North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > Scrollsaw Work
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 09-14-2009, 07:56 AM   #1
Sanding
cskipper's Avatar
City: Forest City
State: NC
County: Rutherford
Threads: 443
Show Printable Version Email this Page   Quote this post in a PM to cskipper
cskipper cskipper is offline 09-14-2009, 07:56 AM
How do you folks sand your scroll saw pieces - from portrait style to baskets, intarsia..... What type of sanding products/tools/paper.... do you use? I linked to the thread about the abranet products and discovered that they make the sanding sticks in 6, 8 and 10" in addition to the 12 3/4" and 16 1/2" kind I have. Do you use the scroll sanders (fit kind of like a blade in your saw?) Flapwheels (or is that flywheels?) or sanding mops (never tried those)? Belt sanders (wide or not), ROS?
I guess I am mostly intersted in sanding detailed fretwork.
__________________
Cathy Skipper
Old 09-14-2009, 08:18 AM   #2
wdkits1's Avatar
City: Midlothian
State: VA
County: Chesterfield
Threads: 42
Avg Visit Freq/Week
= 4.20 over 180 days
Re: Sanding
Hi Cathy
Dremal has a 1 1/4 flapper wheel that works pretty good for sanding small intricate pieces. I also use the 1/4" and 1/2" sanding drums and a 3x18" belt sander. Plus an assortment of sanding sticks and good old hand sanding using various sheet sand papers.
__________________
wdkits1
www.midlothianwoodworks.com
"why buy it if you can build it"
Show Printable Version Email this Page   Quote this post in a PM to wdkits1
Old 09-14-2009, 08:57 AM   #3
PChristy's Avatar
City: Lexington
State: NC
County: Davidson
Threads: 363
Avg Visit Freq/Week
= 6.92 over 180 days
Re: Sanding
Cathy, for the most part when I do my fretwork I sand the piece up to 220 grit before I cut the piece - if the piece is 1/4 stock and it is usually is a portrait I do not worry to much about the inside sanding - I usually use spirals on them anyway - After I get the portrait done I will take a plumbers torch to the back of it and burn the fuzzy's off(do this before any type of cleaning with combustible liquids-ex.MS) then if I need to I will lightly hand sand spot where need with the 220 - If I do any fret that is thicker -1/2-3/4 - then if they do need sanding I will use the blade sandpaper that hooks up to the scroll saw. With the bowls that I have made I will use a drum sander that goes into my drillpress after I have glued the pieces together to make the bowl
__________________
Phillip
My Saw Is Making Dust
Time waits for no one. Treasure every moment you have. You will
treasure it even more when you can share it with someone special. (Arthor unknown)
Show Printable Version Email this Page   Quote this post in a PM to PChristy
Old 09-14-2009, 09:01 AM   #4
Sealeveler's Avatar
City: Sea Level
State: NC
County: Carteret
Threads: 12
Avg Visit Freq/Week
= 6.96 over 180 days
Re: Sanding
I use icecream sticks and tongue depressor sticks with psa paper on them.Dremel with various bits but for names I use a Dremel in the drillpress with a cotterpin chucked in it with psa paper placed between the pins.Tony
__________________
O The Secret of Joy in work is contained in one word "Excellence".To know how to do something well is to enjoy it.By Pearl Buck (wish it was carving)
Show Printable Version Email this Page   Quote this post in a PM to Sealeveler
Old 09-14-2009, 10:37 PM   #5
cskipper's Avatar
City: Forest City
State: NC
County: Rutherford
Threads: 443
Avg Visit Freq/Week
= 2.45 over 180 days
Re: Sanding
You lost me there - what's a cotterpin?
__________________
Cathy Skipper
Old 09-14-2009, 11:00 PM   #6
Sealeveler's Avatar
City: Sea Level
State: NC
County: Carteret
Threads: 12
Avg Visit Freq/Week
Re: Sanding
http://en.wikipedia.org/wiki/Cotter_pin http://en.wikipedia.org/wiki/Split_pin
__________________
Old 09-14-2009, 11:09 PM   #7
Sealeveler's Avatar
City: Sea Level
State: NC
County: Carteret
Threads: 12
Avg Visit Freq/Week
Re: Sanding
I lower the Dremel far enough that the eye of the cotter pin is below the surface of the Dremel Drillpress table.Tony
__________________
Old 09-14-2009, 11:16 PM   #8
cskipper's Avatar
City: Forest City
State: NC
County: Rutherford
Threads: 443
Avg Visit Freq/Week
Re: Sanding
So I am waaaay over doing my sanding? When I do a piece of fretwork (that won't be framed), or ornaments, I sand all the cut edges so there are no "sharp" edges or rough spots that could catch a cloth if dusted. I know that when I sold the pieces to the gallery a couple of years ago that that was important. I know that I'll never get paid enough for a piece for that kind of time, but I'd rather have a room full of pieces I'm proud of than ones I've worked on and are okay. Is there an to sand the inside edges, especially with ornaments? I mean that I was tickled this a.m. to discover that they make smaller sanding sticks than the ones I use that take a 12 3/4" bands. In case you can't tell, I'm a little obsessive compulsive about this - help (please!)
