story DaveO Old Off Topic Forums 10 09-24-2006 10:24 AM
HVLP spraying Travis Porter Finishing 17 03-06-2006 04:20 PM
PC holiday story Steve D Old Off Topic Forums 1 12-22-2005 04:09 PM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,317
Threads: 17,288
2nd Top Poster: jeff... (6,592)
Welcome to our newest member, Dildayk
» Today's Birthdays
fivestring (50)
Ncdawgs1882 (27)
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
