North Carolina Woodworker
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Reviews
Reviews Post your own review of tools, stores websites, etc.
» Upcoming Events
Klingspor Wood Workers Show Case - Raleigh, NC -- September 11
Klingspor Extravaganza - Hickory, NC -- October 29 and 30
2011 North Carolina Woodworker Calendar Contest
Entry deadline by August 16th
Click for more!!
Welcome New Member Chat! Every Thursday evening at 7:30pm Click here for more!
Closed Thread
Thread Tools Display Modes
Old 12-29-2009, 11:48 PM   #1
JJP-12HH review
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 265
Show Printable Version Email this Page   Quote this post in a PM to Bas
Bas Bas is offline 12-29-2009, 11:48 PM
Administrator
I've only had it for a few weeks, but figured I'd share my experience with the machine since several people have asked some questions about it.
Introduction
First, a bit of background: Before I bought this machine, I was using a 6” Grizzly Jointer and a Ridgid 13” lunchbox planer. That’s fairly standard equipment in the woodworking world. There were two main reasons I wanted to upgrade:
  • Jointer capacity. I don’t like having to rip boards down because my jointer can’t handle them. Yes, a planer sled works, but it is very cumbersome.
  • Setting knives. I hate setting knives. It often turned into an all-day affair, even with jigs and a dial indicator.
I estimate that an 8” jointer would handle 60% of all the lumber I typically buy, a 10” jointer would handle 85%, and a 12” jointer 98%. For those once-in-a-lifetime boards, I’ll find someone with an aircraft carrier.
As for setting knives, while there are indexed knife systems, by far the best solution is to use a helical head with carbide inserts. The carbide lasts longer, reduces tearout, and the inserts are easy to rotate/ replace. But it’s not cheap. And it doesn’t make a lot of sense to buy a jointer with a carbide helical head but use ordinary knives in the planer. That’s when I started to look at a combination machine.
Combination machine
With a combination machine, you use the same head for both jointing and planing, meaning you only pay for the helical head once. That’s a big plus. At 600sq.ft. I have a decent sized shop, but it’s not a ballroom. It’s not too hard to fit two separate machines; the tricky part is making sure you have enough room (8+ ft.) on both the infeed and outfeed side. That’s much simpler with a single machine.
There are many good combination machines available, but in my price category, there are only two real choices: The Grizzly G0634Z (which replaces the G0634) and the JET JJP-12HH. I had the good fortune to see both machines beforehand. Both looked very solid and well-made. In the end, I decided against the Grizzly for two reasons: First, the fence on the Grizzly must be removed from the machine before switching to planer mode . That’s not so easy to do in a small shop – where are you going to put it? Second, the machine is almost a foot wider (deeper) than the JET because of the rack-and-pinion fence system.
Installation and setup
The machine was delivered in a large, wooden crate. It wasn’t the best packaging (it was nailed to the pallet in a rather ungainly fashion), but it protected the machine, which is what mattered. This thing is HEAVY, so if you need to move it, get some help. Installation is a snap: Remove the packing material, clean the cosmoline off the tables (which was a only a very light coating) and attach a plug to the cord. Everything was dead-on from the factory.
I put casters from Great Lakes on my machine; they fit perfectly in the holes used to bolt the legs to the crate. Once lowered, the machine is very stable. There is a little “give” if you push hard against the top of the machine, but it doesn’t move at all, even when jointing large, wide boards with some force. I don’t plan to move this machine more than once a year (if that), so instant mobility was not high on the list of requirements (raising the feed requires getting down and dirty to move the turn wheels on the casters).
The machine was perfectly aligned out of the box. I put a 36” straightedge across the infeed and outfeed tables, and it was dead flat. I face jointed a 4’ board and put the straightedge on that – dead flat.
Motor and electrical
The machine has a 220V 3HP motor. The amperage requirements are somewhat confusing. The manual lists the motor at 12.5A, for both the helical- and non-helical versions. Yet the manual states the helical version requires a 30A breaker, whereas the non-helical version requires only a 20A breaker. I went with the motor specs, and plugged it into a 20A outlet. No problems whatsoever.
