| Freud js102 biscuit joiner Name: William City: Cedar Mountain State: NC County: Transylvania Join Date: Nov 2005  12-05-2005, 08:00 PM
I bought one despite the magazine reviews. They say that the fence slips. I found out quickly that one can easily adjust the fence. Mine came from the factory with the horizontal overhang loose enough to slip with moderate pressure. This was because the tightening arm would interfere with some cuts if it were tightened properly. If you take the tightening arm, loosen it enough to push the nut out of the socket on the back, rotate the nut so that it orients the tightening arm in a convenient position, and retighten, this problem goes away.
Ever since this little fix, I have had no problems. The fence locks tight in both height and angle. The index indents take a little time to figure out for accuracy, but this is just learning the tool. For $120, don't pass this up. |