__________________
Cathy Skipper
Old 09-14-2009, 11:25 PM   #9
PChristy's Avatar
City: Lexington
State: NC
County: Davidson
Threads: 363
Avg Visit Freq/Week
Re: Sanding
Cathy - with most of my ornaments I do not sand the inside cuts because the blades that I use usually does not leave a bad cut that needs to be sanded - I do sand and clean up both sides to make sure any fuzzy's are gone = With the things I do not frame I do make sure it does have a good smooth service = hand sand-the sanding belts that fit on the scroll saw etc. Most of the things that I do - I do frame behind glass with a black back ground = with the black back ground you have to make sure all the fuzzy's are gone or they will show up - don't feel bad that you want to sand it all - you do great work and I know that you want it to look its best - hang in there
__________________
Phillip
Old 09-15-2009, 07:14 AM   #10
Senior Moderator
Events Director
ScottM's Avatar
City: Cary
State: NC
County: Wake
Threads: 257
Avg Visit Freq/Week
= 6.49 over 180 days
Re: Sanding
For 90% of my cutting I use a reverse tooth blade whic greatly reduces sanding. I now own a sand flee (bought used) that does great job on bigger stuff. For smaller pieces I use full sheets of sand paper that I clamp to a board and then "move the pieces over the sand paper.
I do not sand the inside cuts of fret work
__________________
Making Saw Dust With a Scroll Saw
Show Printable Version Email this Page   Quote this post in a PM to ScottM
Old 09-15-2009, 11:38 AM   #11
City: Kannapolis
State: NC
County: Cabarrus
Threads: 3
Avg Visit Freq/Week
= 4.32 over 180 days
Re: Sanding
I use fine tooth blades to minimize the need to sand the scrolls as much as possible. If there are fuzzies on the cut edges I have a ROS with a soft pad on it and 220 sand paper that I use and I go over both sides of the piece while it is being held in place with a router mat. This removes the fuzzies very quickly and still leaves crisp edges (if you don't over sand). Irregularities in the scroll cuts are tough to fix. For these I have several sets of jeweler type files and popsicle sticks with sandpaper on them. The real trick with these is to learn not to make them when you are doing the cutting, so that this type of touchup isn't needed.
Charley
Show Printable Version Email this Page   Quote this post in a PM to Charles Lent
Old 09-15-2009, 12:15 PM   #12
CarvedTones's Avatar
City: Cary
State: NC
County: Wake
Threads: 189
Avg Visit Freq/Week
= 6.53 over 180 days
Re: Sanding
Kind of a "me too" - I use reverse tooth blades because I like that rattling sound it makes when you don't hold your work down; really calms my nerves.
I sometimes go over the whole thing lightly with fine paper on a sanding block, but I don't even always do that. good blades leave pretty polished surfaces and rarely fuzz up much if any.
__________________
-Andy
Wag more - bark less.
http://www.CarvedTones.com
Show Printable Version Email this Page   Quote this post in a PM to CarvedTones
Old 09-16-2009, 09:11 AM   #13
CaptnA's Avatar
City: Mills River
State: NC
County: Henderson
Threads: 33
Avg Visit Freq/Week
= 3.46 over 180 days
Re: Sanding
you sand your pieces???
I thought splinters added to the authentic hand made penache!
This is one reason I don't do a lot of intricate fretwork. Its frustrating and time intensive for me to get a piece where I think it ought to be.
One thing I've found that works pretty well for me - look for places that give away promotional fingernail files. Not the metal ones but the cardboard ones, usually with a logo on them. A fire department I know had hundreds of them left over after their open house/fire prevention week a year or two ago. I tried to make sure some of the left overs didn't go to waste. They are probably close to 120 grit on on side and 220 on the other and work well and last a long time. And I can wrap a finer grit paper around the file if I need.
Show Printable Version Email this Page   Quote this post in a PM to CaptnA
Old 09-17-2009, 08:36 AM   #14
cskipper's Avatar
City: Forest City
State: NC
County: Rutherford
Threads: 443
Avg Visit Freq/Week
Re: Sanding
Originally Posted by wdkits1 View Post
Hi Cathy
Can you adust the speed of your belt sander? One of the reasons I have avoided intarsia is that I can't figure out how to securely hold one of the many small pieces against a belt sander and not hurt myself. (yes, I am a clutz).
I am in a hurry this a.m., but remember that someone mentioned crisp edges for their ornaments. I use blades which leave a pretty smooth finish, and know that redesigning around oop's is a different issue. I really don't want crisp edges, I want soft edges, inside and outside cuts if it is a piece that someone will handle.
__________________
Cathy Skipper
Old 09-17-2009, 09:29 AM   #15
City: Cary
State: NC
County: Wake
Threads: 189
Avg Visit Freq/Week
Re: Sanding
Cathy,
I have one of the flex drum sanders shown at the top of this page:
http://www.intarsia.com/Hardware.html
You can make your own using pipe insulation and sleeves for the hard drum sanders for drills, but I went ahead and spent the $35 plus $2 more for the 1/2" adapter so I could put it in my drill press, though right now it is on a washer motor.
Anyway, this smooths corners much better than a flat sanding belt and it sands contours. It's not very grabby as it is only touching a small area of your piece at any given time, but techniques is important - you must keep it moving and inspect often to make sure you are sanding evenly.
For rotary sanding detail, I really like bristle discs:
http://www.woodworkingshop.com/cgi-b...mSt=FO-BRISTLE
The instructions tell you to put 3 discs on the mandrel, but you can use only 1 or 2 to go more slowly in tight areas. Keep in mind that the 1" ones have an "impact speed" much higher than the 3/4" and the 3/4" has 400 grit available (it is pretty much polishing on hardwood). The 1" 80 grit is a carving tool disguised as a sander (DAMHIKT).
__________________
-Andy
Closed Thread
sanding
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sanding help needed Bas General Woodworking 18 11-25-2008 02:47 PM
Sanding Question Nice Figures Woodturning 3 06-27-2007 01:33 PM
How much sanding. clowman General Woodworking 9 12-04-2005 12:28 AM
Sanding after priming???? DaveO General Woodworking 0 09-09-2005 10:03 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,666
Threads: 25,110
Top Poster: DaveO (14,702)
Welcome to our newest member, dirty b
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
