North Carolina Woodworker
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Reviews
Reviews Post your own review of tools, stores websites, etc.
» Upcoming Events
  1. Klingspor Wood Workers Show Case - Raleigh, NC -- September 11
  2. Thomas Day Museum Tour Hosted by Jerome Bias -- October 9th Click here for more!
  3. Angels for Heartstrings -- October 10th Click here for more!
  4. Klingspor Extravaganza - Hickory, NC -- October 29 and 30
  5. Welcome New Member Chat! Every Thursday evening at 7:30pm Click here for more!
Closed Thread
Thread Tools Display Modes
Old 02-04-2007, 10:57 PM   #1
Bowclamp clamping cauls reviewed
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 705
Show Printable Version Email this Page   Quote this post in a PM to DaveO
DaveO DaveO is offline 02-04-2007, 10:57 PM
Administrator
A while back someone created a thread about Bowclamps. There was a little discussion about them, but the general consensus was that nobody had tried them to give a reliable opinion about them. A reply was posted to that thread by Craig Feuerzeig of Zig Industries, the creator and maker of the Bowclamp system. He offered a set of the clamping cauls to be tested and reviewed by a member of NCwoodworker. D L Ames, took on the task, but due to a very busy work schedule has been unable to make the time to give them a good testing for review. He handed the set off to me to test and give y'all my thoughts and opinions about them. And they follow:
I have to admit that I was a little skeptical about the Bowclamp system. Not about the technique or method of using clamping cauls as it is a time proven method of distributing clamping pressure across a large area. Nor that they were well made items. But about the whole idea of buying curved pieces of wood for between $22-32 a set.
Well, I picked them up from D L on Saturday, and gave them a work over today. My first impression of the cauls as I removed them from the box was that they were definitely hand made, not by a CNC or any other automated process. You could see the tooling marks, a little burn from a router or shaper, and some slight chip-out from shaping. None of these thing affected the usability of the cauls, it just proved that Craig is a one man operation, and made each on himself.
Right off the bat I noticed that each set of cauls had their own unique curvature, definitely not random. I wanted to see if they would bow like they were designed to do so they could provide even pressure across the entire work piece.
Here's a shot of the cauls without clamps showing the curvature:
And with clamps applied closing up the gaps to a straight line:
After doing that I decided to put them to use in a panel glue up. I was making a cat bed, (as something to make that would require the use of the cauls). First I milled up three pieces of Lacewood that were to be the “headboard” of the bed. Normally I would use 3 or 4 Bessy clamps for this glue-up.
Here's a shot of the panels and cauls before clamping:
And after, showing very even (somewhat excessive for illustration purposes) glue squeeze out across the entire joint:
The cauls applied excellent pressure even though only two F-style clamps were being utilized.
The only draw back I found in this application was that I need to make 1/2” spacers to lift the panel so that it was in the center of the caul face to provide parallel pressure.
The next application I tried was a quick lamination of some Red Oak 5/4 stock to make the legs for the bed. Seeing as the panel was still drying in one set of the cauls I had to use my standard method of clamping for one and the cauls for the other.
Here's a 18” lamination using 3 Bessy clamps:
And here's a 26” lamination of the same stock using the 36” Bowclamp cauls:
Excellent glue squeeze out across the entire joint line:
The only issue I had during this application and others was the amount of screw travel to completely close the cauls. It takes almost the entire thread length of my standard F-style clamps...that's a lot of twisting.
I wish that I had a scientific method of testing how much pressure the cauls applied compared to a standard K-body style parallel jaw clamp. But I don't so I tried to break the joint after the glue had cured and the wood broke first...that's enough pressure in my book, it created a solid joint.
My overall impression of the Bowclamp caul system is that they are well designed, do what they are designed to do, and worth the money. A full set of 3 pairs of cauls 24”, 36” & 48” runs about $130. If you bought the wood to make them, about 6 BF of 8/4 hard Maple, you would spend around $36. Then factor in 3-4 hours milling, squaring, dimensioning, routing, cutting sanding and finishing, and you would come out better buying them. If you value your time like I do. I much rather be making something fun than some high tech bowed sticks.
And the savings goes even farther because instead of having a arsenal of expensive parallel jaw clamps you can use many less and cheaper F-style clamps. That is something that I found to be quite advantageous as I have many of the cheaper F-style clamps that I don't use very often due to their tendency to not stay parallel and to mar the work piece with their small area of surface contact.
My biggest complaint is that I don't have 2 sets of any of the sizes to be able to utilize them to help keep a panel glue up flat, something which I think that they would also excel in doing.
I would like to thank Craig for the opportunity to test out his product and commend him on taking something very simple and refining it to perfection for a reasonable cost.
Also thanks to D L for being to busy to test them out...I will find lots of use for them in my shop. If anyone would like to give them a test run themselves, I would be more than happy to let you give them a try providing you post your thoughts also.
Respectfully submitted,
Dave
Bowclamp
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Old 02-04-2007, 11:07 PM   #2
Toddler's Avatar
City: Hillsborough
State: NC
County: Orange
Threads: 54
Avg Visit Freq/Week
= 0.00 over 180 days
Re: Bowclamp clamping cauls reviewed
Nice review DaveO.
and seriously. . . cat bed???
PS) PM me your address so I can send that nesting box plan.
Show Printable Version Email this Page   Quote this post in a PM to Toddler
Old 02-05-2007, 04:36 AM   #3
cskipper's Avatar
City: Forest City
State: NC
County: Rutherford
Threads: 474
Avg Visit Freq/Week
= 3.81 over 180 days
Dave, thanks for a well written review. I think I was one of the first to mention these in thee original dissuasion, so I was especially interested in the results. It was also good to hear that DL is alive and well.