The machine makes a very satisfactory rumble when started up. It’s radically different from the noise my Ridgid used to make, it’s much, much quieter. Two simple buttons control the machine, one red, and one green. I didn’t need the manual to figure out which is which.
Jointer operation
The jointer uses a European style guard, which is quite different from the “pork chop” guard. I definitely prefer the Euro guard, the pork chop guard was always slamming back at the wrong time, or a thinner piece of stock would get caught underneath it. This is a much better design, and a breeze to adjust.
The fence is my least favorite part of the machine. It’s certainly solid enough, in that it doesn’t flex when you joint your boards. That’s critical. But to move the fence, you have to loosen it via two handles. There isn’t much room to turn them, so if you need to loosen/ fasten more you lift up on the handle and return it to the original position. I might replace them with some knurled knobs. Also, the fence is not parallel to the table. It doesn’t need to be of course, but if you’re used to the rack-and-pinion system, it takes some getting used to. This is where the Grizzly machine does better, and why it’s a foot deeper. I also found it slightly difficult to set the fence 90 degrees to the table. If I lock it down “as-is”, my Wixey digital angle gauge shows 90 degrees at the bottom of the fence and 89.5 at the top. If I apply a little bit of pressure to the top of the fence when I lock it down, it’s 90 degrees all the way. So I may need to do a little filing. I don’t think the 0.5 degrees really matters much anyway.
Enough has been written about a helical head with carbide inserts. So I’ll just add this: Wow. The machine comes with 10 replacement inserts, although for some reason the little plastic box I received only had 5. A quick call to JET’s customer service fixed that. So now I have 15. With any luck, they’ll go unused for a long time.
The infeed and outfeed table are “ribbed”, which supposedly reduces friction. I’m still on the fence as to whether I prefer ribbed or smooth. The stock feels more secure as you joint it, but I suspect the ribbing adds some friction, although I only noticed this as I was joining an 11 ½” wide piece of 8/4 Purpleheart. The cutterhead may also be contributing to this feeling of resistance; it feels as if the cutters are pushing the board down.
Dust collection in joiner mode is outstanding. Even with an ordinary 1.5HP DC, very few chips escape the jointer. The helical head helps here: there are no long protruding knives that fling the chips onto the table.
Planer operation
At first, the planer table appeared “short” because there are no infeed/ outfeed tables like my Ridgid had. But you don’t need them. I planed longer boards (6ft) as well as short boards (18”), zero snipe. There is a lever you have to move in order to engage the feed rollers, it’s a little stiff but works fine. Locking the height is easy and secure. When you feed the board, you can really feel when the roller grabs the board. And once it has the board, it’s held flat. I really like the tactile feedback you get from this. Dust collection is good, a few chips fall on/ beside the planer table, but 99% gets sucked up as expected.
Oh, and did I mention the helical head with carbide inserts? I planed a variety of species (QS red oak, FS white oak, Purpleheart, Hard Maple, QS Sycamore and QS beech) just to see how it would handle different grain patterns. The Sycamore had some very wild figure, and the oak had lots of knots and swirling grain. I planed each board with- and against the grain. The results were outstanding. With the red oak and Sycmore, I had to use slightly shallower cuts to avoid tearout, but not by much. The results were much better than with my Ridgid planer. The only way I could come close to these results would be with fresh knives and feeding the boards at an angle.
Jointer/ planer changeover
This is the real test of course. I am very happy to report the changeover is extremely fast. The most time consuming part is raising/ lowering the planer table. This is because the dust collection chute must be flipped between modes, and the planer table has to be 7” below the cutterhead for that. The table moves very smoothly, so it’s not too big of a job. I had seen a modification to use a power drill to move the table up and down, but I decided it’s not worth it. All-in-all, the changeover takes about 20 seconds. If I had a separate joiner and planer, I’d probably spend the same time wheeling each machine into position.
Summary
Overall, I’m very pleased with the machine. It is well engineered, it has plenty of power, and the helical head tackles even the toughest grain. I think JET has found a real sweet spot here, offering features normally found on much more expensive machines, and in a very compact form at that. I’m not going to presume it is in the same league as some of the more industrial machines from Hammer and Felder, but I don’t do this for a living. I suspect this machine will last me a lifetime, which works for me.
