North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Reviews
Reviews Post your own review of tools, stores websites, etc.
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 05-24-2009, 10:30 PM   #1
Air piping for shop
Splinter's Avatar
City: Wallace
State: NC
County: Duplin
Threads: 172
Show Printable Version Email this Page   Quote this post in a PM to Splinter
Splinter Splinter is offline 05-24-2009, 10:30 PM
After a recommendation by Woodguy1975 I decided to install this system in my new shop. I purchased the "Master Kit" and installed it. I was rather skeptical that the push on fitting would work without leaking air. I was wrong. They do not leak. The system is super easy to install. If you change your mind or make a mistake you can remove the fittings with just a push on the fitting to release it. The kit comes with a cutter that you should use to cut the pipe.
I ran two main lines in my shop from my air compressor that is located in the barn half of my shop. I ran the lines 10' high on the walls and then did a drop drown to about 5' for the air outlets. Each outlet has a bleed valve to bleed off any moisture in the lines. You can put the lines in the wall but I did not put mine inside the wall. I am really please with the system.
Thanks Woodguy1975 for recommending this system.
__________________
You can't work without tools.
So many tools so little money.
Old 05-24-2009, 11:15 PM   #2
City: Concord
State: NC
County: Cabarrus
Threads: 34
Avg Visit Freq/Week
= 6.07 over 180 days
Re: Air piping for shop
No experience with this, but Harbor Freight now offers a similar system for $90. I have no idea if they carry this in stores or not.
__________________
Eric
Show Printable Version Email this Page   Quote this post in a PM to thrytis
Old 05-25-2009, 12:53 PM   #3
City: Raleigh
State: NC
County: Wake
Threads: 18
Avg Visit Freq/Week
= 6.30 over 180 days
I would say that the HF setup is way too small diameter wise (3/8 fittings). The air is going to get lost by the time it gets to the tool after going through those small fittings. Even if you build a system with 3/4" tubing the fittings (probably 1/2" ID) severely restrict the air and you will have problems with any high volume tools.
And PLEASE, don't anyone mention making a system out of PVC.I know people do but, but, but...
Show Printable Version Email this Page   Quote this post in a PM to DaveD
Old 05-25-2009, 01:05 PM   #4
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Threads: 263
Avg Visit Freq/Week
= 6.69 over 180 days
It sure it is much easier to run that stuff. The solenoid valves I got for my autogates all came with push connectors. They work well.
I looked at that stuff and PEX but the working pressure was listed as only 150 psi. I have a 175 psi compressor so ended up going with copper.
Show Printable Version Email this Page   Quote this post in a PM to Alan in Little Washington
Old 05-25-2009, 01:58 PM   #5
Bryan S's Avatar
City: Burlington
State: NC
County: Alamance
Threads: 93
Avg Visit Freq/Week
= 6.57 over 180 days
When I serviced car washes I used the pushlock fittings and loved them, had very few problems with leaking assymbly was quickand easy They dont always come apart as easy as thet are supposed to but the system works good.
__________________
He is your partner, your defender, your friend, your dog. You are his love, his life, his leader. He will be yours, faithful and true to the very last beat of his heart. You owe it to him to be worthy of such devotion
Show Printable Version Email this Page   Quote this post in a PM to Bryan S
Old 05-25-2009, 09:24 PM   #6
City: Concord
State: NC
County: Cabarrus
Threads: 34
Avg Visit Freq/Week
Both the HF and the Rapid Air system use 1/2" OD tubing. I imagine most people with high volume requirements would install a metal pipe system, but the nylon tube systems probably would be sufficient for the typical home woodworker.
__________________
Eric
Old 05-27-2009, 02:03 PM   #7
woodguy1975's Avatar
City: Hickory
State: NC
County: Burke
Threads: 133
Avg Visit Freq/Week
= 4.39 over 180 days
Welcome dude! When I did my calculations I found that 1/2" would carry enough air for any compressor anyone with a home woodshop would run. Unless you have crazy run lengths 1/2" is perfect. It looks like HF just copied the system. Those look a lot like Festo filttings.
I can't wait to get going on my new shop and get back to thinking about wood, tools and sawdust.
Good Luck,
__________________
Keeping the Hokie Spirit Alive!! Remember 4/16/2007
First known case of the dreaded "Woodguy Disease" and is highly contagious. Stay away.... stay away! Warning! Not liable for excessive tool buying, drooling, or the sudden urge to spend large amounts of money.
www.jsrwoodworking.com
Show Printable Version Email this Page   Quote this post in a PM to woodguy1975
Old 05-28-2009, 01:08 PM   #8
City: Raleigh
State: NC
County: Wake
Threads: 18
Avg Visit Freq/Week
Couple of things to remember with flexible piping. You don't want any dips in horizontal runs because they will accumulate moisture. No matter what you end up running you want everything sloped down hill to some drainage mechanism. This is hard for a woodworker to do since 'crooked' isn't in our vocabulary.
At the bottom of each of your vertical runs to the tools put the connector some distance above the bottom end of the pipe (6"+??) and put a drain valve on the very bottom so you can drain the line periodically.
If at all possible try to cool the air right after it leaves the compressor and before it gets into the piping system. Basically you want the air to traverse some big vertical metal piping runs (drain at bottom) before entering the horizontal distribution system.
My last shop I piped the right way. The shop I have now just has air hose all over the floor. Go figure.
Old 05-29-2009, 12:20 AM   #9
mkepke's Avatar
City: Fuquay Varina
State: NC
County: Wake
Threads: 56
Avg Visit Freq/Week
= 6.14 over 180 days
Good post Splinter.
I've been hearing about using PEX for air piping for years - nice that somebody put a kit together (and then HF copied them )
-Mark
Show Printable Version Email this Page   Quote this post in a PM to mkepke
Closed Thread
air , piping , shop
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Question on Piping Dudelive "How To" Forum 8 05-24-2009 07:59 PM
6" flex piping meika123 Workshops 6 04-02-2008 03:07 PM
DC piping? Splinter Workshops 15 01-27-2008 01:26 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,104
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