__________________
Cathy Skipper
Show Printable Version Email this Page   Quote this post in a PM to cskipper
Old 02-05-2007, 08:12 AM   #4
nelsone's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 168
Avg Visit Freq/Week
= 4.24 over 180 days
Good Review Dave! I have also been skeptical about purchaing cauls. You did a good job on the cost breakdown.
Show Printable Version Email this Page   Quote this post in a PM to nelsone
Old 02-05-2007, 08:42 AM   #5
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 193
Avg Visit Freq/Week
= 1.32 over 180 days
They sound like a good thing that I would find very useful. I have never been able to justify the high cost of K body clamps and their ilk, so I too have many "F" style clamps. I am going to be glueing up a lot of panels for the bedside cabs so perhaps I could borrow the 24" set??
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Show Printable Version Email this Page   Quote this post in a PM to DavidF
Old 02-05-2007, 09:25 AM   #6
Splinter's Avatar
City: Wallace
State: NC
County: Duplin
Threads: 179
Avg Visit Freq/Week
= 3.42 over 180 days
Dave, thanks for the detailed review. It helps to get a review from a know WW'er not just from the company's web site. I have to put them on my wish list.
__________________
You can't work without tools.
So many tools so little money.
Show Printable Version Email this Page   Quote this post in a PM to Splinter
Old 02-05-2007, 10:14 AM   #7
Administrator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 705
Avg Visit Freq/Week
= 6.18 over 180 days
Certainly, just let me know when you would need them, and I can drop them by Apex when I am in the area.
Dave
__________________
--Dr. Seuss
Old 02-05-2007, 10:18 AM   #8
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 193
Avg Visit Freq/Week
Dave
Starting next week end! how about bringing them to the Apex lunch tomorrow? then everybody could see them and I could take them away
__________________
Old 02-05-2007, 10:22 AM   #9
Administrator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 705
Avg Visit Freq/Week
You bet, I'll write myself a note right now.
Dave
__________________
--Dr. Seuss
Old 02-05-2007, 12:30 PM   #10
Sully's Avatar
City: Washington
State: NC
County: Beaufort
Threads: 162
Avg Visit Freq/Week
= 7.00 over 180 days
Originally Posted by Toddler View Post
Nice review DaveO.
Exact same thing I was thinking! Geez-louweez, lacewood and all. The darn bed I sleep on ain't no where near nice as that.
__________________
Humility is being corrected by your 4 year old on a woodworking project.
Show Printable Version Email this Page   Quote this post in a PM to Sully
Old 02-05-2007, 01:15 PM   #11
City: Rocky Mount
State: NC
County: Nash
Threads: 126
Avg Visit Freq/Week
= 6.14 over 180 days
Very well-written, objective review, Dave.
I agree with you on the value of my time. And if you reckoned you could build a set in 3-4 hours that means it would likely take me a few days!!
Chuck
Show Printable Version Email this Page   Quote this post in a PM to cpowell
Old 02-05-2007, 01:18 PM   #12
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 193
Avg Visit Freq/Week
Dave
Thank you Sir, I appreciate that.
__________________
Old 02-05-2007, 02:28 PM   #13
sapwood's Avatar
City: Durham
State: NC
County: Durham
Threads: 219
Avg Visit Freq/Week
= 5.09 over 180 days
Well thought out and thorough review Dave
Excellent point about not needing the big Besseys'. Their cost has limited me to mostly F-clamps.
Roger
__________________
I ain't never had too much fun!
Show Printable Version Email this Page   Quote this post in a PM to sapwood
Old 02-05-2007, 03:49 PM   #14
Administrator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 705
Avg Visit Freq/Week
Dave
Bowclamp
An amendment to my review. After visiting the SMC Bowclamp forum I realized that CNC technology (Shopbot as a matter of a fact) is used quite heavily in the production of the cauls. In addition to a very cool Drycleaner's conveyor system to automate the finishing process.
YouTube - bowclamp dipping mock-up
That doesn't detract from their usefullness, I just didn't want to be giving out incorrect information...even if it was only my erroneous impressions.
Dave
__________________
--Dr. Seuss
Old 02-05-2007, 07:39 PM   #15
John Reeves's Avatar
City: Durham
State: NC
County: Durham
Threads: 88
Avg Visit Freq/Week
= 0.58 over 180 days
Thanks for the review Dave. It really helps when a trusted source comes forth.
Show Printable Version Email this Page   Quote this post in a PM to John Reeves
Closed Thread New posts
bow , cauls , clamp , clamping
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.ncwoodworker.net/forums/f35/bow-clamp-clamping-cauls-7110/
Posted By For Type Date
Bowclamp.com - Press & Reviews This thread Refback 10-28-2008 10:40 AM
Bowclamp.com - Press & Reviews This thread Refback 10-05-2008 08:55 AM
Bowclamps, Bob and I go visiting This thread Refback 07-20-2008 03:29 PM
Bowclamp This thread Refback 07-03-2008 02:07 PM
Similar Threads
Bowclamp clamping cauls reviewed DaveO Reviews 20 02-05-2007 10:35 PM
Need help clamping odd shape rhett General Woodworking 13 01-21-2007 08:10 PM
Bow clamp cskipper Reviews 6 11-12-2006 12:34 PM
Calls or Cauls (?) (Re. Bow Clamp) John Reeves General Woodworking 5 09-28-2006 01:00 PM
Clamp down sapwood General Woodworking 9 08-02-2006 10:19 PM
How to get discount qualified
Mountain Sawyers Ad
Lee Valley ad
Kreg Ad
The Woodworking Source Ad
» Stats
Members: 4,681
Threads: 31,246
Top Poster: DaveO (15,165)
Welcome to our newest member, shoegler
» Today's Birthdays
SevenPin
Jay Sr. (66)
Geege (56)
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
