Been sorta busy lately with son and grandson's moving back up to pa. and with the weather being cold haven't been out in the shop too much since doing the Christmas stuff. The the weather warmed up, the kids got outside more and this project came along I couldn't resist. It's not often (except for Ethel) that I can combine wood working and being a motor-head in one project but this one did it. I'm already halfway into making a second with some changes to the design of my own.
Pattern #SB-1710-P from Steebar. Took me roughly 2 weeks of 2-3 hours at a time in the shop and onthe computer redoing some of the plans since they aren't to scale as stated on the drawings.
Maple, oak, walnut and cherry. Small 1 rpm motor from Steebar ($40) I've since found quite a bit cheaper on ebay does the work of operating the piston, gears, valves, etc. Switch on lamp base is from Angelo lamp supplies #70421. It allows me to turn on the motor and lamp, turn off the motor and let the lamp on, turn off the lamp and let the motor on and then shut everything off.
In my set of plans I've changed the shape of the back board to contour more to the gears, done away with the gear shafts going all the way through the front board to a back board and added a place for a spark plug in the head by the valves. I'll post when that ones done. I'm also considering making plans for a twin-V four stroke engine.