Would I buy this machine if I had a 30x40 shop? That's tough to say. A 12" jointer with helical head is only a few hundred dollars cheaper than the JJP-112HH combination machine, so is the extra cost of a planer worth it to avoid the changeover time? I'm not even going to worry over that!
__________________
Bas.
"I don't need it. I just want it."
How to add a picture to your post
Old 12-30-2009, 12:07 AM   #2
ErnieM's Avatar
City: Chocowinity
State: NC
County: Beaufort
Threads: 103
Avg Visit Freq/Week
= 6.69 over 180 days
Re: JJP-12HH review
That was a great review! Best of luck with your new "toy".
Ernie
__________________
www.ernestmillerharpsichords.com
"A lot of people are afraid of heights. Not me, I'm afraid of widths."
-Steven Wright.
Show Printable Version Email this Page   Quote this post in a PM to ErnieM
Old 12-30-2009, 05:21 AM   #3
FredP's Avatar
City: franklinton
State: nc
County: franklin
Threads: 148
Avg Visit Freq/Week
= 6.81 over 180 days
Re: JJP-12HH review
great review bas. soon as I get the latest project out the door I'm going to hit you up for a visit. gotta check out the euro guard and the new man cave!
__________________
fred p
If it ain't broke you aint trying hard enough
www.ncwoodencreations.com
Show Printable Version Email this Page   Quote this post in a PM to FredP
Old 12-30-2009, 06:57 AM   #4
Secretary
Trent Mason's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 160
Avg Visit Freq/Week
= 7.00 over 180 days
Re: JJP-12HH review
Great writeup Bas. I'm glad your new aircraft carrier is working well.
__________________
Trent
trentmason.com
"Two roads diverged in a wood, and I--
I took the one less traveled....."
-Robert Frost
"We should never separate the lives we live
from the words we speak."
-Paul Wellstone
Show Printable Version Email this Page   Quote this post in a PM to Trent Mason
Old 12-30-2009, 08:10 AM   #5
Events Director
ScottM's Avatar
City: Littleton
State: NC
County: Warren
Threads: 375
Avg Visit Freq/Week
= 6.46 over 180 days
Re: JJP-12HH review
I have seen it in operation and it is one sweet machine. BTW when Bas say it is heavy he means HEAVY. Took 4 men and a boy to move it in.
__________________
Maker of fine saw dust
Show Printable Version Email this Page   Quote this post in a PM to ScottM
Old 12-30-2009, 08:29 AM   #6
Site Programmer
froglips's Avatar
City: Hillsborough
State: NC
County: Orange
Threads: 667
Avg Visit Freq/Week
Re: JJP-12HH review
I really enjoyed your review. Very well written. I also applaud sharing your thought process and the key decision points.
But, I had one question. Do you like the helical cutter head?
__________________
One cannot overemphasize the importance of good plane management.
Robert Wearing, Essential Woodworker
Hillsborough Orange Woodworkers Meetup
200
Show Printable Version Email this Page   Quote this post in a PM to froglips
Old 12-30-2009, 09:01 AM   #7
Bas is offline Bas
Administrator
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 265
Avg Visit Freq/Week
= 6.96 over 180 days
Re: JJP-12HH review
Anytime Fred. I think I have a book lying around that has your name on it too!
I like it almost as much as I hate setting knives.
__________________
Bas.
Old 12-30-2009, 09:14 AM   #8
PeteM's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 189
Avg Visit Freq/Week
Re: JJP-12HH review
Great review but . . .
You said: "I was joining an 11 ½” wide piece of 8/4 Purpleheart."
Watcha doin' with that?!?!?!
pete
__________________
"Man is so made that he can only find relaxation from one kind of labor by taking up another."
-Anatole France
Show Printable Version Email this Page   Quote this post in a PM to PeteM
Old 12-30-2009, 09:16 AM   #9
ptt49er's Avatar
City: Harrisburg
State: NC
County: Cabarrus
Threads: 82
Avg Visit Freq/Week
Re: JJP-12HH review
Great write up! Now if only I can find the change to buy one
__________________
~Phillip
"Okay Hunny, so my hobby is collecting other hobbies. Atleast I'm well rounded!"
Show Printable Version Email this Page   Quote this post in a PM to ptt49er
Old 12-30-2009, 09:21 AM   #10
Mt. Gomer's Avatar
City: Durham
State: NC
County: Durham
Threads: 80
Avg Visit Freq/Week
= 6.22 over 180 days
Re: JJP-12HH review
pete
My thoughts exactly!?!?!?
Great write up, Thanks!
Show Printable Version Email this Page   Quote this post in a PM to Mt. Gomer
Old 12-30-2009, 02:09 PM   #11
City: Clayton
State: NC
County: Johnston
Threads: 203
Avg Visit Freq/Week
= 5.17 over 180 days
Re: JJP-12HH review
Great review Bas, and the answer to whether you would buy this machine if you had a 30x40 shop is yes, because even with all of that room you can find other things (such as wood) to fill the space. DAMHIKT .
Good luck with the new toy !
__________________
Jimmy
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did" Mark Twain
Show Printable Version Email this Page   Quote this post in a PM to JimmyC
Old 12-30-2009, 03:14 PM   #12
Bigdog72's Avatar
City: Lillington
State: NC
County: Harnett
Threads: 141
Avg Visit Freq/Week
Re: JJP-12HH review
Sounds like its time for another shop crawl!
__________________
WORK EVERYDAY LIKE YOU DON'T NEED THE MONEY!!
TREAT YOUR CHILDREN RIGHT, THEY PICK YOUR NURSING HOME!!!
Show Printable Version Email this Page   Quote this post in a PM to Bigdog72
Old 12-30-2009, 03:25 PM   #13
Bigdog72's Avatar
City: Lillington
State: NC
County: Harnett
Threads: 141
Avg Visit Freq/Week
Re: JJP-12HH review
__________________
Old 12-30-2009, 08:00 PM   #14
Canuck's Avatar
City: Cary
State: NC
County: Wake
Threads: 207
Avg Visit Freq/Week
= 7.04 over 180 days
Re: JJP-12HH review
Fantastic review there, Bas!!!!
Me thinks you missed your calling though. Should've been an editor or reviewer for one of those woodworking magazines or working in the JET marketing department!
Something tells me that you don't particularly enjoy changing out planer knives, eh!?
I am sure that you will get lotsa years out of this piece of equipment. (I thought about you all day today as I ripped 10" pieces of white oak before I plowed them through my little 6" Ridgid jointer! Oh well! Only 7 more 8 footers to go!)
Thanks for the great review!
__________________
..............found out many years ago that Elbow Grease doesn't come in a bottle!!!!
Show Printable Version Email this Page   Quote this post in a PM to Canuck
Old 12-30-2009, 08:15 PM   #15
MikeCSmith's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Re: JJP-12HH review
BAS,
I just finished reading your review. Thanks very much for doing this. The one thing I always hear people say is the fence is too short. However another reviewer I read in one of the wood magazines said that it wasn't a problem and it does not seem to be a problem for you either. One of my worst shop experiences is adjusting my jointer knives, even with all the right jigs, it's still a terrible job (probably a user problem).
Thanks again for the great review, I'm interested in this machine, I'm going to buy a lotto ticket this week.
Show Printable Version Email this Page   Quote this post in a PM to MikeCSmith
Closed Thread New posts
helical head , jet , jjp-12hh , jjp12hh , jointer/planer combo , review
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
review of OS Keye General Woodworking 8 10-08-2008 09:34 PM
Help with Powermatic PJ-882 Review tom hintz Power Tools and Their Use 8 01-15-2008 11:44 AM
How to get discount qualified
Kreg Ad
The Woodworking Source Ad
Mountain Sawyers Ad
Lee Valley ad
» Stats
Members: 4,585
Threads: 30,664
Top Poster: DaveO (15,152)
Welcome to our newest member, JonathanK
» Today's Birthdays
legmaker (58)
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
